It looks to me like the issue is likely to be that the windows are slightly set back from the body sides rather than being flush or protruding slightly. That makes them more difficult to keep clean.Can anyone explain why GWR 80x consistantly have such filthy windows? I assume it's an issue with the carriage washers but it seems to be have been the case for as long as I've been using them. Can it not be resolved?
I wouldn't say it's a design flaw. It's just the design that Hitachi uses. Look at the various incarnations of bullet train - slightly recessed windows and door pockets.Sadly they are. From my point of view, along with the recessed door pockets, they are another design flaw in Hitachi’s High Speed design - both door pockets and window recessed have since become dirt traps.
Another drawback with that design is that, to replace a window, they have to be replaced from the inside as well. While the Mk3s weren’t immune from getting dirty edges and corners, they aren’t as bad as the IETs.
If part of the problem is soot or oil from the engines (which other dirt would stick to as well), then the 80x are likely to be worse than HSTs because they have multiple exhaust stacks which are closer to the coach windows. If so, the West Country sets are likely to be worse than South Wales ones, since they spend more time running on diesel.
Agreed - I don't think it's a particular issue (noting the odd exception as you do with any fleet). More often that note it's noticeable just how clean the train is - especially when you consider some sets are coming up to the 5 year mark.I haven't experienced this problem when using these to Paddington and back twice this week. Indeed compared with other operators' trains that run to Worcester GWR 800s are immaculate.
