Why isn't Oyster rolled out nationwide?
class303
5 Sep 2011
With Glasgow's "Bramble" :roll: card on the horizon it just got me thinking. Why don't they just install oyster to the Glasgow subway and even suburban rail services? I assume the barriers installed at Glasgow Central and elsewhere are compatible?
Is there any need for an entirely different smart-card system?
While I appreciate oyster is funded by TFL or whoever i don't see why SPT (or whoever) can't just contribute to it in order to use the system? Not just Glasgow, but all major cities? Oyster works so well i think it's a shame not to roll it out further and see no reason why it needs to be confined to London.
Roll it out in the big cities and surely it's progress towards a national smart-card network? To have to have a different card and balance for every city I wish to visit seems a pain to me.
traji00
17 Aug 2009
I believe that may be the (eventual) intention with ITSO cards - even Oyster is being updated to be compatible. AFAIK the way in which Oyster works is way too complex :/
But I'm sure someone would be able to explain better than me.
Mcr Warrior
8 Jan 2009
:roll: Presumably, you couldn't have a "touch in, touch out" ticket across the national network, could you, just pre-loaded tickets? (Otherwise, how much would the maximum charge be for failing to touch out properly?)
quarella
7 Dec 2009
There you have hit the crux of the matter. In any shared revenue operation there will be disputes funding of the equipment to start with and then receiving a fare share of the income.
wibble
23 Jun 2010
I don't think Oyster will be around much in the next 5 years - I reckon it'll be superceded by contactless payment cards, ITSO smartcards and NFC.
bicbasher
14 May 2010
I wouldn't write off Oyster just yet. TfL Discounted travel will still require Oyster (and possibly ITSO) while Contactless won't be still as widespread as standard Chip and Pin.
class303
5 Sep 2011
I just mean in the big cities for metro style journeys on National rail, like we currently see in London.
p123
1 Oct 2011
Hahaha, I got the Bramble thing put in my Zonecard a few weeks ago. Tried it at Queen St and Central, and the gates just shout at me until I put the old paper Zonecard into them!
ChathillMan
13 Sep 2010
Its is one of those things which sounds good until you think about how it would be implemented.
The cost of setting it up would be astronomical with each possible fare and route needing its own digital encryption.
Then the actual usage if it. Season tickets and single/return fares would be relatively easy to programme for smartcards. Pay as you go on the entire rail network? I am getting a headache just thinking about it
Deerfold
26 Nov 2009
That would be confusing for passengers - you can use it for local journeys in London, and local journeys in, say, Birmingham, but not journeys between the two...
Oyster also has a limit to the number of Zones it can handle - and the current London system uses a lot of them.
Chrisgr31
2 Aug 2011
Isn't Oyster effectively a first generation ITSO smartcard?
Deerfold
26 Nov 2009
Oyster predated the initial ITSO specifications (which is why it's quicker for a start...).
Subsequently the readers have been updated to be ITSO-compatible.
Freedom passes are both ITSO and Oyster (since 2010).
jon0844
1 Feb 2009
I wasn't serious anyway! It couldn't work for a PAYG system nationwide but I expect it could for travel on other metro/tram/bus services and you'd load tickets on for longer journeys.
Obviously wouldn't be Oyster but hopefully a national smartcard usable on ALL transport.
Deerfold
26 Nov 2009
The Danish National Smartcard (if you get the unregistered version) has to be told if you're taking a long distance journey (and you're treated as having an invalid ticket if you don't). It will then deduct 700DKK (about £80) on entry to the system and refund however much when you touch out.
34D
9 Feb 2011
Oyster is actually a very basic, 20th century technology.
ITSO can function (eventually) as a national smartcard, though don't expect to see a national PAYG product.
