Why are XC allowed to continue?
JJmoogle
11 Jun 2012
I just struggle to see how a Voyager can be wasting more space than an equal length train that needs power packs (and those aren’t the only non-passenger lengths on Flirts), unless the Voyager was built to stricter crumple lengths for 125mph.
If it’s comparing 2x5 v 1x10 (equivalent) then that’s a different story (which I don’t believe would get funded as it presumably means buying more 10s than half the number of 5s voyagers)
your x12 Flirt is also 10m longer, biasing the stats a bit. Would that fit all the way to the ends of XC?
Having used a 221 and a 745 on the same day the difference is quite clear, you can see it.
The every toilet is an accessible toilet and the then standards of crumple zone design leading to massive vestibules on a voyager is part of it,
I assume there's some more space 'lost' by putting tilt mechanisms(or the space for them) underneath means more equipment is needed upstairs, along with the two to three decades more of experience in multiple unit design and technological advancements making components smaller.
Meerkat
14 Jul 2018
But a 745 would need power packs - are they really shorter than the difference in crumple zones (assuming the accessible toilets issue is fixable in refurb)?
Energy
29 Dec 2018
They can't be. They are structural to the train, if they could be easily removed they would have been years ago. That train section is luggage storage or the shop on Avanti in non toilet vehicles.
JJmoogle
11 Jun 2012
The powerpack vehicles are really rather short so I'm going to say yes.
Richard Scott
International Transport
Railtours & Preservation
13 Dec 2018
To be honest, the powerpack is irrelevant, it's part of the train and just makes the train longer (it's more like a loco but shorter and also has advantage of removing underfloor engine noise); it doesn't use up passenger space like a cab, which is part of the structure. Considering years ago cross country trains were often load 13 plus a loco, train length is irrelevant, it's how it's used that's important and 2 Voyagers together waste an awful lot of passenger space. If you look at capacity of 2x5 car 800s compared to a 9 car, the 9 car wins by quite a margin, I believe.
Krokodil
23 Jan 2023
Wales
If we assume that two powerpacks are required, then the space they occupy is not much more than the dead area between two Voyagers.
How else do FLIRTs save space?
- One vestibule per 15m vehicle instead of two per 23m vehicle
- articulated bogies so the vehicles are closer coupled, though the flip side is that the vehicles are shorter so there are more joints than with long vehicles.
- fewer UATs and fewer toilets in general. Probably not enough for a longer distance operation, but you don't need the ratios that the Voyagers are equipped with.
As they have fewer bogies and would reduce diesel engine hours by a decent margin, they'd be cheaper to operate.
Meerkat
14 Jul 2018
So the main advantage to your plan is changing to long units, which is expensive and unlikely IMO, rather than Flirts themselves.
Never been on one so a couple of questions re suitability for XC…
How quiet are the connections over the bogies - AIUI they are effectively in the middle of the saloon between vestibules in the middle of the adjoining vehicles?
I assume a trolley can get through the power unit if a person can, despite them being narrow?
Trainbike46
18 Sep 2021
belfast
I'll answer your questions from my personal experience, others may see things differently
The advantages of the FLIRT are in the level boarding (which, in my view, should be a requirement for all new rolling stock orders), the fact that they are relatively easily changed to other power modes, and
From a seats perspective, the voyagers are bad in a way that cannot be changed (look at comparing the seating density of a 5-car voyager with a 5-car 80x!) - so the advantages wouldn't solely be in it being a longer unit, but also in it being a better unit. This wouldn't only be possible with a FLIRT, but apparently Hitachi has massively increased charges for new 80x units, making that option less likely
You should try them sometime! they are very good units.
FLIRTS are much quieter than most other diesel trains I have been on, and also quieter than many EMUs, despite the connections between cars being effectively in the saloon yes
I think they can get through, yes
dk1
2 Oct 2009
East Anglia
I can assure you all that the catering trolley can easily pass through the power-packs on class 755 units and happens several times a day on the triple traction diagrams between Norwich & Liverpool St. Vestibule areas are quiet as quiet can be.
13 Jan 2024
Cambridge
The only times when I thought a 755 was loud was when the doors to the power pack were stuck open and I was sitting right by it (happened a few times)
dk1
2 Oct 2009
East Anglia
Some software updates caused that to be the default setting and can be very easily overridden by the driver.
sleepy_hollow
9 Jan 2018
Density can’t go much higher, even with new seats. The big issues are the accessible toilets, the crumple zones and the wasted cabs. Densifying would also make the Voyager experience even more unpleasant.
In essence XC is currently operated by fast, reliable diesel trains and more of the type are probably becoming available, for all their wasted space. The railway will remain diesel operated for the foreseeable future so the real medium term questions seem to be:
1. How soon can more Voyagers transferred to XC?
2. How much of the line can be raised to 125 mph, and how much will be worth it? For example the speed limit past Charfield Meadow appears to be 100 mph. Is raising the limit from Bristol Parkway/Yate to Cheltenham/Gloucester and thence to Bromsgrove/Birmingham to 125 mph possible, and is it worth it?
Senex
1 Apr 2014
York
In essence XC is currently operated by fast, reliable diesel trains and more of the type are probably becoming available, for all there wasted space. The railway will remain diesel operated for the foreseeable future so the real medium term questions seem to be:
Wasn't 125 where possible between Birmingham and Taunton part of the originally-conceived Operation Princess infrastructure package? (But unlike Birmingham–Sheffield, Wolverhampton–Stafford, Oxford–Banbury (for tilt), tht bit and several other never got started—and then came the Railtrack collapse.)
virgintrain1
29 Jul 2011
It was!
Struggled enough to get Bromsgrove Westerleigh to what it is now. Level crossings still causing the problems.
Mamorin
21 Sep 2020
Cheshire
I do hope this happens, as I feel Congleton would be better served by a regional operator. Only issue for locals would be the possible loss of a service to Kidsgrove.
Pre-pandemic a 2nd hourly service at Congleton post HS2 would have been an idea worth looking at imo, but now 1 service per hour will do.
Mark J
12 May 2018
The 11:14 from Reading to Wolverhampton (why not Manc Piccadilly?) is surprisingly a double formation. Both sets have full and busy carriages and no one standing in aisles and vestibules for once!
Why can't XC be like this more often. For once has been a pleasurable journey.
Edit: The train was a 4+4 formation.
26 Jun 2019
On weekdays there are two double voyager diagrams on the Bournemouth to Manchester service. Assume it’s similar on Sundays too.
As you say would be great if it was more often but with the introduction of the York/Newcastle services, which are a complete lottery as to whether they run or not, most services are a 4/5 car.
anthony263
19 Aug 2008
South Wales
I caught the 1253 from Totnes to Glasgow yesterday as far as Bristol Parkway formed of 220020/220023 . Train was pretty busy at Totnes but still plenty of seats on board. However after Exeter St David's seats seemed very hard to come by.
I definitely think Cross-country need 2tph between Exeter and Birmingham at least with double units.
Got to say the seat I sat in on coach Cof 220020 yesterday was pretty comfy a d legroomwas good until I got squashed in after train departed Exeter.
Grecian 1998
27 Oct 2019
Bristol
It's common on trains formed of double Voyagers running north from Plymouth to Bristol for the rear unit to be rammed and the front unit to be fairly quiet. The platform entrances at the two busiest stations, Plymouth platform 7/8 (usually) and Exeter St Davids platform 5, are adjacent to the rear of northbound trains. Most people don't move down and just pile onto the rear set. Towards the front of the leading set is usually much quieter.
The same phenomena happens in reverse at Temple Meads. If southbound services are leaving platforms 10 or 12, it usually pays to walk down to the end of the platform as the front set will usually be quieter after the churn of passengers finishes. If leaving from platform 8 conversely, as this is much shorter it's a better idea to go to the rear of the train. On one service I caught recently, the front set didn't appear to have any double sets free. I walked down to the last standard class carriage in the rear set and there were 3 people in it.
I also usually aim for any of B, F, H or L as the fully unreserved carriages (although of course B and H may not exist). As RTT usually gives an accurate indication of XC's train lengths, it's been a while since I had an unpleasant journey on XC. It does admittedly help that I usually have the flexibility to pick a double set, mainly travel at weekends and rarely have any heavy luggage, so I cheerfully admit my experiences probably aren't typical.
Mitchell Hurd
28 Oct 2017
I'd love to know why CrossCountry think replacing 445-seat HST's with 400-seat (8-car) Voyagers is fine when 9-car workings would be better.
Northampton
Do Crosscountry actually think it's fine or do they just not have enough 5-car sets to go around? (Genuine question)
Richard Scott
13 Dec 2018
With the advantage of the HST that you can access the whole train. I wouldn't mind betting the HST uses less fuel and assume lower staffing costs?
Trainbike46
18 Sep 2021
belfast
AIUI, removing the HSTs without direct replacement wasn't XC's idea, it was ordered from the DfT
Things should get better when the 7 (?) extra voyagers are in service, though ideally they should get all the availble 221s as well to increase capacity in the short term. In the long term, they need bimodes (or, to go into fantasyland completely, full electrification of their routes and EMUs)
Mark J
12 May 2018
XC has been truly awful today.
Attempted to get on the 12:15 Reading to Banbury train, was unable to do so due to the sheer number of people on the platform. The entire length of the four carriage train and ten+ deep in places.
Had to get on the GWR to Oxford and await the next service from there, as I was not prepared to stand nose pressed against the window all the way there.
There have been endless delays, cancellations and short formations - four carriage units.
The service really is an utter joke.
leomartin125
15 Nov 2015
North West
Yesterday (24/06), XC would’ve been significantly affected by the signalling issues in the Southampton area. I don’t think a single train was able to use Southampton Central all day, so from the start their service was compromised and sets would’ve been out of position leading to delays and likely, cancellations too.
This was out of their control, however I do agree that during times of significant disruption, XC do have major issues with managing this and putting a suitable action plan together, so I have to agree somewhat with your comments.
That being said, XC keep their trains at Eastleigh Depot (iirc) and Eastleigh was able to run some trains yesterday, it does look as though they did attempt to run what they could from Eastleigh Depot… but sadly that wasn’t enough to prevent cancellations.
GWR, once upon a time, operated IETs to Banbury from London Paddington. Not sure what happened to that service, as that could’ve been an alternative in times of disruption such as yesterday!
