Why would a signal fail to clear?
Rana12345
29 Jan 2017
Why would a signal fail to clear (remain at danger) when setting a route and the route lights show up and the track circuits are clear?
Annetts key
13 Feb 2021
West is best
How long have you got? Depending on where it is, there could be dozens or more reasons. The route lights only tell you that the route locking should have been activated. There are far more controls in the signal control circuits.
LCC106
16 Nov 2011
Welcome to the forum. Can I ask, is this a question you have as part of your training? If so, why are your thoughts on the subject? If it’s general interest then I’m sure some members will be able to help. If it’s the former and you simply don’t know, it may be worth talking it through with your trainer. That’s what they’re there for.
ComUtoR
13 Dec 2013
Is the track circuit "occupied when clear" or "clear when occupied" ?
I've seen reports of both circumstances. Could there be a track circuit failure of some sort ?
( I'm not a signaller or S&T)
cin88
16 Oct 2015
WCML
If a track circuit is showing clear when occupied, the signal protecting it would be able to be cleared.
king_walnut
16 Oct 2013
I've never understood this attitude towards trainees asking questions on this forum. There is literally nothing wrong with helping a person learn.
Northampton
The issue is that the forum may give an incorrect answer in good faith, an answer that has since been superseded, or an answer that is correct for their company/work/area but not for the trainees.
Annetts key
13 Feb 2021
West is best
Track circuits actually detect the absence of trains (wagons, coaches, cars, locos, whatever). Hence with no train present, they “show clear”.
If a train is present (or indeed anything else that forms a short circuit/low resistance path between the two rails), then the track circuit will be “occupied” and it will show as red lights (or equivalent) in a power signal box/panel/signalling centre.
As they are designed to be as fail save as possible, 99.9999% of failures will cause the track circuit to show occupied.
If a track circuit is occupied, the interlocking will hold one (or more) signals at red to protect the affected section, as the interlocking has to treat it as if it’s a train.
Annetts key
13 Feb 2021
West is best
Can you supply any other information?
Is this a two aspect area, a three aspect area or a four aspect area?
Is this a plain/straight line, or are there points for a junction, loop, or sidings? If yes, what is the layout? What junction or route indicators does the signal have? Which route is being called?
Is there a level crossing involved?
Is there a banner for this signal? Or for the next signal?
Does this signal protect anything unusual? For example, some long tunnels may have an emergency system to put the ‘protecting’ signals to red.
Do you know which type of interlocking system controls the signal?
Islineclear3_1
24 Apr 2014
PTSO or platform depending on the weather
Is it an automatic signal or a controlled signal?
Is it on a mainline or loop/siding?
Has the signal bulb/filament "gone/blown"?
If you were the signaller, how would you know if a signal failed to clear?
Do you have a rulebook? Have you read it?
rower40
1 Jan 2008
Displaced Track Circuit Interrupter on a nearby trap point.
Mis-reading control to prevent signal clearing when a different train is approaching an adjacent red signal on the same gantry.
Back-to-Back control to prevent two trains departing the same platform in both directions.
Approaching train has already passed the "flashing aspect inhibit point" but has not yet reached the approach-control (MAR) point
Airport Trip Wire tripped.
Another speciality is this one: the route has failed to release behind the previous train, so it looks as though it has been set for this train, and the signal has stayed at red. Oft-times in ARS areas (when the signaller is not habitually requesting every route) this one occurs, and the signaller assumes that ARS set the route (because the signaller knows he/she did not), but the signal is still red.
I think the forum collective can come up with some even more obscure reasons than these. I look forward to reading them.
Did anyone mention lamp proving of the next signal?
In SSI-speak at least, these conditions are collectively known as aspect controls. 30 years ago now, I don't recall if approach control was part of aspect controls or had its own category.
carriageline
11 Jan 2012
Module failure
Junction indicator / theatre box lamp proving failure
A relay fault, if so equipped.
Bertone
5 Nov 2021
Hertfordshire
Yes me, in the third post in this thread yesterday.
Gloster
4 Sep 2020
Up the creek
I don’t think anyone has mentioned a fairly simple reason: the signalman forgot to clear the signal, thought s/he had cleared it but hadn’t or forgot to put it back on automatic after it was in manual, etc.(We’ve all done it, but I did it in the days when all you got was an angry driver saying, “Oi, bobby, when are you going to clear this fiddling signal?”)
liamf656
2 Aug 2020
Derby
Is that a fact?
If I were the trainee I’d take anything said in this forum as a suggestion rather than fact…
…for this reason.
