Is there a reason why a lot of bus stations that have been rebuild on the same site, like Stockport, is now called an Interchange?
Stourbridge town station could well be renamed Stourbridge Interchange, as a) it's not the original Town station, and b) is close to the bus station (which is called "Interchange.")Bradford Interchange and Hull Interchange are two examples that come to mind which are definitely interchanges and act as hubs for bus and rail services in their respective areas.
But I still think of it as Bradford Exchange! Luckily the two words are almost interchangeable, and any mis-speaking is easily understood!Bradford Interchange Rail Station is 60 metres away
Probably the most bonkers was (and may still be, although I haven't been recently) the bus stop next to Adwick station which described itself as "Adwick Interchange". In ten years of working through the railway station I never saw a bus there!The definition of "Interchange" is often stretched, especially in South Yorkshire. My favourite example being Grimethorpe interchange, which is simply 4 bus stops on a street (2 either side).
You could argue Swinton Interchange is even more ridiculous, being simply a bus stop next to the train station.
Same is true in Tyne and Wear. If it's a multimodal facility, it's an Interchange, whereas if it's just buses it's a bus station. If the bus station is separated from the rail/metro station even by having to walk across a single road or alleyway, that's a bus station. The only 3 exceptions I can think of are the Airport, Central Station (since the name of thosd two render "interchange" redundant), and North Shields Transport Hub, because marketing.In Greater Manchester interchange has long been used to mark a point where you can change travel modes. The very long established Bury Interchange where tram and bus can be found. Similar in Ashton-under-Lyne which has buses and trams, with the added bonus of the railway station being reasonably close. Stockport currently is probably pushing it a bit. It is a bit of a trek from the buses to the trains. But also it's a statement of intent for the proposed extension of the Metrolink.
There is always a clear difference. If it's bus only, in Greater Manchester, they call them bus stations instead.
That's certainly the case at Altrincham Interchange, where you can switch between Metrolink trams, heavy rail (to Stockport / Chester) and local buses. Think there's also a taxi stand there.In Greater Manchester interchange has long been used to mark a point where you can change travel modes.
There are no commercial Arriva buses calling at Llandudno Junction any more and no signage at the station or on ‘Platform(!) 5’ advising would be passengers where the nearest bus stops are, not helped by the fact that there are buses to/from Llandudno picking up at totally different stops within a couple of minutes walk from the station!I'm sure that Llandudno Junction showed the bus stop outside as "Platform 5." I thought it was excellent and would have sworn that it was on the departure boards too. However I can't see it on any website now, not even NR..
Maybe that was only when we had a RRB from there onwards to Bangor... (Which was done briliantly: an express departure to Bangor - and /on to Holyhead? - plus a stopping bus for all stations to Bangor, both clearly signed and stewarded.)
I read that and wondered how many of those countries have a system where the bus is the feeder to the train. Which happens a lot in regulated, organised public transport systems. Which we in the UK, (mostly) don't have.In several other countries, there is often no special label for the bus station if it happens to be next to the railway station. In timetables it will simply be referred to as "bahnhof", "gare", "station" etc. When looking at British bus stations from that perspective, you then realise that is kind of embarrassing that we actually have to point out that a bus station has other modes in the vicinity, as if it is something special.
Just over the border in West Yorkshire (and reachable on SYPTE tickets) is Denby Dale Interchange. A single platform railway station and one bus stop on a turning circle! There was a second bus stop at one point, but that was removed a while back.Probably the most bonkers was (and may still be, although I haven't been recently) the bus stop next to Adwick station which described itself as "Adwick Interchange". In ten years of working through the railway station I never saw a bus there!
I lived in Melbourne, Australia in the early 1990s, and your right . A 'bus station ' at a shopping centre/railway station was and still call thatIn several other countries, there is often no special label for the bus station if it happens to be next to the railway station. In timetables it will simply be referred to as "bahnhof", "gare", "station" etc. When looking at British bus stations from that perspective, you then realise that is kind of embarrassing that we actually have to point out that a bus station has other modes in the vicinity, as if it is something special.
The thing is though, bus stations really aren't safe or even pleasant places to wait for a bus after dark, or in the case of some places even during the daytime, an Interchange if done right suddenly makes things safer. Taking Leeds as an example, you really wouldn't want to be down Leeds Bus Station on a night, where as the train station feels a lot safer. Now if both the bus station and the train station were built together with the same high level of staffing for both and called something different like an Interchange, the bus station part suddenly seems and would be more appealing.
Over in the Irish Republic, there are several examples of bus and train stations built right next to each other but for some reason they're referred as individual units rather than one common one such as an interchange. Tralee, Killarney, Limerick to name a few, it's a pity especially in the case of Tralee and Limerick as there are some great connections to be made from both modes of transport.
Surely it's little more than a buzzword - does anyone really care whether a location is called "Interchange" or "Rail Station"? Certainly the latter is what we call it in my home town, to separate it from the actual bus station, sensibly placed vastly closer to the entirety of the town that isn't the rail station. By contrast, the town I lived in in Germany had precisely 0 buses stopping at the Rail Station - they stopped at the bus station 5 minutes walk away, vastly closer to the entirety of the town that wasn't the rail station...In several other countries, there is often no special label for the bus station if it happens to be next to the railway station. In timetables it will simply be referred to as "bahnhof", "gare", "station" etc. When looking at British bus stations from that perspective, you then realise that is kind of embarrassing that we actually have to point out that a bus station has other modes in the vicinity, as if it is something special.
That may be the case om your town, but not in mine. I'd much rather wait at the bus station (open air, well lit, if a bit cold) than I would at some random roadside stop. It's site specific, rather than bus stations as a whole.The thing is though, bus stations really aren't safe or even pleasant places to wait for a bus after dark, or in the case of some places even during the daytime, an Interchange if done right suddenly makes things safer. Taking Leeds as an example, you really wouldn't want to be down Leeds Bus Station on a night, where as the train station feels a lot safer. Now if both the bus station and the train station were built together with the same high level of staffing for both and called something different like an Interchange, the bus station part suddenly seems and would be more appealing.
With respect, the comment seems largely based around the 3000th attempt at shoehorning in "everything is better abroad"...
