Which ticket for Heathrow T5?
mrbouffant
25 May 2018
On Monday I wish to travel on the 0644 thameslink service from east grinstead via Farringdon and the Elizabeth Line to heathrow T5
Which ticket should I buy? The southern journey planner offers no fares between the two stations.
Thanks!
MrJeeves
28 Aug 2015
Burgess Hill
Thanks!
Check out the forum's ticketing site:
It offers an East Grinstead to Hanwell ticket, plus a ticket from Hanwell to Heathrow for £28.60.
There's no through ticket available other than one routed "SOUTHERN & HEX" which wouldn't be valid on either Thameslink or the Elizabeth Line (and costs £45.10!).
PO48RA
29 Jun 2024
Hampshire, UK
Using the forum's split ticket site I'm seeing the above £28.60 fare to Terminal 5 via Farringdon and the Elizabeth line.
A cheaper alternative, albeit possibly a bit slower, is £16.71 to Feltham via Clapam Junction and then take the 490 bus for £1.75 to Heathrow Terminal 5. The bus takes about 30 minutes, runs every 20 mins or so.
CyrusWuff
20 May 2013
Incidentally, it's possible to buy a through ticket to Heathrow via Feltham. The destination to use is Heathrow Bus (NLC 5564.)
Link to a search on the forum site: https://tickets.railforums.co.uk/re...ss=false&flexible=false&selectionMethod=Grid#
Is this cockup or conspiracy? Ignoring Crossrail for the moment, why wouldn’t a single fare have been available to LU Zone 1-6 using the Piccadilly Line, or a single fare to Heathrow using Connect, (with a cross London marker), back when that still ran? Did the latter fare just never get introduced?
PO48RA
29 Jun 2024
Hampshire, UK
Heathrow Underground shows up on the national rail enquiries search but not on the split rail tickets search, any ideas why?
Haywain
3 Feb 2013
Because it's generally more expensive than Zone U1256 as a destination?
MrJeeves
28 Aug 2015
Burgess Hill
The site should sell whatever is cheaper of the two.
This question is probably better suited to the actual forum ticketing site thread, though.
greatkingrat
20 Jan 2011
Just a warning that not all Elizabeth Line trains stop at Hanwell, including the direct ones to T5. So it might be worth considering a different split, even if it is slightly more expensive to get more flexibility.
mrbouffant
25 May 2018
Thanks for your thoughts. What a can of worms! In the end I bought a single to Farringdon and then tapped in for the liz line. Overall cost was about £30. More expensive than it should have been but more straightforward.
