Why are there no single or two-car EMUs?
Mikey C
11 Feb 2013
Unless you decide as a country to electrify every line, it does seem logical that any route genuinely only needing a relatively infrequent 2 car units would be a low priority for electrification other than small sections of line in an otherwise electrified area
While the odd 2 car service has been operated in the London/South East such as the 456s on the South London Line, the 2 car units were more used to give flexibility in the lengths of services.
Bringback309s
22 Aug 2013
Like 142's ?
No - having compliant 365's sat in sidings, awarding a franchise to a company replacing two year old trains (SWR) that then says its made a massive loss. I wasn't particularly commenting about DMU's or short EMU's, just what a cock up of an industry as a whole the UK rail industry is. I could go on!
30907
Plenty of single car electric units in other countries
SNCF have quite a few 2-car units, but the only single cars I can think of in Europe are power cars that work with "loose" trailers, still surviving on Swiss narrow gauge lines (and minor Austrian lines?)
4REP
16 Oct 2019
Bingley
class 414 2Hap also existed but mainly worked with 4car emu like cigs/veps/ceps/beps and occasionally reps.
There are. Possibly the biggest example is Thameslink. Off peak there is massive over capacity on the south of London routes (I have no experience of north of St Pancras, so that may not be the case there!)
That's a rather different issue. If Thameslink had gone for 4-car sets running singly in the off-peak (as they often did before the 700s) then they would be reasonably well filled. There is no need on this route (nor, I would argue, on most others) for a 2-car EMU.
AM9
13 May 2014
St Albans
I think the units ran as buffet unit to Clacton, non-buffet unit to Walton and the two-car were meant to add capacity and boost performance in the peaks, hence being only two-car.
When introduced, the standard consist of London to Clacton/Walton services was (from the country end), 309/3 - 4-car; 309-2 - 4-car griddle & 309/1. At Thorpe Le Soken, the front 4-car unit detached and served Frinton and Walton, then the rear 6 cars left for Clacton. On the up services, the Clacton section arrived at Thorpe first, and the Walton section joined to maintain the same configuration throughout the diagram.
In the late '60s/early '70s the busiest train of the day, the down 17:40 ran with two 2-car 309/1 units then a 309/2 and 309/3, - a 12-car 100mph train with 3364kW pulling 543 tons (nearly 9hp/tonne - high for the '60s). This service ran fast to Colchester and didn't split -only going to Clacton. Once clear of the signal checks up to Shenfield, this train really did show its heels!
AM9
13 May 2014
St Albans
There are. Possibly the biggest example is Thameslink. Off peak there is massive over capacity on the south of London routes (I have no experience of north of St Pancras, so that may not be the case there!) ...
The operations disruption of shuffling 4-car units around would seriously affect Thameslink units well outside the peaks. Overall, once inside the zones, there is fairly good patronage of the outer services, -the Sutton loop services as 8-car units slightly less. Energy wise, the additional rolling resistance of a 8 or 12-car unit vs a conventional 4-car unit is a comparatively small part of total requirements, and much of the energy used in acceleration is recovered in regeneration braking.
... The argument for fixed formation, long trains was capacity and the operational inconvenience and inefficiency of splitting, so yes that was the view taken. Conversely though, short DMU fleets are ordered with the reasoning that they can be coupled for peak times, or to serve multiple destinations after splitting. Experience shows this rarely comes to fruition. One man's efficiency is another man's waste of resources, it seems.
In areas with much smaller flows, peak train capacity can be met with part-time extensions of diesel stock, but the energy waste in DMUs is proportional to the weight of the vehicles and none is recovered during braking. As passenger levels increase in recently electrified areas away from the south-east, fixed 8-car sets might become more advantageous.
Islineclear3_1
24 Apr 2014
PTSO or platform depending on the weather
They did work singly on the Lymington and Sheerness branches, Maidstone West, Dorking to Horsham backwaters and I'm sure, other branches on the former South Western Division; however, they were tagged onto peak hour main-line units to add additional capacity
hwl
5 Feb 2012
It would have cost circa 20% more per vehicle to go for 4car on Thameslink vs actual 8/12 car mix along with additional driver requirement for splitting joining and ECS.
In the future multiple of 5 vehicle are the optimum for ETCS computer system cost minimisation hence the 5x 24m unit / half unit solution from Bombarider solutions for GA and LNR.
Short EMUs have:
  • a significantly higher cost per vehicle
  • are less energy efficient per vehicle
  • have extra staff splitting and joining costs per vehicle
Newer EMUS now have regenerative braking so the running cost of longer EMUs has fallen.
Maintenance requirements for modern EMUs are also lower hence less need to be able to rotate the fleet through maintenance.
Reducing capacity off peak is now not seen as cost effective in many cases.
30907
Back in the early 70s there were single 2-HAP off peak workings out of Victoria - the xx50 Gillingham stoppers (and on the SED 8 and 10-HAP were normal in the peaks until more VEPs became available...)
reddragon
24 Mar 2016
Churn (closed)
Because you wouldn't electrify a line that only had demand sufficient for a single carriage train?
Romford - Upminster branch barely needs 2 cars and was only electrified to get rid of a diesel island in the 1980's
The Marlow branch can only takes 2 cars and may get electrified for the same reason.
Perhaps converting an old unit to 2 cars could make sense in such cases.
delt1c
4 Apr 2008
What would be the savings of converting a 4 car to 2car? 1st you have the cost of the conversion then savings would be neglible.
Also the maintenance cost of DMUs is higher overall and probably more dependent on mileage/time in service, so there is more incentive to minimize the number of cars with DMU operation than with EMU.
Lockwood
4 Apr 2013
Well, for the case of Bourne End, so it would physically fit.
AlexNL
19 Dec 2014
When you look abroad, you'll see that there are plenty of short EMUs.
For example, in the Netherlands. NS used to operate two car EMUs of the Mat '64 type (length: 52,1m), they still operate two-car SGMm units (length: 52,2m) and even their newest EMUs aren't that much longer. The three car versions of the SNG measures 59,6m in length and the three car FLIRT is 63,2m long.
Other operators have even shorter trains. R-Net's two car FLIRT trains are 45,7m long and the shortest ones of them all can be found in the east. The two car variants of the 'Spurt' (GTW) trains used on the Vechtdallijnen route are only 40,9m long.
4REP
16 Oct 2019
Bingley
Due to the high hp rating of the 4Reps, I don't recall 2 Haps ever working with them unless there were ecs workings and a set of motors were cut out
Reps had a index ratio of 14 so could do so. Reps could not work in multiple with 4 car emus even with their own class unless motors were isolated.
Peter Sarf
Croydon
I seem to recall that , in their latter years, the 2-HAPs got fixed together in pairs becoming 4-CAPs. Not all of the 2-HAPs survived to this stage and I think they were converted for the Coastaway line. The number of 4-CAPs dwindled and, by 1988, these were used on Victoria to Medway (or beyond) services I think in pairs (8 coaches). I used them quite a lot in the evening and they were similar to EPBs but with a loo and some compartments. As for livery i think some HAPs were all over blue as opposed to blue & grey. But that might only have been once they became 4-CAPs.
PeterC
29 Sep 2014
I would have been home from school by that time of the evening, I am sorry that I never saw that formation.
Bob M
20 Dec 2008
If a 2-car third rail unit were available, the Lymington branch would be a good place for it.
hexagon789
2 Sep 2016
Thank you for clarifying, seems I remembered some bits. Something I often wondered was how able the 309s were at actually reaching 100mph. Certainly a standard 10-car formation doesn't seem all that powerful by modern standards?
The other thing is how much 100mph running there was. From Modern Railways the GEML seems to have still been 90 max in 1962/3.
Just some observations and ponderings
Only been there once (twice for the pedant, there and back), but I think there's a station car park or a road in the way.
It’s the main road, passing at track level, there used to be a level crossing when the line extended to High Wycombe. Anyway, a 4 x 20m EMU could fit the long platform at Bourne End, it’s only the reversal towards Marlow via the shorter platform that needs a short train, and I believe a 3 x 20m EMU would work anyway. It’s the lack of a suitable 3 car EMU in the recent batches that is the only issue. You’d need a special unit and a spare just for that branch...
No point when they have enough 450s now, since the 707s came in. You’d need two units to have a maintenance spare, then by the time you add crew training, maintenance, spares holdings it just doesn’t make sense.
