There are a variety of places.
Freightmaster is a quarterly book and/or subscription website that gives you info on scheduled freight working, including headcodes and likely traction.
RealTimeTrains is great for finding short planned workings, although it displays all working timetabled freight paths even though many never run.
If you are serious about it (IE not just going out occasionally) then Freightmaster is well worth the money especially the online version which is kept as up to date as possible.
Disclaimer-
No connection except as a subscriber etc etc.
...and as of today only costs £12 for access through to the end of September!If you are serious about it (IE not just going out occasionally) then Freightmaster is well worth the money especially the online version which is kept as up to date as possible...
If it is for casual spotting then RTT will be best for you: I've done an example of tomorrow (4th August) at Newton-le-willows, having selected the time period that I'm interested in (all day in this case) and have put in the services column to only find freight services.
http://www.realtimetrains.co.uk/sea...8/04/0000-2359?stp=WVS&show=freight&order=wtt
You can then do similar things for any other station, and by clicking on each train listing, you can see more details, such as what type of loco will be hauling the train, and track its progress in real time
Awesome that's what I was looking for. Shame the mobile app doesn't have the same functionality
Good luck to see any of those running!!If it is for casual spotting then RTT will be best for you: I've done an example of tomorrow (4th August) at Newton-le-willows, having selected the time period that I'm interested in (all day in this case) and have put in the services column to only find freight services.
????? :roll:you can see more details, such as what type of loco will be hauling the train
Also the type of locomotive is specified by means that it will say that it is a diesel or an electric or a form of multiple unit. Not a class of locomotive.
MARK
Although even that does not mean too much. Most of the WCML intermodals are listed for electric locomotive but show up behind a 66, while I frequently see 1Qxx test trains listed as being the HST but showing up as 67s.
Personally I use it in advance only to look for STPs, for that it is invaluable and does away with the painful "secret insider gen" on such workings. Seen loads of stuff locally that I would not have known about by just selecting STP only passing Keighley.
