MidlandJoe
When planning a trip, I'm interested in how differently people do it. Do you focus on one main spot for the day? Do you visit several stations within a certain area? How do you decide what stations you will visit, in what order, and for how long?
For me personally, I mix. I sometimes focus on one location, and sometimes I go out and cover several (For example, I might do several stations on the Birmingham - Wolverhampton section.) I usually tend to spend an hour at each station, if I'm visiting several, or more if I'm visiting fewer.
When deciding on the order, I simply look at the timetable and work out which is the easiest, with connections that can almost definitely be made (+10 mins ish for delays) and without having to hang around for too long.
Finally, when it comes to deciding on the stations, my main 'Research' task if you like is to check the visibility from each platform, so you won't get caught short. I then check for timetables. I don't see much point visiting a station with an hourly or sometimes half hourly service, unless it is an interesting location (For example, Ribblehead on the Settle - Carlisle line with the Viaduct)
It would be interesting to see if anyone here plans trips differently, and if so, how they go about it. Let me know.
