Where are the pink validators at Stratford? / Oyster PAYG question
dvboy
6 Sep 2011
Took at journey from Surrey Quays to Southbury on Thursday, touched a pink reader at Whitechapel to change from Overground to the District Line, but because I didn't touch one at Stratford, when changing from Central line onto a Geeater Anglia service to Cheshunt, I've been charged £6.20 instead of the avoiding zone 1 fare of £3.20. Oyster website says I should have touched a pink reader at Stratford. I looked for one but didn't see one anywhere, despite being there for a while so having a good wander around!
Later the same day I appear to have been charged £1.50 from Highbury & Islington to Shepherd's Bush, instead of Southbury, where I started from after topping up, so should have been £2.20. I remember touching at pink reader at H&I, but it appears to have counted this as touching in. I also touched one at Willesden Junction, probably unnecessarily.
I've a bus journey on top of this, at £1.40, so total I should have been charged is £6.80 but for the day I've been charged £9.10.
By my calculation the refund I'm due is now £2.30. Can someone tell me where the validators are at Stratford, if it's worth ringing Oyster to get £2.30 refunded?
Date / Time Journey / Action Charge Balance
Thursday, 10 October 2013
£9.10 daily total
15:52 Bus journey, route 94 £1.40 £6.15
14:03 - 14:52 Highbury & Islington to Shepherd's Bush [London Overground] £1.50
£7.55
14:52 Touch out, Shepherd's Bush [London Overground] +£3.40 £7.55
14:37 Touched pink card reader, Willesden Junction £0.00 £4.15
14:03 Touch in, Highbury & Islington £4.90 £4.15
13:38 Topped up, +£10.00 £9.05
09:08 - 10:40 Surrey Quays [London Overground] to Southbury [National Rail] £6.20
-£0.95
10:40 Touch out, Southbury [National Rail] +£1.00 -£0.95
09:19 Touched pink card reader, Whitechapel £0.00 -£1.95
09:08 Touch in, Surrey Quays [London Overground] £7.20 -£1.95
MikeWh
15 Jun 2010
Crayford
Pink validators are on the overground platforms. You should only need to touch them if going via Hackney or Highbury. I'd always call the helpline if you've been overcharged, though it helps to have a clear understanding of what you should have paid because they often assume you'd have capped and only refund above that.
If you can post your expanded journey history then we can try and work out what happened at other points that day.
dvboy
6 Sep 2011
I couldn't see one on platform 11.
You might have started replying before I posted my expanded journey history, but it's there now.
To clarify my journeys were:
Surrey Quays - Whitechapel - Mile End - Stratford - Cheshunt - Southbury
Southbury - Seven Sisters - Highbury & Islington - Willesden Junction - Shepherds Bush
MikeWh
15 Jun 2010
Crayford
I see you've added it. ;)
How did you get from Stratford to Southbury without touching again? Normally you would go via Tottenham Hale and Seven Sisters which would force a touch.
It appears that you didn't touch in at Southbury. This is a common issue after topping up, even I've done it once. Pink readers will act as entry validators if you're not already in.
dvboy
6 Sep 2011
On a Stratford - Bishop's Stortford train to Cheshunt, so no touch.
You could be right about having not touched in at Southbury on my second journey.
MikeWh
15 Jun 2010
Crayford
Sorry, that should be London Overground platforms (1 and 2).
Yep!
It's ignored Whitechapel as you don't need to touch there. Thus it's assumed you've gone through Shoreditch and Highbury.
dvboy
6 Sep 2011
I've contacted Oyster through the website in the hope they can refund me (rather do that that phone).
bicbasher
14 May 2010
The phone number is now an 03 number, which if you have inclusive minutes would come out of that instead of the more costly 08 number.
