What value do the through lines at Lancaster have?
P5 is too short. 171m
Ah, my memory fails me then, I thought it was the full length of 4.
Having done a quick aerial view it doesn't look 94m shorter than 4 (which is at least 265m to fit an 11 car Pendolino). I guess it is about signal positions for a reversal? Nonetheless it also looks like it would be very easily extended at the south end to be exactly the same length as 4. Using cars nearby as a guide (assuming them to be 4m long which is fairly average for a car) it looks to be physically maybe 20-30m shorter.
Edit: there is a 156 visible in 5 on Google Maps, using that as a guide it looks to be about 25 m.
randyrippley
21 Feb 2016
If you need an extra platform, just reopen and extend P6
It's been sitting unused since electrification, and possibly since Green Ayre closed
Room at both ends to extend, whereas 4&5 are limited
5 is the shortest of the through platforms: I remember a dead mk3/DVT/motorail set coasting into it, blocking the pointwork at both ends.
Apparently 4 would have been clear
Northampton
You know on Google maps you can right click and measure distance directly?
Is there room to put the pointwork and signals in for the additional line?
That I did not.
I get 23.56m as the difference between the two southern ends and there's nothing I can see in the way of extending. Though the shape of the curve could mean the difference is slightly longer, but not 90-odd metres - that must be because of the signalling.
Northampton
That I did not.
It's a useful tool, although of course not 100% accurate.
The signals are quite far back, although it may also be because of issues for despatchers sighting the length of the trains. Having had a look at some of the photos from the platforms, it seems that any rebuilding would be contingent on rebuilding the road bridge south of the platforms. I don't know Lancaster very well, but looking at the map it seems that would be incredibly disruptive and therefore expensive.
randyrippley
21 Feb 2016
.................... it seems that any rebuilding would be contingent on rebuilding the road bridge south of the platforms. I don't know Lancaster very well, but looking at the map it seems that would be incredibly disruptive and therefore expensive.
closing that bridge would cut the town in half, the alternative routes are all height or weight or width restricted
HS2 were fag packet looking at the north end.
north end has space on the east side, where the remnants of the curve to Green Ayre still exists. You're limited by the embankment for the bridge, but there's enough room to feed a track into P6
Ianigsy
12 May 2015
I would imagine that to an extent, the through lines at Lancaster make it easier to prevent or relieve congestion at Preston because anything that isn’t due to call at Lancaster doesn’t have to wait for the platforms there to clear.
It would be P5 they extend.
You could add 23.56m by simply filling in the hole in what's there! Look at the Google aerial shot. It's nice and wide there too, quite narrow at the north end.
HS2 will almost certainly be DOO* so curvature doesn't matter, you have a camera on each vehicle. I don't think it's curved enough to cause excessive stepping distances.
Extending north instead seems bizarre.
* With OBS, stewards or somesuch, but the driver is almost certain to be the one operating the doors.
Northampton
Have a look at the pointwork. You'd need to move or get rid of the overrun at the north end and the engineer's sidings at the south end. Not insurmountable by any means, but a potential cost and possible operational complication.
What's the reason you can't have pointwork on a platform here, as some others do have it e.g. those with mid platform "overtakes" like Chester P3? Is it risk that something might overhang and whack it?
FWIW on looking again it looks like 4 was extended fairly recently, possibly for 11-car Pendolinos, and 5 left alone. The paving stones are a different colour.
Northampton
The overhang is one problem, although hardly unsolvable (York Platform 3/4 has a mid platform switch, for example). It's also about where the overlaps end up. At Chester, the lines are already very low speed and you can set flank protection for most routes on P3. At Lancaster if the overlap fouls the main lines it will have a significant capacity impact on the 125mph railway as they will have a 2-minute timeout before the road can be reset.
The south end was re-modelled in 2013 which allowed down trains into 4 and 5. Up Goods was upgraded to passenger standard and the up crossover out of platform 3 was upgraded from 15 to 40mph.
However the upgrade to 40mph was obviously a cost limited partial upgrade, as it is less than speed modern passenger stock can accelerate and decelerate when stopping at the platforms.
Having the loops helps timetabling, so ideally should be kept, but having to crawl through speed restricted junctions wastes time. But sometimes got to widen the formation to put in long turnouts and have loops that can hold 775m long trains.
If you are coming out of 3 on the up chances are you arent going to get much above 40mph anyway so its moot. Any faster and a new crossover may not have fitted. Anything on the down into 4 or 5 would likely be facing a red so again not a lot of benefit.
Some guy
6 Feb 2022
Preston
All of the TPE Manchester services stop except the long standing 1010 from Manchester Airport. A few Liverpool ones don't and a few that aren't currently running, such as the 2212 from Edinburgh to Manchester Airport, which may or may not return.
As far as Avanti West Coast goes they've already acted since franchise start to add the Lancaster call to the 1030 London Euston to Glasgow Central. The 1330 does not stop but again this is because of a lack of time. You could say it may be able to call at Lancaster in place of Oxenholme Lake District as the Windermere service has a connection there instead so this would be preserved but that doesn't mean it is easy.
The 10:30 still used to be express from Preston to Penrith even under Avanti as the Euston- Birmingham- Glasgow behind it served Lancaster and oxenholme but that’s been canned due to Covid so they managed to path the 10:30 to serve the both. In the done direction the 10:00,14:00 and 16:00 Glasgow to Euston via Birmingham never stopped at Lancaster
Starmill
18 May 2012
Bolton
The change was planned in for the 1030 for May 2020, in addition to the service from the West Midlands. Of course, the May 2020 came and went in various stages of disarray so it never actually ran.
If next year or the year after the two-hourly service between Glasgow and the West Midlands is restored I would hope to see the 1030 keep its call.
Some guy
6 Feb 2022
Preston
If it does the 10:30 calling patterns would most likely be Lancaster, Penrith, Carlisle and Glasgow with the one behind service stopping at Lancaster, oxenholme, Carlisle, Motherwell and Glasgow
