Ash Bridge
Class 66 has a control stand. It is different from traditional UK designs in that there is no separate 'key' to unlock the control desk. Traditional UK locos (ie those built by BR) use the drivers key (small t-shaped thing) to unlock the controls. Once the desk is unlocked, the controls (reverser and power controller) can be operated.
On a 66, the 'key' is actually a rather large lump of brass (later ones are plastic) that doubles as the reverser. It has a crude key shape at one end and a handle type grip at the other. You have to insert it into a slot which then unlocks the controls. The key, inserted into its slot now doubles as the reverser and, when changing ends, has to be removed and taken from cab to cab.
The controller is indeed 'pure Emd'. On traditional UK locos, you pull the controller to reach full power, but on a 66 you push it. I believe this is to do with having to switch from right hand drive to left hand drive. The signage on the controller stand is decidedly trans-atlantic as well!
With reference to the class 58 desk, the layout of the dials, gauges and brake controls is indeed a generic layout first seen on the 58. The layout is standard across 58/59/60/66.
Many thanks for confirming this and all the additional info
