When is a direct train not a direct train?
apbj
18 May 2023
It seems GWR's 0710 Penzance-Paddington (1A78) now involves a change of set for all passengers at Plymouth. It used to be that one 5-car set was attached to another at PLY to make 10, but now it seems to be diagrammed as a set change.
The first time this happened the train manager mumbled some apology about "needing extra carriages" which made no sense. The second time the train manager said it had always been done this way, which isn't true. Happened again today.
Despite the code remaining 1A78, seat reservations were not transferred over which means absolute bedlam on a busy peak (expensive!) service into London. Various assistance passengers cut loose in the process, too.
Can GWR sell through tickets for trains that are no such thing? Journeys that break in Plymouth are sold at a discount in advance so there's a fare premium as well as an issue of convenience.
Tetchytyke
12 Sep 2013
Isle of Man
Looks like you were just unlucky today with a set swap. RTT shows that your unit was swapped on to 2C09 (0809 Exeter to Penzance) at Plymouth and the unit from that was swapped on to your train, which ran as a 10-car from Plymouth.
apbj
18 May 2023
No, it was diagrammed this way last week and so far every day this week.
It worked as expected Mon Tue this week, and Wed-Fri last week. According to RTT
Tetchytyke
12 Sep 2013
Isle of Man
Not according to RTT it hasn't.
Example from yesterday: https://www.realtimetrains.co.uk/service/gb-nr:W34562/2026-06-30/detailed#allox_id=1
802005 operated throughout, with 802004 added at Plymouth.
Same last Wednesday: https://www.realtimetrains.co.uk/service/gb-nr:W34562/2026-06-24/detailed#allox_id=1 (802015 throughout, 802009 added at Plymouth).
Unless RTT is relaying duff allocation info, of course.
apbj
18 May 2023
Ah, maybe .. we definitely had to swap on Friday and again on Monday, hence asking the question but perhaps I have indeed just been unlucky with set swaps :)
On the plus side, the absence of reservations following each swap also means an absence of automated announcements so there's relative peace and quiet at least!
18 Mar 2007
North Oxfordshire
At one point you could pretty much guarantee that a large percentage of Cambrian 'direct trains' to/from Birmingham would actually involve a set swap at Shrewsbury, depending on how many ERTMS-fitted 158s were actually working and in the right place.
Don't know how common it is now that more 197s have come on stream.
There were also trains on SWT where you would have to move coaches if you were making certain journeys.
(E.g. on a Sunday when a 4 car Alton train joined an 8 Car Basingstoke train at Woking, anyone travelling from the Alton portion to Clapham Junction or Wimbledon would have to move coaches as only the front 8 cars could be opened there).
I believe the Class 450 SDO has since been upgraded and this is no longer required.
321362
31 Oct 2023
Was about 50% a few months ago, but now barely any end up being swapped.
The exile
31 Mar 2010
Somerset
This happens quite regularly at Temple Meads. On the last occasion, it was actually announced as being due to the fact that the new driver wasn’t trained to drive “this type of train” (158) - which I suspect was a major departure from script!
