GraphitProjekt
Seemingly throughout the BR days and up until quite recently Merseyrail was only connected to the "grid" at 3 places - Bankhall, Shore Road and Bromborough. Searching through SP Energy Networks' documents I have found reference to all 3 of those.
But I've found a RailEngineer article from 2019 that mentions the addition of 3 more (to do with the class 777s) at vague locations, searching on Google Earth historic imagery I have seen works going on in those locations in the last 5 years:
Except! I have found a reference to a 33/11kV connection with Network Rail at Hillside substation (on the Southport branch). See a pdf here if you like. Looking at Google Earth, I can see work took place from 2020 at the site someway south of the passenger station. There's been a DC substation at Hillside for decades considering the cathedral-esque architecture of the item - however, the 2020 work involved adding a new little brick building which is not seen in Long Lane or Aughton South which use only green containerised buildings as is often the case with a Network Rail project.
Hillside is not mentioned at all on the RailEngineer article so did one of the previous locations change after 2019 - or are there four new connections?
- (Kirkby branch) Between Long Lane and Walton
- Construction can be seen at a site near the overbridge of the B5187 (Long Lane) where there was previously nothing (so this would have added a new DC substation too)
- (Ormskirk branch) Between Maghull North and Town Green
- In the middle of some fields a way south of Mickering Lane where there was previously nothing (so this would have added a new DC substation too)
- (New Brighton/West Kirkby branch) "between the new DNO substation building at Birkenhead North and the upgraded substation at Bidston"
- Can't really see what exactly this is referring to but lots of new stuff has been built around the pre-existing Bidston substation
