The question as posed by Neil Williams was what legal basis would there be for police to remove the passenger *if* they were called. This would be the basis.
I'm not the one making the claim that the driver would call the police in the first place.
So the driver calls the police, despite the fact there is nowhere else for the customer in the wheelchair space to move.
You suggested the customer in the wheelchair space could be removed from the bus as they would be committing an offence by not getting off when asked, because they had "put at risk or unreasonably impede or cause discomfort to any person travelling on or entering or leaving the vehicle" or "that he has been causing a nuisance".
Could you explain your thinking, as it is not clear what part of that legislation a person simply standing in the wheelchair space with nowhere else to go has triggered.
Just in case you haven't read the decision it said -
"An absolute rule that any non-wheelchair user must vacate the space would be unreasonable: there are many circumstances in which it could be unreasonable to expect a non-wheelchair user to vacate a space, and even more, to get off the bus, even where the space is needed by a wheelchair user. Even a qualified rule (i.e. that any non-wheelchair user must vacate if it is reasonable) implemented through mandatory enforcement would be likely to lead to confrontation with other passengers (not least where the non-wheelchair user vacating the space affected other travellers) and delay. Passengers are not clearly subject to a statutory obligation to comply with a policy relating to the use of the space, and would not appear to be under such an obligation to get off the bus if they fail to do so."
