Why not control future-build EMUs from the rear cab?
fandroid
9 Nov 2014
Hampshire
Why not control future EMUs (& DMUs) from the rear cab? It would lower the risk for the driver in the event on hitting anything. The technology exists. Especially on DOO trains, the survival of the only staff member is extremely important for passenger safety in the event of a collision or derailment.
We have lineside signals and speed boards that need to be seen, and occasional physical obstructions that need to be spotted at brakes slammed on.
There are some urban lines that the cabs are not really needed, as trains operate automatically
How are they seeing everything? Via multiple screens and cameras?
stuu
2 Sep 2011
As in someone driving by watching it on a big screen rather than out the window?
If (big if) something like that were considered, the "cab" could go in the middle, no need for one at each end. And potentially not on the train at all
Western Lord
17 Mar 2014
As anybody who watched Gerry Anderson's UFO will know, driving a vehicle while facing backwards is no big deal!
Sorcerer
20 May 2022
While driving from the back may increase the driver's chances of survival in something such as a head-on collision or derailment, the chances of such an incident happening is so unlikely that I don't even consider it worth the hassle of redesigning a train and adding so much complex engineering, and if collisions or derailments start increasing, it will definitely not be down to the design of the train's cab layout.
MarkyT
20 May 2012
Torbay
You wouldn't get much sympathy from customers, the general public and media if the driver was seen to be hiding away at the back of a train because of the risk of collision to which everyone else onboard would be more exposed. Having a responsible staff member at the front of the train making key decisions even if not adjusting the controls very much between stations in this era of ATO is a big part of the psychology of safety, and there are things a set of eyeballs directly connected to a well-trained sentient brain can sometimes notice that machine systems and even the very best live video feeds to a remote operator would be hard pressed to catch, precisely because they're not very well defined: Early warning of livestock incursion or a tree that didn't actually cause a problem for the train concerned but might be leaning in a little closer than usual/comfortable for example; a group of youths messing about on a bridge; someone looking troubled at the lonely end of a fast line platform where no train is due to stop for ages, etc.
randyrippley
21 Feb 2016
I think you mean Captain Scarlet.
But he kept crashing the SPV whenever he drove one, it was a standing joke in the series
If you have a remote driving position surely it would be positioned near the middle of the train (or wherever is convenient) and you would forget about cabs at all.
This would obviously remove the need to change ends during reversals.
A0
19 Jan 2008
If you're going for remote control, why even bother having the driver on board ? Easier and safer to have them in a control room.
greyman42
14 Aug 2017
I recently watched a documentary on Nat Geo about a head on train crash at Paris. When the driver realised a crash was unavoidable, he left his cab and got everyone to the back of the train before the collision. Everyone on that train survived.
Fincra5
6 Jun 2009
Not sure if this is a serious post or not...
D7666
12 Aug 2013
FWIW the tender ITT went out for what is now Class 700 did specify ability to drive from rear cab using cctv when necessary. this feature was dropped from the actual tender and 700s can not do it. Like it or not, it IS a serious idea
D365
29 Jun 2012
I’d be surprised if full line speed would have been permissible. Although, saying that, I’m not sure if there is a speed limit on the auxiliary ’shunting’ desk fitted to Class 90s.
Northampton
Personally, I think having the ability to conduct low speed shunts from a remote cab via CCTV would be perfectly sensible and help operational flexibility. The train isn't going fast, it's in an area that is comparatively better secured than the lineside and with 240m trains it's potentially a reasonable time saver that could even avoid the need for some crossovers, a big money saver.
In terms of regular service driving, no thanks.
MarkyT
20 May 2012
Torbay
Saving a cab change for a shunt would be very useful, especially for shuffling units around depots and servicing yards. Driving from the wrong cab was routine for such purposes but seems to have fallen out of favour in the UK, although, like locos propelling, there are ways to do it safely using a second staff member at the forward end in constant radio contact with the driver, ideally with access to a brake handle for emergencies. CCTV at the leading end might avoid the additional employee. Portable control units might also be used in depots, as in some freight shunting operations. When coupling up or precisely positioning for a depot task, controlling the movement from the trackside might be more effective than from any cab.
