It is a ticket that used to be called "Saver Half". It cannot be bought on it's own, you have to buy an Advance for travel in the opposite direction at the same time. It cannot be bought at stations.
Furthermore that is not an SVS. It is coded SVH so that was an incorrect code. Had you used the correct code many on here would be able to tell you instantly what the problem was.
