I just been looking at some Wiki Pages and was looking at how well Stations do, I was wondering when the 2014/2015 Figures will come out?
I guess with this we'll see if the Sparks effect still applies now that the chat moss is fully wired.
How are you going to work out if it is "sparks" when so many stations in the North West have been seeing exponential growth without the wires?
Wavertree Technology Park got annual usage of 342,000 in 2012/13 and 468,000 in 2013/14. If there's 25% growth at the station it's first year of having wires that would be a significant reduction in growth.
For instance, Wavertree station passenger numbers actually went down from 362,000 in 2011/12 to 342,000 in 2012/13, and it is impossible to have an exponential growth curve with just two reference points.
There will be a sparks effect on the NW electrified lines in terms of a faster coherent network of services with more capacity which I wouldn't try to quantify by cherry picking one particular station's figures over just 1 year.
.... The problem with any 'sparks' argument is if the growth continues you could get someone arguing the growth would have stopped or slowed if it wasn't for electrification. However, unless you ask new passengers why they started using the service and the primary response they give is directly related to electrification then you don't know....
The problem there is that many (most in some cases) aren't particularly aware of their trains' method of propulsion. Until the timetable is adjusted to take the 75mph stock's slack out, they won't even see much reduction in journey times. There's also the issue this year of maintenance teething troubles, which Allerton will probably have ironed out by next year.
There's not to my knowledge been a lack of growth in any major electrification scheme since the '50s so I doubt that this will be the first.
Just keep an eye on house prices along the line compared with similar areas not on those lines, - the most striking indicator of the attraction of electric services. In St Albans, the electrification of the BedPan services pushed house prices up between 20 and 30% in a couple of years, - regrettably before I moved here!
Wavertree Technology Park got annual usage of 342,000 in 2012/13 and 468,000 in 2013/14. If there's 25% growth at the station in it's first year of having wires that would be a significant reduction in the level of growth.
Plenty of adverts have been made for it across the region saying that theres electrics running on the line.
compare Widnes and St Helens Jn or Newton Le Willows and Birchwood. Believe car parks on the routes are suddenly impossible to park on and causing trouble locally (St Helens Jn IIRC)
Yes Northern keep tweeting that but the reality is most people probably don't care. Saying there's extra seats is more relevant but there aren't extra seats on all services operated by 319s as some are services which used to be 4 car Sprinters, especially those between Liverpool and Wigan.
Not that reliable. What if there's been a lot of job losses in Warrington? The CLC line would be affected more by that than the Chat Moss line.
Just looking at some figures for a few lines I noticed that local stations between Crewe and Liverpool have seen quite a lot of growth since the Turbostar service between Liverpool and Stansted Airport was replaced by a Desiro service between Liverpool and Birmingham. However, the following is also worth noting:
1. Late running northbound trains from Stansted Airport were sometimes terminated at Crewe, putting some people off using the train.
2. The electric Desiros that were introduced were brand new and didn't lack any features that the Turbostars have.
3. There was significant growth in the first few years of using 350s but the total growth over the past ten years at those stations isn't that different to lines which still get 1980s diesels. Maybe new 350s and a service revision got people to switch to using the train sooner opposed to attracting people who wouldn't have ever switched to the train?
4. LM have introduced penalty fares so maybe some of the growth is actually less ticket-less travel?
It wasn't ever exclusively diesel. Look all you want but you will find electric services even then. The stansted services weren't that unreliable either and services will still terminate at LSP with late running.
The reality is that there were hardly any 4 car services running out of lime st.
Warrington has had huge employment growth
I know you downplay this 'sparks effect' judging by a large number of your recent posts but there is plenty of evidence and is accepted as fact by many if not all in the industry. I don't see the equivalent of Wolmar (with his anti-hs2 view) who is against the view of the Sparks effect.
Punctuality should improve as a result of using 100mph capable EMUs as they are can more easily recover late running when running to a timetable drawn up for 75mph DMUs.
Electrification is very expensive and wouldn't usually be carried out on lines which don't have potential for growth.
I'm not going to disagree that improved infrastructure can push up the value of houses. However, I think there's a number of points to consider here:
1. Did any extra services get introduced? OK electrification might make it easier to add in extra services but if you look at North TPE extra services have been added in ahead of electrification and more will be added in December 2017, again before electrification. If the infrastructure is not being used to it's full potential prior to electrification then electrification can be credited for achieving things which would have been possible without it.
2. How would property prices in St Albans have been affected if electrification hadn't occurred? Faster journeys to/from London will have made it more of a dormitory town pushing up house prices. However, there isn't enough information in your post to say the 20-30% increase should be accredited to electrification. Property prices nationally have gone up a lot over short period of times and have done that for a considerable amount of time.
3. What else occurred in and around St Albans around the time of electrification? Were there any new roads, new shopping developments etc.? Did standards become higher in local schools or did standards at schools in other towns drop?
My local station has seen usage increase by 67% over the last 5 years, despite there being no improvements in rolling stock, no more services, no journey time improvements or no electrification. The only noticeable change is more overcrowded trains! I'm sure if the line was electrified 5 years ago certain people would be saying look at what electrification has achieved, when in fact the increase usage is down to:
1. A major employer in the area increasing the amount of work done at a local site, in favour of reducing work at other sites
2. Withdrawal of subsided bus services including school buses
3. People being willing to travel further to work due to jobs not being as plentiful as they were
4. A nearby city becoming more popular for shopping and night life.
And as for property prices I live in what's been called one of the most expensive towns to live in, in the North of England, despite being under the flight path of a major Airport. Not everything is logical!
Roger Ford said 3 or 4 years ago that growth was flatenning off and there was 1 year when that was true but then the growth accelerated again. Most North West stations have seen more than a little growth in 9 out of the past 10 years.
