Winchester - Todmorden
afyutr
23 Dec 2013
Firstly thank you to all for the interesting and thought provoking discussion and advice in general on here.
I have been trying to get my head round if there is a cheaper way of doing Winchester WIN -Todmorden TOD than a) being quick off the mark with advances (best case £74.20 return) or b) paying the full off-peak return price of over £110. My first foray into working out the routeing guide / splitting options has ended up in a fried brain. This may be because there is no other option!!
I'm confused as to why the "via Leeds" or "via Manchester" tickets cost more than "any permitted route" tickets. Are Leeds and Manchester not permitted on the any permitted ticket?...
Usual travel is Fri (after 0930/peak hours), return Sun.
Thanks in advance for any advice.
Romilly
5 Nov 2013
You can get cheap Advances from London Kings X to Todmorden via Leeds. I looked on the East Coast website for 28th & 30th March, and there were one-way advances at £13 (that includes a discount for booking through the EC website): around the middle of the day on the Friday, but only on the 1045 coming back on the Sunday. That leaves you looking for a cheap way to get from Winchester to London. An OffPeak Return would do the job (outward from 0856 onwards) but is £35.50, or £41.50 if you buy it to Zone U1* in order to cover the tube as well.
It may be that splitting Advances on the route via Reading, Birmingham and Manchester would reduce the £37.10 advances you have found on that route, but that's not a route I have tried doing splits.
30907
The tickets you refer to have the Maltese Cross which permits travel via London including cross-London transfer. The "any permitted" doesn't.
PermitToTravel
21 Dec 2011
Groningen
If you wouldn't mind going via London, then there are usually some cheap advances from Winchester to Birmingham on Virgin (I can see many for £12.00 and £16.50, even leaving on Friday afternoons).
Using a Mixing Deck-style booking engine, like East Coast (recommended as it comes with reward points), click "show slower routes" on the left hand side, tick the box next to "VWC & CONNECTNS", and click on Update.
From Birmingham, you can pick up the (usually far more expensive and crowded) Crosscountry route on another advance ticket, if you can find any good tickets.
bb21
Emeritus Moderator
4 Feb 2010
Blimey, you haven't half chosen a complicated fare for working out permitted routes. ;)
Not as clear cut as this. If the OP purchases the Route Any Permitted Off-Peak Return, he will be allowed to use all of the permitted routes on the Route +Via Manchester fare because it is cheaper, one of which is via London. That said, this would not apply if the ticket held is an Anytime Return.
I don't blame you. You have chosen probably one of the most complicated examples and even my head hurts looking at it.
Perhaps. I will show some of my workings below, if anyone is able to keep up with it, good luck. :p
Assume that you purchase the Route Any Permitted Off-Peak Return fare.
Winchester has two associated routeing points: Eastleigh and Basingstoke.
Todmorden has three associated routeing points: Blackburn, Halifax and Manchester Group.
Fares Check
(SOS - Anytime Single / SVS - Off-Peak Single)
Winchester - Todmorden:
Route +Via Manchester #1
SVS £102.50
SOS £203.00
Route +Via Leeds #2
SOS £157.00
Route Not Via London #3
SOS £110.50
Route Any Permitted #4
SOS £110.50
Eastleigh - Todmorden:
Route +Via Manchester - FAILS for all fares
SVS £104.10
SOS £207.50
Route +Via Leeds - PASSES for #1
SOS £159.50
Route Not Via London - PASSES for #1 and #2
SOS £115.50
Route Any Permitted - PASSES for #1 and #2
SVS £114.00
SOS £115.50
Basingstoke - Todmorden:
Route +Via Manchester - PASSES for #1
SVS £96.30
SOS £195.50
Route +Via Leeds - PASSES for #1 and #2
SOS £149.00
Route Not Via London - PASSES for #1, #2, #3 and #4
SOS £104.00
Route Any Permitted - PASSES for #1, #2, #3 and #4
SVS £98.50
SOS £104.00
Winchester - Blackburn:
Route Via Banbury - PASSES for #1, #2, #3 and #4
SOS £103.50
Route +Via London - PASSES for #1
SVS £110.70
SOS £203.00
Winchester - Halifax:
SOS £111.00
Route +Any Permitted - PASSES for #1 and #2
SOS £152.00
Winchester - Manchester Stns:
SVS £104.80
SOS £109.00
SVS £102.50
SOS £202.00
Select Appropriate Routeing Points
Eastleigh is not appropriate.
Basingstoke is appropriate if considering the Route Not Via London fares and Route Any Permitted fares.
Blackburn is appropriate if considering the Route Via Banbury fare.
Halifax is not appropriate.
Manchester Group is appropriate if considering the Route Via Banbury fare.
Check Map Permissions
Basingstoke - Blackburn (must go via Banbury): LONDON, LE+EP, RP;
Basingstoke - Manchester Group (must go via Banbury): LONDON, LE+MA, LE+MA+NR, RM, RM+NR;
I'm not going to look the maps up. Any route you can trace using these map permissions which goes via Banbury is a permitted route on the Route Any Permitted Off-Peak Return between Winchester and Todmorden. For LONDON map permission, you combine Basingstoke - London Group maps with London Group - Blackburn maps (or London Group - Manchester Group in the latter case) and the route must be one which goes via Banbury.
Other Permitted Routes
There is no direct train between Winchester and Todmorden.
The shortest route entirely by rail, which is likely to be the one below, is permitted.
Winchester - Todmorden shortest route said:
Winchester 0
Micheldever 8.5
Basingstoke 18.75
Bramley (Hants) 23.75
Mortimer 27
Reading West 33.25
Reading 34.25
Tilehurst 37
Pangbourne 39.75
Goring & Streatley 43
Cholsey 46.75
Didcot Parkway 51.5
Appleford 53.5
Culham 54.5
Radley 56.75
Oxford 61.75
Tackley 70.75
Heyford 73.5
Kings Sutton 81
Banbury 84.5
Leamington Spa 104.5
Coventry 114
Bedworth 120.25
Nuneaton 124
Atherstone 129
Polesworth 133
Tamworth 136.5
Lichfield Trent Valley 142.75
Stoke-On-Trent 173
Longport 175.75
Kidsgrove 179.25
Congleton 184.75
Macclesfield 192.75
Prestbury 195.5
Adlington (Cheshire) 197.5
Poynton 199.5
Bramhall 201
Cheadle Hulme 202.5
Stockport 204.75
Heaton Chapel 206.25
Levenshulme 207.75
Manchester Piccadilly 210.75
Manchester Oxford Road 211.25
Deansgate 211.5
Salford Crescent (Lancs) 213
Salford Central (Lancs) 214
Manchester Victoria 214.75
Moston 218.75
Mills Hill 220.75
Castleton (Manchester) 223.5
Rochdale 225.25
Smithy Bridge 227.5
Littleborough 228.5
Walsden 232.5
Todmorden 234
In addition, as I mentioned above, because this fare is more expensive than the Route +Via Manchester fare, you are also permitted to use any route permitted by this fare. I am not going to do it all over again, but you go back to fares check and pick out appropriate routeing points which pass fares check for #1, and go through the same process again.
Clearly travel via Manchester in this case would be permitted, so is via London , but can you find a permitted route via Leeds using this fare?
afyutr
23 Dec 2013
Bingo!
Bb21 (et al), thank you. I shall digest all that later today.
