#whatstation 318
Mrs Humm
24 Sep 2019
Stamford (Lincolnshire)
whatstation 318.jpg Here is #whatstation 318, a photo which has defeated the keenest railway brains on Twitter. The very brightest of them, however, suggested I should do much better posting it here.
We have no clues other than the details in the picture. We also have no information about the photographer, unfortunately; the only writing on the back of the print is the number 15527, stamped on. Probably the photographer's own serial number.
All we want to know is, where is this coal yard and distant station? Any extra information - a date, or whether the station was open or closed, for example - would be welcome.
krus_aragon
10 Jun 2009
North Wales
I love these mystery photos, thanks for coming here and sharing it with us!
The layout of the track and station aren't familiar to me, so I would tentatively rule out the North Wales Coast.
The waggon in the right foreground reads "Pinxton", which would appear to be from a colliery in Derbyshire. So that suggests it's somewhere that would get coal delivered from Derbyshire (as opposed to anywhere nearer).
Ken H
11 Nov 2018
N Yorks
Pinxton is near where the A38 meets the A1 at J28
krus_aragon
10 Jun 2009
North Wales
The M1, rather than the A1, I thought?
I embarrassed my wife by asking her if she knew of the place: she said no, despite spending the first two decades of her life living ten miles away! :rolleyes:
Does zooming in on the signal box reveal any better detail on the original? Many of the railway companies had their own distinctive styles of box - but the photo looks as if it wouldn't stand much magnification. A signaling expert may also have something to say about those ground signals or point indicators. Only one main signal visible (back to camera on right hand platform) and on viewing the full size version I think it's rail-built, which if true would almost certainly point to the Southern Railway.
The underbridge half way through the goods yard is also quite distinctive.
krus_aragon
10 Jun 2009
North Wales
As is (to my mind) the fact that the overbridge that the picture was presumably taken from is quite removed from the station itself: there appears to be some form of (barrow?) crossing at the far end of the station instead.
The underbridge seems peculiar - almost as if the coal stands are on top of the road that should go under. But assuming there is a road under there, I'd guess there is a station approach road off it to the right of the coal yard, going up to the building on the right hand platform and also serving the coal yard and the industrial building far right. There's no station footbridge so either a subway or more likely the barrow crossing you suggest is the means to access the left hand platform.
Looking at the proximity of the underbridge I think it's more likely the photographer has climbed a signal gantry rather than being on an overbridge.
krus_aragon
10 Jun 2009
North Wales
On reflection, that would explain the lack of other visible signals in the area (excepting the ground signals, of course).
I'm thinking it would be about the right place for a home signal on the left hand track and an advance starter on the right hand track. But I can't see any reason why there should be a gantry or bracket spanning to the camera position above the centerline rather than just having two signal posts. If there was a junction behind the camera then either the signal box would be there instead, or the visible signal at the station would have a distant arm under it.
Sir Felix Pole
21 Oct 2012
Wilmslow
Is the station closed? - the platform edges look especially prominent and bright as if the coping stones have been recently removed and there appears to be no running-in boards, seats, barrows etc. There is also a home signal, visible under magnification,on the station-building building platform but no signalling on the other platform. It is also a lot of coal for a small station - maybe the industrial affair on the right is a large consumer?
Ash Bridge
17 Mar 2014
Stockport
That Pinxton coal wagon does seem a long way from home, nevertheless I think this could be Merton Abbey Station.
Peter Mugridge
8 Apr 2010
Epsom
By Jove! I think he's got it! :D:D:D:D:D
( And it's pretty much in my back yard as well, being only a few miles from Epsom, but that explains why all that searching in the Midlands over the past few weeks got nowhere!!! )
Ash Bridge
17 Mar 2014
Stockport
Very well deduced - we've spent weeks on Twitter scratching our heads over this one!
The line is now buried beneath the A24.
Well my head is hurting just a bit after four hours of searching this evening, that Nottinghamshire coal wagon did throw me of the scent at first I'll have to admit.
Peter Mugridge
8 Apr 2010
Epsom
That wagon threw everyone off course on Twitter, including members of the Humm family.
Mrs Humm
24 Sep 2019
Thank you. Now we know it was Merton I should think that only the Leicestershire and Kent collieries were closer than Pinxton. I should think that much of the coal went to the paper factory north of the station (although it seems to also to have used water power from the R Wandle).
Yes, it's the M1. My family is from those parts too.
Thank you very much indeed! That's brilliant, I thought it would never be solved. But Merton Abbey is even further from Stockport than it is from Pinxton - were you familiar with it, or do you just have an encylopaedic knowledge of the entire network?
I wonder if they are related to the Humm family who own the book shop at Stamford.
Yes, that's us!
That was a pretty good tip you gave me, Peter - very many thanks! And now I can see it on the map I'm rather pleased that it looks very much as I'd imagined. I'm particularly pleased to see that the overbridge is over a stream - just as I thought. And there is indeed an overbridge in the far distance. Can you work our how long the straight actually is? I've no idea how to calculate that.
Thank you. You are right about the quality of the print - it is not very good, taken into the sun, and I cannot get any more from it. You are absolutely right about the SR. Twitter got stuck in the Midlands, mislead by the Pinxton wagon. Now we know it was Merton Abbey I was able to find it on the 25" maps at the NLS. The sidings to the left only appear on the 1934/5 sheets, as does the signal you mention. There is also an original signal beyond the signal box, I think that is visible in the photo. The overbridge crosses a stream called - not inappropriately - The Pickle.
Thank you. There is no gantry shown on the maps, it looks as though the photo was taken from a road bridge.
I think the station is closed, which would account for the lack of a foot bridge. There was a road between the coal yard and the building, just as you say. The stream crossed by the underbridge bisects the coal yard. It's possible to work this out from the photo, but I found it too strange to believe!
Could the underbridge be a filled-in canal?
Thank you, that's an good thought, but now we know it's Merton Abbey we can tell from the large scale map that it was a stream. I suppose now it is just a storm drain in a culvert.
Thank you, yes we thought it was closed and that turned out to be correct. In fact it was closed to passengers in 1929. There was a large board mill to the north of the station and a smelters to the south. The whole area was highly industrialised by the mid-1930s (the 1894/5 map shows watercress beds).
Thank you all very much for a terrific response, I shall know where to come next time Twitter is non-plussed. I have tried to reply to everyone, abject apologies if I have missed any post.
Cowley
15 Apr 2016
Devon
Good work Mr Bridge (the only person who I know that knows more about where I live than I do :lol:).
30907
Signals: I can make out a platform starter (quite tall) on the LH track by the barrow crossing and trailing crossover, and a home in the other direction.
I reckon the nearest signal is lattice post not rail post.
Merton Abbey took me comlletely by surprise, but it makes sense: closed to passengers in 1929 but remained open for freight. It's one of very few SR stations that might have had that amount of coal traffic.
The line to Tooting Jn was disconnected in 1934 (says Wikipedia, linking to www.disused-stations.org.uk) and the layout rationalised in 1935.
The photo is therefore no later than 1935, and could well have been taken post 1929 (or 1917-23) to give the impression of the station being closed.
Mrs Humm
24 Sep 2019
Always happy to help or mislead, and a good distraction from watching the news...
The Midlands was the nearest large coalfield to London so I don't think Pinxton at Merton Abbey would have been unusual. An alternative explanation is that it's after the start of WW2, when all private owner coal wagons were pooled so they could work from anywhere to anywhere. The former situation was never restored, the survivors passing to British Railways in 1948. The photo can't be much later than that, as BR started building steel bodied replacements in large numbers (don't remember the date of this) and none of these are visible on the photo.
Anything is better than the news.
The mechanics of the distribution of coal must have been complex, I've no idea how it actually worked and I'm interested to see how far from home the Pinxton wagon had travelled.
As to the wagons, Robert thought the same as you, but added that it couldn't be very long after the wagons were pooled because the boards on coal wagons were frequently damaged and replaced; after the WW2 pooling the owner's name was never filled in on the new boards, and there didn't seem to be any new, blank, boards on the wagons in the photo.
Ash Bridge
17 Mar 2014
Stockport
To be absolutely honest I was sticking to the same Nottinghamshire/Derbyshire and surrounding environs as seemingly everyone did. After 4 hours or so I was on the verge of giving up except that I decided to have a final peruse of earlier postings on the thread and noticed that #5 from @edwin_m mentioned the Southern style signal post on the righthand platform. My thoughts then turned to LSW lines and initially some of the more rural stations e.g.Semley on its West of England mainline, this was soon discounted as there is curvature on the platforms, but to cut a long story a bit shorter this did eventually lead me to Merton Abbey. I must just add that I'm fairly certain I have seen this or at least a very similar shot in a publication somewhere before, so will now have to check my collection to confirm, anyway very glad to be of assistance.
Mrs Humm
24 Sep 2019
Thank you, that brackets the dates very closely.
Mrs Humm
24 Sep 2019
Thanks again for your effort, we are greatly indebted to you. When I posted the photo on Twitter I mentioned that the station wasn't Pinxton, to save people wasting time on it. Instead everyone reckoned that it must nevertheless be local to Pinxton so for Railforums I didn't mention it. But one man noticed the signal post and suggested the Southern; to my great shame I passed it by without comment - everyone was so sure it was the Midlands or North.
Sprinter107
26 Mar 2019
That station is Hall Green. View towards Stratford.
Sprinter107
26 Mar 2019
Forget that last post. Thatll teach me to look at the photo properly. Theres a very similar one I saw a few weeks ago, but was of Hall Green, but it's not this one.
