What's the fastest way to...
TSR :D
19 Nov 2011
Go from Southall to Central London, somewhere near Goodge street tube station?
There are two routes I want to take, one with NR, one without NR.
Without NR option, do I really have to take bus to Ealing? Is it faster to take it to Hounslow or somewhere up north?
Also, is it true they say, you move 1 metres every 10 minutes on traffic at rush hour in London?
LexyBoy
23 Jan 2009
North of the rivers
With NR it'd be train to Padd then cycle (if you're fastish) or Tube.
Without NR, private helicopter would be the fastest realistic option.
Urban Gateline
8 Mar 2011
NR - to Paddington would take around 17/18mins, then get the tube onwards from there if you need to.
Yes, traffic is slow in Central London at rush hour, that is to be expected as everyone is trying to get somewhere!
TSR :D
19 Nov 2011
On option 2, without NR, tubes can be used.
What's fast way to travel from padd to somewhere near Goodge street and Euston? Is it another NR or tube?
EDIT: Sorry for looking like an idiot for not using TFL's planner, but I don't trust planners as you sometimes can go faster than what it says. Once, it said it would take 1 hour to make a journey, I took 15 minutes using completely different route.
Urban Gateline
8 Mar 2011
How about Paddington to Queens park using the Bakerloo line, then London Overground from there to Euston?
The estimated time for a tube journey in the TFL Journey Planner is only so long so that minimum connection times are adhered to, otherwise I'm sure people will hold TFL liable when they miss their NR departure when there's service problems on the Tube!
LexyBoy
23 Jan 2009
North of the rivers
Tube. Circle or H&C specifically, or Bakerloo and then Victoria. Or Central from Lancaster Gate to Tottenham Court Road, depending exactly where you're headed.
RJ
25 Jun 2005
Back office
The TfL Journey Planner is more realistic although some would quite justifiably describe it as optimistic.
TSR :D
19 Nov 2011
Okay, now I know the NR way.
Now, is there quick way to do it without NR but with tube? Is it better to go to Ealing, Hounslow, or somewhere up north of Southall?
Please take bus journey times while in rush hour into account.
And with TFL planner... No, I've even gone quicker than all minimum connection times combined.
Deerfold
26 Nov 2009
If you want to avoid NR I'd suggest the 105 to Greenford and the Central Line to Tottenham Court Road. Then either the Northern line or walk to Goodge Street.
I'd expect it to be slower then NR to Paddington but not horrendous.
Mutant Lemming
8 Aug 2011
It does depend whereabouts in Southall you are heading from as well.
From the Town Hall the 607 "Express" is given around 20 minutes to Ealing Broadway in rush hour (half that early mornings) and then it's Central Line to TCR and Northern Line or walk as above. If you are east of Southall or near the Ealing Hospital then the 607 (even with the traffic) shouldn't be too much of a problem.
DaveNewcastle
21 Dec 2007
Newcastle (unless I'm out)
I'm with LexyBoy on the use of a bike!
Its fairly easy between Paddington and Kings Cross using the dedicated east-west cycle lanes running parallel to Marylebone Road/Euston Road but just a couple of blocks to the south.
I've often cycled from Ealing to Paddington, usually via Shephers Bush (which can be as fast as the Tube or bus and usualy faster) and in a rush I've gone flying down the Westway (with all large vehicles being overtaken in the peak), there's a little climb up to Notting Hill, but its all very easy. And quick.
MikeWh
15 Jun 2010
Crayford
Can I be nosey and ask why you specifically want to avoid NR? The reason I'm puzzled is that the most obvious answer would be to avoid the zone 1 Oyster premium for mixed mode journeys, but Southall to Paddington is charged on the TfL rate, so the premium doesn't apply.
TSR :D
19 Nov 2011
No, that wasn't the reason. It's freedom pass with 9:30 restriction.
