Why do pendolinos tilt?
CallySleeper
27 Jun 2006
trentbartonland
In order to answer the above question, I'm not looking for an explanation into the actual mechanism within the train - I want to know about the actual physics behind it (in not too much depth please!) Does tilting round bends allow an object to travel faster? Or does travelling round a bend at speed cause an object to lean into it? (So, not just specifically limited to trains)
When (!!) i'm out running, at high speed I have a tendency to lean into bends. Is this natural? Or am I just trying to mimic a train?
455driver
10 May 2010
To reduce the sensation of the passengers on the train of being pushed towards the outside of the corner.
A train can go around a corner much much faster than they do, the limiting factor is passenger comfort, if you have ever been in a car being driven aggresively round corners you will know how uncomfortable it is as you are pushed from side to side towards the outside of each bend.
kevinwaltets
11 Apr 2012
Never mind the passengers, the limiting factor must be the stress placed on the outside rail.
Now I read about cant deficiency years ago (APT) but does a tilting train place less stress on the track. I doubt it does because the mass and thus forces should be the same.
So this is where passenger comfort comes in as 455driver says but that's not the limiting factor.
455driver
10 May 2010
A (lightish) passenger train at 125mph wont be putting any more force into that outer rail than a heavy freight at 75!
OxtedL
Quizmaster
23 Mar 2011
You can make this as complicated as you like, but here is a simplified explanation of what is going on, forces wise. Hopefully I haven't made any mistakes - I'm sure I'll be corrected if wrong.
Diagram 1:
To get a train to go round a curve you need a centripetal force pulling it towards the 'centre' of the curve. The is applied to the train by the track. However to the people on the train, it feels like a force is being applied in the opposite direction - a centrifugal force. [This is a 'fictional' force, to those who enjoy such concepts.]
There are now three important forces we wish to consider acting on the people in the train:
  1. The aforementioned centrifugal force
  2. Gravity, i.e. their weight
  3. Normal Reaction Force
The normal reaction force is applied by surfaces in the train that you are in contact with (eg floor, seats) - this is them resisting your weight pushing down on them. If this force didn't exist or wasn't strong enough you'd push straight through them. Importantly, the normal reaction force acts perpendicularly to a surface.
Diagram 2 (complete with wonderful stylised people):
When we add these three forces together, as you can see in the left diagram, we get a resultant force (in red). To avoid you flying around the train you need other forces to cancel them out - typically friction between yourself and the surfaces you are in contact with. However, this needs communicating to the rest of your body, so you have to brace yourself. You will have noticed this in a car.
If we can make this red resultant force smaller, less bracing is required and everyone is more comfortable.
Fortunately we have a trick up our sleeves - if we tilt the person and the surfaces they are in contact with, the normal reaction is still mainly* responsible for balancing your weight, but is now at an angle. (*mainly - as long as you're not tilting too far and you don't care that much about finer detail.) This means that it also partially cancels out the centrifugal force, so the red resultant is smaller, so you have to brace less and are more comfortable.
I hope that roughly explains what's going on. I'm aware that I have cheated in my balancing of forces a bit here, but I hope it communicates the essence of what's going on.
A tilting train puts more stress on the track than a non-tilting train of the same weight. But the track is able to cope with this - perhaps with an increase in rate of rail wear and need for more frequent rail grinding. Ultimately there is a risk of overturning if the cant deficiency gets too great. However, like 455driver I have always understood that passenger comfort is the limiting factor on curving speeds.
DaveNewcastle
21 Dec 2007
Newcastle (unless I'm out)
Animals lean into a curve when running, and so do cyclists (pedal cyclists and motorcyclists). It's an intuitive response in order to maintain balance.
I used to know a man who drove a Land Rover with his alsation dog on the front passenger seat. I enjoyed watching them drive round the bend towards me, as both driver and dog would lean into the bend by the same angle and at the same time, and then both straighten up again simultaneously.
CallySleeper
27 Jun 2006
trentbartonland
Thanks everyone. See when you're tilting, are you trying to use shifted centre of gravity to balance out centrifugal force on the other side?
The reason for this (I think) is that the axle weight is heavier on 390s and also 221s because of the additional tilt mechanism which you wouldn't find on say, 220s.
DownSouth
10 Dec 2011
Shifted centre of gravity is correct, but there's no such thing as centrifugal force.
For any object to move in a curved path requires centripetal force to pull it towards the centre of the curve. This force could be friction (cornering a car or a bike on a flat road), aerodynamic forces (e.g. a plane turning), a Normal Force (one object pushing against another, e.g. the outside rail of a flat curved track pushing a train inwards) or even gravity (holding you on the surface of the rotating earth instead of flying off into space on a straight line). Without something providing the centripetal force, an object cannot travel in a curved path and it will instead keep moving in a straight line according to Newton's first law (inertia).
The centripetal force (F, in newtons) experienced by an object in a curved path at any instant is equal to the object's mass (m, kilograms) multiplied by the square of the object's velocity (v^2, v is in metres/second) divided by the radius of the curve at that moment (r, in metres) which looks like this:
Where the concept of tilting a vehicle comes in handy is for using something other than friction to provide the centripetal force instead of friction - we could use something else (e.g. a great big electromagnet, or rocket thrusters on the outside of a car/train) but gravity is far more convenient for working with land vehicles. When an object is resting on a tilted surface, gravity acts on it and pulls it towards the "inside" of the tilt.
What this allows is for the surface on which a vehicle travels to be tilted inwards, so that some (or even all) of the centripetal force is provided by gravity pulling the vehicle down the tilt towards the centre of the curve instead of friction. This is called a banking angle but is commonly referred to as camber on a road curve, and on a rail line as superelevation (the difference in height between the inside rail and outside rail, rather than as an angle) or commonly by the non-technical term of cant. Just by knowing the speed at which the cornering will take place and the radius of the curve, there's a simple formula to work out the "ideal" banking angle which would have the gravitational pull down the tilt providing exactly the right amount of centripetal force:
On an outdoor velodrome with progressive bankings, most people should be able to ride a bike fast enough that they can ride in a straight line around the turns with the bankings doing all the cornering work. If you're reasonably fit you should be able to ride faster than the ideal speed for the banking at the bottom and therefore need to counter-steer to lean the bike or move up towards the outside where the banking is higher.
Specifically talking about rail (and equivalents for road in brackets), you can't actually have the superelevation (camber) set at the "ideal" banking angle in 99% of cases because the majority of curves are used at a wide variety of speeds - the ideal banking angle for a slow freight train (Morris 1100) will be very different to the ideal banking angle for a fast passenger train (Ferrari 599). Setting it to the ideal angle for the passenger/Ferrari would have the freight train scraping along the inside rail and the Morris driver having to steer "up" towards the outside of the curve, while setting it to the ideal angle for the freight/Morris would have the passenger train pushing up against the outside rail and the Ferrari driver steering into the corner using the grip of the tyres to provide the centripetal force.
This is where the concept of cant deficiency comes in, for resolving the compromise on a mixed traffic rail line. CD is the difference between the superelevation which would provide the ideal banking angle for the selected speed and the actual superelevation of the track - and is expressed in terms of height. When a train runs at a speed where the cant deficiency is greater than zero (i.e. a higher speed than the ideal speed for the banking angle) the banking angle is not sufficient to provide all the centripetal force and the remainder will be provided by the contact with the outer rail. Somewhere between 120-150mm is usually regarded as the top end of CD for a conventional (i.e. no tilting body) passenger train, if the CD is higher than that the amount of lateral force experienced by the passengers will be too high to be comfortable and they would be seen gripping their armrests and losing objects sideways off the table.
The principle behind providing a tilting body train (e.g. a Pendolino, ICE-T, Acela, Hitachi's QR Tilt Train, or Talgo) is that it takes the same principle of using a banking angle to lessen the amount of centripetal force provided by friction and applies this to the friction between the seat and the passenger as well as to the rail/train interface. These trains can run at speeds set for a CD higher than that which would be comfortable on a conventional (up to 300mm in Europe) with the tilting body providing an "extra" banking angle to make up the difference between the track's superelevation and the higher banking angle which would be comfortable for passengers at that speed.
There is such a thing as too much tilt though. If a train is cornering with the banking angle of the passenger accommodation at exactly the ideal banking angle for the curve (whether just by the track's superelevation or a combination of that plus a tilting body) then there will be no lateral force and therefore no sensation of cornering - and passengers have a high chance of getting motion sickness if they get the visual sensation of cornering without the physical sensation. An infamous case of this was on the publicity runs for BR's APT project where the amount of tilt was so high this did become a problem - BR showed a great example of the traditional customer service ethic of a public railway (i.e. none at all) and publicly blamed it on the journalists being drunk, but then confirmed the journalists were actually correct by their subsequent actions (they reduced the amount that the APT bodies would tilt).
For some people who have become very accustomed to the cornering of a particular type of conventional train, the first time using a tilting body train could possibly see a minor degree of the same experience, but nowhere near as bad since that lesson was learned by BR. The same people may experience the same thing on even a new conventional train with different ride characteristics though.
Axle load would be a small component of it, but the majority of the increased wear (mainly the outside rail) would be due to the speed being above the speed for which the track was optimised, and further above it than a conventional passenger train - remember that the centripetal force is proportional to the square of the object's velocity. In the broader scheme of things though, a UK-spec Pendolino is still a lightweight train compared to the medium-weight "heavy" freight in Britain and genuine heavy freight elsewhere, and only 11 cars long as well.
It's easy to see why this is perceived as a price worth paying though - nowhere else makes such a huge song and dance is about the most minor of journey time improvements as Britain, and nowhere else would consider skipping a major interchange station to save a minute or two to be remotely acceptable as some were talking about on the Crossrail to Reading thread.
The increased wear would be primarily due to the increased speeds. Active tilt systems (i.e. not Talgo-style passive tilt) do transfer a little bit of weight to the inside rail which has a minor mitigating effect on the wear of the outside rail, which a conventional passenger train does not.
Excessive wear and tear on mechanical components and the track would also kick in as limiting factors before the risk of overturning.
Yep, it's just a simple fact that comes from the physics of the situation - shoes and tyres are not equipped to pull you into a corner, they push you into it. Try to stay upright or leant the other way and you'll end up on the deck.
If you were to run up towards a vertical pole and grab onto it with one hand to swing yourself around it you wouldn't lean inwards though, there's simply no need to when something else other than friction is providing the centripetal force.
If you regularly use a proper car seat which hugs the body and keeps it in position, the instinct to lean disappears pretty quickly.
Peter Mugridge
8 Apr 2010
Epsom
Class 220 DMS: 51.1 tonnes.
Class 221 DMS: 58.5 tonnes.
Class 220 MS: 45.9 to 46.7 tonnes.
Class 221 MS: 54.1 to 55.9 tonnes.
As for passenger comfort - it's far more enjoyable on a TGV doing 135mph on the classic track below Poitiers to Bordeaux than it is on a 390 tilting at 125mph on the WCML.
CallySleeper
27 Jun 2006
trentbartonland
Thanks for this, I managed to follow it. To rephrase my question then, the point of a runner tilting into a bend (on a flat track) is to produce a centripetal force which allows them to take the bend quicker?
I assume this same physics could be applied to other moving objects such as bikes on flat surfaces where you don't have a banking angle.
455driver
10 May 2010
A moving object wants to go in a straight line, the centripetal force is a way of forcing it to go around a corner, a cyclist will lean towards the inside (setting up the centripital force) so will effectively be falling in that direction, by then turning the steering that way to balance the fall causes Newtons 3rd law to comes into play and that opposite force we feel is the centrifugal 'force' which is just caused by physics dictating that we should always go in a straight line.
Not bad for a train driver! ;)
Minilad
26 Feb 2011
Anywhere B link goes
Google is a wonderful thing ;):lol:
455driver
10 May 2010
Nope, all in my head, the only thing I couldnrt remember was the spelling of centripical, I always want to spell it centripetal.
next time somebody asks a question maybe we should just tell them to use google if its that good! :roll:
Class172
Quizmaster
20 Mar 2011
West Country
I'm just currently finding this thread interesting reading as it is full of mechanics. :)
DaveNewcastle
21 Dec 2007
It can't be - most of the world's creations and knowledge haven't even been digitised. It's painful to watch how much fundamental knowledge people seek on the web - in vain.
I have similar doubts about some spellings, but don't call me petal.
DownSouth
10 Dec 2011
Yes, but it's more complicated than that.
What is basically happening is that the muscular movement and friction between a runner's feet and the surface is enough to make the feet go around the corner without a problem, but the rest of the body needs some other force acting as a centripetal force to have it keep up with the feet - and this is often gravity (via leaning in) but also could be partially from a crosswind.
The reason that a car or a train can corner on a flat surface (trains can do slow corners on flat tracks) is that they passively 'lean' into a corner. The suspension of a car allows it to transfer the weight to the outside wheels so that the car is partially operating as a two wheeled vehicle, riding mainly on the outside wheels and effectively leaning into the corner because the centre of mass is all to the inside of those wheels (i.e. on the centreline of the car).
It's a balancing act though. If the suspension is set up to dampen out too much of the body roll and keep the car flat, there will be less weight transfer to the outside tyres, and therefore less grip and the car will wash out at a lower speed. If it's set too soft there will be too much body roll and the potential for the car to corner inefficiently with extra tyre wear on one side only.
Assuming the road or track is flat, the car or (non-tilting) train doesn't lean into a corner - if anything it leans outwards. Because it has a wide wheelbase it can do that, up to a certain limit, without overturning. If the speed is high enough the inner wheels will lift off the road/track.
A runner or a (motor)cycle can't do that because its "wheelbase" is narrow so unless they lean into the curve they will topple outwards.
Banking the road or track (known as superelevation or cant in railway terms) means that the train, bike, car, or whatever is still roughly perpendicular to the surface even when curving. At the equilibrium speed for the banking, there is no net lateral force and in the case of the car or train the wheels either side share the weight equally.
DownSouth
10 Dec 2011
Read for comprehension buddy.
A car effectively leans in with respect to it partially operating as a two wheeled vehicle resting on the outside wheels thanks to the centre of mass being to the inside of the two vehicles taking the bulk of the weight. The orientation of the body with respect to the road surface is a completely separate issue to this fact.
If it's resting on the outside wheels it's leaning outwards. Sorry if I don't comprehend your posts, I only got A level physics and a degree in engineering.
PaxVobiscum
4 Feb 2012
Now that's a shame - I was enjoying this discussion and it was going so well (so interesting and informative) and the great bonus was that on this thread, unlike certain others, none of the participants had felt the need up to now to mention qualifications, either actual or aspirational. :D
I suspect that you may both be correct and merely explaining matters from a different viewpoint, but please don't fall out over it.
