Wigan Disruption 20/8/25
M60lad
31 May 2011
Does anybody know the nature of the Signalling problem that is currently causing problems in/around Wigan Northwestern area at the moment? Looks like its going to be causing problems until 12:00 at the earliest so it must be something major that's happened.
I know earlier it was even affecting Chatt Moss services due to a service to Wigan being stuck at the siganl at Parkside Junction.
deepthought
29 Dec 2016
I don't know the details but problems started last night around 2245. The last London to Preston (1P09) was diverted from Warrington and travelled via Chat Moss to Manchester Piccadilly platform 13 where it reversed and then went via Bolton.
hexagon789
2 Sep 2016
Now 15:00 unfortunately:
Description​
A fault with the signalling system in the Wigan North Western / Warrington Bank Quay areas means some lines are blocked. Trains running through these station may be cancelled, delayed by up to 60 minutes, revised or diverted.
Major disruption is expected until 15:00.
Mcr Warrior
8 Jan 2009
Avanti actually been running some services on the Northern half of the WCML, between Glasgow Central and Preston, rather than binning everything off!
800001
24 Oct 2015
Because they have the Preston and Glasgow TMs available to run the service as they are lot affected by the disruption.
fgwrich
15 Apr 2009
Hampshire
Whatever it is has certainly meant a bad night for the Caley Sleeper passengers, with the lowlander arriving into Euston 109 minutes late, while the Highlander in both directions is still travelling.
Chester-Manchester services also affected, so the problems seem to start at Winwick Jn northbound.
But some trains are now running through - 9M50 has just reached Warrington and 9S44 has reached Euxton Jn.
1H83 (Llandudno-Man Airport) has also run through normally.
Rail Quest
8 Apr 2023
Warrington
When I was looking at RailCam track diagrams this morning, I noticed trains seemed to jump through several blocks in a go, jumping all the way from Wigan station to Golborne Jnc, then all the way to just north of Warrington. I'm assuming this sort of behavior indicates signal failures and temporary block working of some description?
aaronspence
9 Jun 2022
It looks like northbound trains are using the Up slowas I just saw 9S47 do the jump you described on Traksy
Halwynd
11 Sep 2021
North West
According to RTT and Traksy, 6M26 Wilton - Knowsley seems to have been stood on the curve at Lowton Jcn since around 04:40 this morning. It's normally a lengthy and I'm surprised it can fit on the curve without fouling either the Liverpool & Manchester or WCML.
Geeves
6 Jan 2009
Rochdale
The more severe issues always come later at Preston because if there's no train for the Glasgow crew to come down on then of course the return cannot set off north so it just sits at Preston.
800001
24 Oct 2015
I would imagine, the length of time this is going on, that the cause is cable theft?
pokemonsuper9
20 Dec 2022
Greater Manchester
The distance between the WCML and the Chat Moss line there is about a kilometre of track length
I don't know the usable length in regards to signals, but I think that's more than enough space.
800001
24 Oct 2015
15 seperate cables damaged reportedly.
The tweet below is from network rail, including 2 pictures of the cut and damaged cables
We apologise to passengers caught up in the disruption on the West Coast Mainline today
Unfortunately, signalling cables have been cut in several locations
This is criminal damage and the police are investigating
Bevan Price
22 Apr 2010
According to RTT, services at Liverpool Lime St have also been badly affected.
Mcr Warrior
8 Jan 2009
What are you seeing on RTT that gives that impression? From what I can see the only trains disrupted at Lime St are ones that would have gone to Wigan.
Or those trains continuing on to Blackpool North or maybe even Glasgow Central. Routed, of course, via Wigan North Western.
Efini92
14 Dec 2016
I think that’s just a data issue because of the signalling. There was nothing on the curve this morning.
BG2024
12 Oct 2024
None of the eastbound Chat Moss stoppers made it to Manchester this morning. The 0700 and 0802 to Manchester Airport were cancelled, and the 0728 to Victoria only made it as far as Earlestown (where it looks like a very long wait for an onward connection).
Northern had their usual level of passenger communications, i.e. worse than nothing at all. The 0700 was still being reported as expected to leave Lime Street on time right up until the moment it was due to depart, even though the inbound service was still stuck at Manchester Airport. For hours, all they were reporting was some small disruption at Euxton Balshaw Lane, and a few cancellations to services between Manchester and Blackpool.
M60lad
31 May 2011
1> According to Tracksy yesterday's 22:20 Blackpool North-Liverpool Lime Street 2C34 has been in Platform 1 at Wigan Northwestern and it's still there now, was this stopped at Wigan last night due to the Signalling Problems or some other reason?
2> Out of interest how does the Emergency Special Workings work that's been implemented at the moment for trains running through Wigan North Western?
Bevan Price
22 Apr 2010
I think I must have made some mistake with RTT earlier -- but several Trans Pennine services in the morning were cancelled.
Rail Quest
8 Apr 2023
Warrington
A fascinating video from Ben Elias shows him driving through this section during the disruption. In this, he explains the procedure in detail. Highly recommended.
Bow Fell
12 Feb 2020
Brilliant video, and nice to see it from the other side!
I hope this highlights, the absolute requirement for clear safety critical communication and why NR / TOC’s thin the service is such circumstances due to the length of time these things can take. The workload and pressure on the signaller is unimaginable and imagine having to go through this procedure without a reduced service! It’s not just talking past signals or the authorisation of emergency special working but imagine doing that and giving line blockages to the S&T and dealing with anything else on the panel at the same time!
