CalaisFret
- Joined
- 13 Jan 2016
- Messages
- 13
Hi, am looking to see a class 08 shunter working on the national network i.e. Not preserved/heritage. Any advice on the best location for this? Any advice gratefully received.
You will only see them in depots (the few that still use them). So you need to find depots that use 08s reguarly and can be seen from a public location.
Norwich Crown Point uses them every day and you can see the depot from various roads around it. In fact any depot that uses traditional hauled stock (HSTs, Mk3s, Mk4s) will have 08s, so that'll be Laira, Old Oak Common, Bounds Green, Neville Hill, Craigentinny, you get the idea.
On that note, off I go to Crown Point to drive 08s!![]()
I saw a little group of three at Polmadie the other day.
There were 2 at Bounds Green a few weeks ago.You often see the Bounds Green one from Alexandra palace.
Can see some good 08 action quite a lot at Bescot too, visible from Bescot Stadium station.
The one at Soho depot is usually quite visible from passing trains.
I was told by an enthusiast at some stage that the sleeper arrival is hauled out of Paddington with an 08. Is this true?
