What stations see every freight operator have regular trains pass through?
mumrar
26 Sep 2008
Redditch
I know that Nuneaton does, but was just wondering how many others have freights operated by all FOCs - DBS, Freightliner, GBRf, Colas and I think that's it (I'll correct if anyone adds some).
Edit : added DRS and Stobart Rail too
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
Direct Rail Services?
Stobart Rail?
matt
30 Jun 2005
Rugby
Stobart Rail is not an FOC. The trains are operated by DBS (previously DRS)
Daimler
5 Feb 2009
Hertfordshire
Wouldn't most stations towards the southern end of the WCML count?
As far as I can think, all five mentioned companies run trains down here...
imagination
3 Aug 2010
There's Mendip Rail too, which I believe doesnt share any of its routes with all other freight operators.
So the question's answer is "none".
rail-britain
12 Aug 2007
Surely it would be possible to see all these FOCs at Reading, albeit rarely
It is quite easy to see all the other (excluding Mendip Rail) between :
Preston and Wembley (WCML)
York and Peterborough (ECML)
From memory I managed to see them all at Doncaster within just 1 hour of arriving on my recent trip
Darandio
24 Feb 2007
I've seen them all at Northallerton, the ones mentioned in the OP anyway.
imagination
3 Aug 2010
I've never seen a DRS train at Reading station, and I've spent a LOT of time there.
mumrar
26 Sep 2008
Redditch
The title I put was about regular appearances, as in work diagrammed for at least one day every week (excluding engineering work) if that helps clear some up.
matt
30 Jun 2005
Rugby
There has. From the Class 37 LG.
Can't imagine you were there at that time of the morning though. :D
The test train would have not been operated by drs.
Also Colas no longer regularly go through Reading.
mbonwick
26 Oct 2006
Kendal
Lancaster and Preston see all the operators mentioned, bar Mendip Rail obviously.
Tugzrule
30 Jun 2009
Carlisle
What GBRF workings go through there, the mail trains are DBS? Carlisle at present has the main ones (although the Colas logs are not currently running)
mbonwick
26 Oct 2006
Kendal
GBRf did have a couple of coal trains, although the latest gen I have hints that these may now go via the S&C/not run....
DRS, DBS and Freightliner all have intermodal and coal. DRS also have the nuclear flask as well.
Colas have the logs.
Mr Spock
14 Jan 2008
Watford or perhaps that should be Bushey - Wembley has all (or did) freight operators.
Freightliner, DBS, DRS, GBRF, Colas (if it still runs) and Mendip runs trains to Watford sidings.
matt
30 Jun 2005
Rugby
I would say Stafford is a very good shout
Plenty of EWS, F-Liner, DRS passes through as well, not sure about DBS
If not Stafford, Bescot Stadium is a good shout as well
EWS is now DBS. Colas don't operate through Stafford or Bescot. Mendip also don't.
