tbtc
Oxted to Uckfield and Ashford to Ore, with 3rd rail.
It'd do little or nothing for journey times, but remove these silly islands of diesel in an otherwise completely 3rd rail region and allow a reasonable number of sprinter compatible DMUs to be moved somewhere they'd be more valuable
These would be on my list too (after we tackle the backlog of Things Wot We Promised We'd Do In CP5, e.g. Didcot to Oxford) - I'd generally start from the position of Most DMU Carriages Freed Per Mile Of Electrification - in which case Uckfield should be a priority (long DMUs that already spend a large proportion of their time on electrified track).
Generally though, if we are talking a world with bi-mode, forget about anything with less than an hourly service (Mallaig!), focus on the busy trunks without needing to wire every branch.
If structures are difficult to wire then at least consider wiring the line up to that structure (e.g. wiring Waverley to Dalmeney would remove a lot of diesel fumes from central Edinburgh and significantly improve air quality, even if nobody wants to tackle the tricky bit over the Forth Bridge).
On the subject of air quality, wiring Marylebone - Bicester would remove a few diesel fumes from central London - same with wiring the central core of the Snow Hill lines (without going all the way to Stratford/ Worcester). If bi-modes can switch reliably then you're a lot better wiring up the busy bits (and forgetting about every branch).
A better question might be to limit suggestions to (say) a hundred miles/ five hundred miles of single track, otherwise you'll get wish lists that include various parliamentary routes!
