Which TOCs are currently conducting in cab trainee driver training?
Stigy
6 Nov 2009
So do you actually volunteer with the Ambulance Service? You seem to know more about testing than me. I did not know that these lateral flow tests were less reliable but hopefully, they are producing more false positives rather than false negatives where the latter give a wrong indication of a positive result that otherwise goes undetected.
One thing I do know is that there seems to be a more of a blame culture now with various people blaming government, each other, etc, but as @ComUtoR says, certain local councils are being more proactive in tackling Covid 19 amongst asymptomatic people. These councils clearly recognise that the cost of such testing is lower than the cost of allowing Covid to go rife in the community.
Yes, I’m a Community First Responder for South Central Ambulance Service. Whilst technically I agree about it being better to have a false positive (right side failure :D), it’s not ideal as you’d then have to get a PCR test done to definitively say whether you have Covid. This probably puts people off taking the test in the first place, especially testing yourself routinely when you are showing no symptoms.
I know @Stigy personally, and it would be a surprise to me if he does, because he's never mentioned it
I don’t think there’s a “yawn” emoji available to use here.... ;)
Interesting, I knew that Stigy moved from SWR to GWR so I had him down as working at either Fratton or Reading. With a name like @tiptoptaff , I imagined you worked out of Cardiff, I used to study there many years ago, digressing somewhat.
I read that as “distressing somewhat”....which would fit :D
DunfordBridge
13 Apr 2013
Scarborough
Probably where people need to be educated on account of the number of asymptomatic spreaders.
I enjoyed myself in Cardiff, although I did spend enough time there to experience a certain level of distress on the odd occasion. Portsmouth too was enjoyable.
sw1ller
4 Jan 2013
I don’t trust these weekly tests at all. I was in a transition from the blood tests to the lateral flow tests, both of which came back negative. However, I felt awful so I went for a NHS test which came back positive. It floored me for a few days so I definitely had it, but I took more of the tests work sent me and they all came back negative.
Im still taking the tests as I want to help people get back to work and some kind of normality, but I just see them as a tick box exercise now.
DunfordBridge
13 Apr 2013
Scarborough
Quite alarming in the sense that it is a false negative. Maybe it was the timing of the first tests or the route that the virus takes into the body in the early stages of infection.
sw1ller
4 Jan 2013
I don’t know. But yes, very alarming indeed. It’s weird how 5 tests from work all came back negative, 3 before the nhs one and 2 after. Like you say, maybe it was just pure coincidence and the tests work fine, but I’m not convinced.
DunfordBridge
13 Apr 2013
Scarborough
I think your experience is enough to cast doubt in my mind about the validity of those five tests and it is no wonder that certain operators have suspended in-cab training which is a debate in itself.
sw1ller
4 Jan 2013
I mean of course its more likely that 5 tests were wrong and the 1 was correct... :rolleyes:
It’s more likely that 5 do it your self test were wrong and 1 NHS one was correct yes. Coupled together with the fact I felt like absolute s***e.
Stigy
6 Nov 2009
Assuming these DIY tests were Lateral flow tests, then they definitely aren’t as accurate as a full PCR test. It’s entirely possible (although very unlucky) that five of them were incorrect and the PCR test was accurate.
Timpg
30 Jan 2014
Ipswich
I’m a trainee driver for GA and I begin my pass out tomorrow, I had 6 months off, last year due to Covid restrictions etc, until these bubbles could be set up and agreed by aslef.
personally I think it’s a safer situation to be in a bubble with a DI, tested every week and temp checked before every shift. Than being a untested qualified driver, going to work in a busy jsop with drivers and guards coming and going throughout the day.
Myself and my DI had a constant mutual respect for each others health and abided by the rules of the various lockdown restrictions. It’s a system that has been as safe as can be and has worked for me and my DI, he is now starting with his next trainee and I will hopefully become qualified in the next few days.
Stigy
6 Nov 2009
Good luck with the passout! It’ll be a great feeling once it’s finally done!
DA1
22 May 2017
England
Just going back to this thread, has anyone’s situation at their TOC changed?
Trainee driver groups at mine are going back to classroom training with two tests a week after a couple weeks of online learning.
vikingdriver
11 Mar 2010
Still no in cab training at SWR.
craigybagel
25 Oct 2012
TfW in cab training restarts tomorrow.
