Metro95
Once it is open, will all trains on the GWML need to stop at Old Oak Common?
Yes. It’s been explicitly stated that will happen in a number of route strategy type publications written by NR.Once it is open, will all trains on the GWML need to stop at Old Oak Common?
So - all GWR journey times increased by how much? 5 minutes?The benefits of OOC will be rather diluted if they don't stop everything. So I expect everything, or virtually everything, will.
To Paddington yes, but in many cases the loss will be significantly smaller since people will connect to Crossrail at OOC rather than Paddington.So - all GWR journey times increased by how much? 5 minutes?
If noone will want to use it, why would there be increased overcrowding?And probably more overcrowding?
And for what purpose ? Passengers from say, Birmingham to/from Reading, Bristol, Cardiff, etc. are hardly likely to want to use HS2 and change at OOC when they already have through services.
Yes to Paddington, but Paddington area is not much or a destination anyway. But some trains might drop a different stop instead eg Swindon, or Didcot, or Reading, so time to Paddington is roughly neutral for further stations. But too early to tell.So - all GWR journey times increased by how much? 5 minutes?
I don't think anyone will be able (legally) to do OOC-Euston hops.
It just isn't going to happen. Having passengers on board for a journey that short doesn't work with ensuring long distance capacity is maintained.I hope they will, it’ll make getting from the GWML to Kings Cross/St Pancras a lot easier.
That ignores the known facts that a lot of passengers prefer a through train, albeit slower, rather than the inconvenience of changing trains and waiting for (possibly unreliable) connections. Speed is not the only consideration when people decide how and when to travel. And any attempt to drastically reduce (or make worse) existing services over classic lines would be politically unacceptable.To Paddington yes, but in many cases the loss will be significantly smaller since people will connect to Crossrail at OOC rather than Paddington.
The reality is, Cardiff to places like Birmingham etc, will be cheaper for the government via Old Oak COmmon, and thus the government will have a vested interest in ensuring people use those routes in preference to the classic ones.
Cardiff to Manchester takes ~3hr30 right now, you can be in Old Oak Common in under 2 hours, then after Phase 2 to manchester you will be in Manchester in 70 minutes. Depending on your specific connections it may even be marginally faster, and the concentration of traffic onto fewer, longer trains with lower staffing requirements will save substantial sums of money.
From the South West the potential savings will be dramatic, Plymouth to London will be ~3hr to OOC, so Plymouth Manchester in 4hr10-4hr30 (depending on connections). The current journey is well over 5 hours, and requires connections at Birmingham etc.
Given the mess that Birmingham New STreet is these days, getting as much traffic as possible out of there is a serious benefit for the railway as a whole.
EDIT:
If NPR to Marsden actually happens, you will also be able to pull essentially all the existing NE-SW traffic onto OOC trains.
The WLL also potentially relieves Central London transfer traffic by allowing easier access to Clapham Junction.
Would they not just be using the capacity that is not being used by those passengers joining/leaving at OOH to/from the Midlands/North?It just isn't going to happen. Having passengers on board for a journey that short doesn't work with ensuring long distance capacity is maintained.
The most important criterion, I would argue, is ticket price.That ignores the known facts that a lot of passengers prefer a through train, albeit slower, rather than the inconvenience of changing trains and waiting for (possibly unreliable) connections. Speed is not the only consideration when people decide how and when to travel.
Empirical data from the current railway indicates that this is probably not true!And any attempt to drastically reduce (or make worse) existing services over classic lines would be politically unacceptable.
If more passengers are expected to travel via OOC instead of using existing Cross Country services does that mean longer trains will be required on the GWR long distance services?To Paddington yes, but in many cases the loss will be significantly smaller since people will connect to Crossrail at OOC rather than Paddington.
EDIT:
Journey times to central London will be reduced compared with before 2019, I suspect, which means that commuters and London leisure travellers don't miss out. The only real losers are cross-London long distance passengers, and to be honest, when you're travelling from (say) Exeter, five more minutes means nothing.So - all GWR journey times increased by how much? 5 minutes?
Stratford is different gravy. It's much closer to the centre, and the development is the kind of big concrete chain stuff that always gets built when the economy is perceived to be booming. Plus, there's a lot of student accommodation there.Look at Stratford 30 years ago to what it is now. Hardly any main line trains called. Yes there was the Olympic catalyst, but the area around Old Oak will doubtless change out of all recognition too.
Different liquor if you know yer pie ‘n’ mash.Stratford is different gravy. It's much closer to the centre, and the development is the kind of big concrete chain stuff that always gets built when the economy is perceived to be booming. Plus, there's a lot of student accommodation there.
This. Instead of forcing trains from Cornwall to London to stop at OOC , how about give the south west some direct XC trains to the north west instead. Direct trains to places like a liverpool or Manchester (even if 30 mins slower than HS2 changing at OOC) would be more welcome than devaluing the GW line out of Paddington.That ignores the known facts that a lot of passengers prefer a through train, albeit slower, rather than the inconvenience of changing trains and waiting for (possibly unreliable) connections. Speed is not the only consideration when people decide how and when to travel. And any attempt to drastically reduce (or make worse) existing services over classic lines would be politically unacceptable.
Who will pay for these trains?This. Instead of forcing trains from Cornwall to London to stop at OOC , how about give the south west some direct XC trains to the north west instead. Direct trains to places like a liverpool or Manchester (even if 30 mins slower than HS2 changing at OOC) would be more welcome than devaluing the GW line out of Paddington.
When travelling from Devon and Cornwall five minutes makes no difference to anything.devaluing the GW line out of Paddington.
To be fair, Bristol to Manchester is a long-standing route which doesn't often go badly wrong nowadays.Many of the current problems on the railway are a result of trying to operate trains from everywhere to everywhere.
I suspect that very few passengers from the West have Paddington as their final destination. The connection at Old Oak Common to Crossrail is going to be similar or better than that at Paddington I would think. Paddington is rather badly sited in relation to the centre of London compared to other termini so many will be using the Crossrail anyway at Paddington.That ignores the known facts that a lot of passengers prefer a through train, albeit slower, rather than the inconvenience of changing trains and waiting for (possibly unreliable) connections. Speed is not the only consideration when people decide how and when to travel. And any attempt to drastically reduce (or make worse) existing services over classic lines would be politically unacceptable.
Interestingly, there is a ton of Imperial student accommodation around North Acton / Gypsy Corner which is really the beginnings of the OOC cluster - presumably folks based down at the ex-BBC Worldwide campus.Journey times to central London will be reduced compared with before 2019, I suspect, which means that commuters and London leisure travellers don't miss out. The only real losers are cross-London long distance passengers, and to be honest, when you're travelling from (say) Exeter, five more minutes means nothing.
Or HMP Wormwood Scrubs. Handy for visiting.OOC isn't actually that far from the centre - it's just a wasteland of sorts. But it'll be 10 mins into Bond St.
An interesting question. Less active people will still probably prefer the through train.Bristol and Cardiff maybe, but in 10 years time when you tap into a journey planner “Birmigham to Reading” and it gives you an option that takes 1h10 minutes or one that takes 1h40, and the 1h10 option is cheaper, which will you take?
Plymouth has a direct train to Manchester today (1153).This. Instead of forcing trains from Cornwall to London to stop at OOC , how about give the south west some direct XC trains to the north west instead. Direct trains to places like a liverpool or Manchester (even if 30 mins slower than HS2 changing at OOC) would be more welcome than devaluing the GW line out of Paddington.
Not always. Look at how Birmingham New Street acts as a disincentive to travel due to the inability to get quickly between platforms. I suspect OOC will be similar, all about the retail offering and preventing ticket less travel at the expense of a seemless journey experience.Plymouth has a direct train to Manchester today (1153).
Some of us welcome the idea of a stop at OOC, quicker journeys are more welcome than slow tedious ones, high frequency services with decent interchanges is the way to go
Somewhat defeating your own argument there - if large numbers of passengers are going to be getting on and off, then surely the station is justified?Also, if such numbers are going to be using this station , id argue it will slow down GWR services by more than 5 minutes, with probably at least 4 or 5 minutes just to facilitate boarding on rolling stock with small end doors and people with large amounts of luggage. Add in the inevitable slow approach that is forced on GWR drivers, id say it'll be nearer 10 minutes slower to Paddington.
