Wilmslow to Crewe: Enhanced Permitted Speed (EPS)?
GhostManDN91
2 Oct 2022
Wigan
Hi all, not sure if it's been asked previously. I was wondering how come there is EPS on the Stoke-on-Trent to Cheadle Hulme via Macclesfield line but not from Crewe to Cheadle Hulme via Wilmslow?
jfollows
26 Feb 2011
Wilmslow
Because it’s 110 to Crewe for anything, no tilt required. It’s pretty straight, unlike the line via Macclesfield. Used to be 100 from Edgeley Junction No. 2 so just got upgraded over most of the length to 110. The entire line via Macclesfield used to be 85 maximum back at the same time.
If you mean EPS more than 110, it probably wasn’t thought worth the extra expense. 20 miles at 125mph is just over a minute faster than at 110mph.
lowe1409
6 Feb 2024
Cheshire
The via Macclesfield line is also much busier with tilting stock.
I don't know what the services were like back when EPS was being installed, but at present you have 2x Avanti and 2x XC via Macclesfield Vs 1x Avanti via Wilmslow. (XC originally having tilt on the 221s)
Is it also worth noting that via Wilmslow, you have much more local services and freight to get around. (Were TFW possibly using 15x when EPS was being installed on the Manchesters?) 2x northern stoppers and at least 1tph freight. 125mph would have made pathing these harder
The Manchester-Crewe line got bi-di signalling between Cheadle Hulme and Sandbach instead, all for improving freight capacity and resilience.
This was before HS2 was planned.
The nightmare scenario for NR was the prospect of pathing more fast trains via Crewe under Phase 2a (there would have been fewer via Stoke).
With HS2 now down to Phase 1, the current split via Stoke/Crewe can be maintained.
Nevertheless, it is odd that EPS wasn't implemented, as the cost would have been peanuts compared to that of the renewal/upgrade work actually done.
The speed/capacity issue is still prevalent on the Stoke route too, limiting more freight and stopper paths being offered.
