Harlequinuk
As title - its 9 miles, yet to get a train between the 2, you need to go into London then back out!
There never has been a connection between the two by rail.As title - its 9 miles, yet to get a train between the 2, you need to go into London then back out!
Luton was also served by the GNR, but from Hatfield, because even then traffic was London-oriented and Luton wasn't a significant destination demanding a connection from the North. SorryIn the distant past there was a line linking Bedford and Hitchin, built to provide the Midland Railway with a route to London via the GNR line to Kings Cross. But after the MR later built a line from Bedford direct to St. Pancras, it became a backwater and eventually closed to passengers in 1961.
I rode this line as a young lad of about 12. It crossed the Bedford to Bletchley line just east of Bedford St Johns on a 90 degree crossing. It also ran at the back of the first school I went to as a 5 year old. Happy Days.In the distant past there was a line linking Bedford and Hitchin, built to provide the Midland Railway with a route to London via the GNR line to Kings Cross. But after the MR later built a line from Bedford direct to St. Pancras, it became a backwater and eventually closed to passengers in 1961.
Wasn't the GNR line to Luton from Welwyn i.e. part of the Hertford, Luton and Dunstable Railway ?Luton was also served by the GNR, but from Hatfield, because even then traffic was London-oriented and Luton wasn't a significant destination demanding a connection from the North. Sorry![]()
Looking at a map it's a very hilly area with the airport being on top of one of these hills, so would be very expensive to construct.
The Bedford-Hitchin line includes a tunnel at Old Warden to get through the greensand ridge, similar to Ampthill tunnel on the MML.In the distant past there was a line linking Bedford and Hitchin, built to provide the Midland Railway with a route to London via the GNR line to Kings Cross. But after the MR later built a line from Bedford direct to St. Pancras, it became a backwater and eventually closed to passengers in 1961.
Yes, but the majority of trains on both branches continued to run to/from Hatfield.Wasn't the GNR line to Luton from Welwyn i.e. part of the Hertford, Luton and Dunstable Railway ?
And between the 100 and 101, there's a direct bus every 15 minutes, which is not bad at all!There never has been a connection between the two by rail.
However the 101 bus by Arriva does it in 30 mins flat.
If/when East West Rail opens it will be possible to do Cambridge-Luton with a change at Bedford.It doesn't show up on the inspiration for this topic – a journey from Cambridge to Luton
Behold! The train journey from Cambridge to Luton!
(Image of Google Maps with train journey from Cambridge to Luton mapped out via Kings Cross to take 1h30m)
However, depending on the timing of the connection, that may only be about 10 minutes faster than via London.If/when East West Rail opens it will be possible to do Cambridge-Luton with a change at Bedford.
No, because Welwyn is north of the junction from the GN main line and Welwyn Garden City didn’t exist when it was built. Therefore it was from Hatfield.Wasn't the GNR line to Luton from Welwyn i.e. part of the Hertford, Luton and Dunstable Railway ?
It strikes me as a rail bus link - shown on maps between Hitchin and Luton Airport and Luton given some marketing - it could be useful.And between the 100 and 101, there's a direct bus every 15 minutes, which is not bad at all!
It doesn't show up on the inspiration for this topic – a journey from Cambridge to Luton – because the railway station at Hitchin is about a 15 minute walk from the town centre bus stops, and there is only an hourly bus service to the station which has a generous 15 minute connection for trains coming from Cambridge, meaning that by the time you've made all the changes it works out slower than going via London.
But if you don't mind walking just under a mile through Hitchin then by changing to the bus you can make the journey up to about 20 minutes quicker than taking the train via London.
OK, thanks both - I stand corrected (and I didn't zoom into OpenRailwayMap quite enough to notice exactly where the junction was at Welwyn!)No, because Welwyn is north of the junction from the GN main line and Welwyn Garden City didn’t exist when it was built. Therefore it was from Hatfield.
Given that some LNER services stop at Stevenage in addition to TL & GN (including the Hertford Loop services), I suspect a direct Stevenage station to Luton Airport rail-bus link might be more useful/have higher usage, even though it's about 10 minutes longer driving time (versus Hitchin station to Luton Airport).It strikes me as a rail bus link - shown on maps between Hitchin and Luton Airport and Luton given some marketing - it could be useful.
Yes indeed - in the same way that the Railair bus to Heathrow is from Reading, rather than a nearer station.Given that some LNER services stop at Stevenage in addition to TL & GN (including the Hertford Loop services), I suspect a direct Stevenage station to Luton Airport rail-bus link might be more useful/have higher usage, even though it's about 10 minutes longer driving time (versus Hitchin station to Luton Airport).
Potentially, although I suspect it is a limited market – people in Hitchin will I'm sure know about the frequent bus to Luton and will use it any time they want to get to Luton, and without a dedicated new service running from Hitchin station (and therefore duplicating the existing Arriva service) I can't see it being marketable as a connection from Hitchin station.It strikes me as a rail bus link - shown on maps between Hitchin and Luton Airport and Luton given some marketing - it could be useful.
Have you looked at the map? The driving route between Stevenage and Luton is via Hitchin.OK, thanks both - I stand corrected (and I didn't zoom into OpenRailwayMap quite enough to notice exactly where the junction was at Welwyn!)
Yes of course I have (I've driven it a reasonable number of times too), it goes through the south and western edges of Hitchin, not via the centre of it or the railway station.Have you looked at the map? The driving route between Stevenage and Luton is via Hitchin.
Arlesey, reopened in 1988, is effectively the station for these.That route might now generate some local traffic with Henlow Camp and Shefford having seen much development since the line was closed
That's pretty much what the current bus service is, albeit going via Hitchin town centre. The airport extension is very lightly used.I suspect a direct Stevenage station to Luton Airport rail-bus link might be more useful/have higher usage,
The old station, closed in 1959, had various names during its life, including Arlesey and Shefford Road and Arlesey and Henlow.
