Here in NE Essex, I have two alternative routes to and from work.
One is via an unmanned, double gated crossing at Ardleigh, on the main London Norwich line. Even outside peak times, this busy crossing handles two up and down Norwich expresses, probably two or three freght trains to and from Felixstowe, and minimum two commuter trains. During the morning and evening commute, those numbers increase. But I am seldom delayed more than a two to three minutes - a train passes and barriers are raised even for a short time before warning signals cut in for the next one. (Sometimes the delay can be five minutes but thats an exception).
The other is at Thorrington, on the Colchester to Clacton and Walton branch. Typically, this handles four trains an hour - maybe six during peaktime. However, the delays at this crossing are much longer. There seems to be a genuine reluctance to raise the barriers if the next train is (say) less than ten minutes away. The net result is that people drive for miles around to avoid this bottleneck.
So my question is this: how does this system work? Are these level crossings controlled from the same control room? Why should the performance of one be so much worse than another? Can any action be suggested that I could take to try and get this service improved?
(The irony is that Thorrington until about 2000 was actually a manned level crossing, with a bloke who had to walk the single wide gate open and closed and the delays then were far less than they are today operating with the same timetable!)
