What is the current fastest train?
‘Current’ isn’t a good guide
Tends to be around the 54 minute mark Victoria to Leeds, 56 from Picc.
On diesel, with 2 stops. I thought a clean run with 1stop is sub 50? And with electric around 44?
A clean run with 2 stops is 50 mins - see for example the new 0900 Victoria-Scarborough seaside express which starts in a month's time. 2 mins more to/from Piccadilly.On diesel, with 2 stops. I thought a clean run with 1stop is sub 50? And with electric around 44?
Indeed - the via Manchester time is still 10 minutes faster than the York-King's Cross stopper.Whilst it might be slower than the current fastest time to York, many more paths would be available on the HS2 routing - since all the trains to Manchester can be extended through Leeds and beyond.
So generalised journey time may be fairly competitive, irrespective of any additional upgrades elsewhere.
The Birmingham-Crewe section is planned to take 11tph with the Eastern branch. I assume capacity is theoretically 18tph so a couple of extra train paths to Manchester wouldn't be a huge problemIsn't the Birmingham - Crewe section going to be choked? Ideally you'd want Birmingham services going North to serve Scotland (via Preston), Liverpool and Manchester. But with only three tph coming off the southern section of HS2 at serve Birmingham, there won't be the slots.
Also the Manchester spur is going to be well over capacity if it is to take NPR traffic as well as Birmingham/London - Yorkshire/NE traffic.
So in France, they have been developing plans for expansion of their high speed rail network for decades. Route corridors can be decided well in advance of construction, giving plenty of time to do due diligence (e.g. ground conditions).
Those are really peripheral routes though. They had a clear plan for the core network and stuck to it.Except they have changed their mind several times in France. Which way out of Bordeaux to the Spanish Border? Link to Limoges? The PACA line? It’s only a few years ago the whole programme was canned.
Current plans (if they can be called plans!) are that NPR train will reverse at Piccadilly.I assumed that NPR would be in a tunnel under Picc and turn Eastwards sharply after leaving. I don't know what the current plans are but a reversal would be less than ideal.
Though as regular readers of the NPR thread will know, local bodies want a partly underground station allowing through trains.Current plans (if they can be called plans!) are that NPR train will reverse at Piccadilly.
Which would delay NPR, and HS2 into Manchester, by at least a decade and increase the cost by, probably, tens of billions.Though as regular readers of the NPR thread will know, local bodies want a partly underground station allowing through trains.
Until 2018 it was 48 min twice an hour between Manchester Piccadilly and Leeds.Tends to be around the 54 minute mark Victoria to Leeds, 56 from Picc.
However, in this special investigation, Byline Times can reveal more claims about what unfolded in HS2 from November 2015 to April 2016, as the scheme progressed through Parliament. According to its former head of property planning and performance Andrew Bruce, this period was marked a conscious suppression of reality and a contortion of the truth designed to secure parliamentary approval for the controversial rail scheme.
Unpopular view on here but I fear HS2 is getting beyond elephant proportions and quickly turning into Moby Dick.
Cost and timescale spring to mind.On what grounds?
And it doesn't help when at every step of the way somebody is calling for another costly review or yet another public inquiry. Both of which take yet more time.Cost and timescale spring to mind.
There's a serious issue in this country about getting stuff done when it comes to infrastructure.
There is also too many people with their grubby fingers in the pie.
I think connectivity between northern cities and down to Birmingham is probably the higher priority. It's risky to just lump "northern city leaders" together though - they have very different and often competing requirements. If I was leading Leeds and West Yorkshire for example I might not be all that bothered about getting to Manchester, and in fact I might regard it as most important that Manchester doesn't get HS2 before Leeds or instead of Leeds.Surely most Northerners and Northern city leaders are more interested in improving connectivity between Northern cities than they necessarily are in getting to London?
Birmingham- East Midlands- Yorkshire currently takes longer than getting to London does due to inadequate infrastructure in several places, notably Sheffield and Leeds. We're in 2021 so why are we still constrained by 1921 type infrastructure?
Exactly; London is 200 miles from Liverpool and just over 2 hours away, any other city less than 100 miles away not on the WCML takes at least the same time, but sometimes longer!
