They are check rails, fitted where there are sharp curves to prevent derailments as the wheel flange will be held in place
In that instance, I think they are a bit further from the rail to catch the whole derailed wheel rather than just the flange (doesn't prevent the derailment but is extra insurance against the vehicle going over the bridge side).Think they are also used on bridges/viaducts to reduce the risk of the train coming off the bridge if it were to derail.
You're thinking of guard rails and there would be two.Think they are also used on bridges/viaducts to reduce the risk of the train coming off the bridge if it were to derail.
At Stratford station you can see check rails on the inside and outside of both running rails for a short distance. Whats the point of the outer one. Couldn't find a pic but you can see them on the video below at about 7:10. The video was filmed in 2012 and these same rails were there last time I was at Stratford about a year ago.
There is a bridge under the railway here - not sure if it's one of the subways or the DLR. It's a bit hard to tell but I think these are part of the bridge deck rather than check or guard rails. There are none on the other track but that deck may have been replaced with one that allows ballasted track to be laid on top of it, which is the preference where possible.At Stratford station you can see check rails on the inside and outside of both running rails for a short distance. Whats the point of the outer one. Couldn't find a pic but you can see them on the video below at about 7:10. The video was filmed in 2012 and these same rails were there last time I was at Stratford about a year ago.
Yes, its a subway underneath. Couldn't understand the point of a check rail on the outside of a running rail but I guess it could well be part of the deck below.There is a bridge under the railway here - not sure if it's one of the subways or the DLR. It's a bit hard to tell but I think these are part of the bridge deck rather than check or guard rails. There are none on the other track but that deck may have been replaced with one that allows ballasted track to be laid on top of it, which is the preference where possible.
or protecting the big protruding girder that forms the subwayCheck rails protecting the subway beneath I would assume.
What's the technical term and purpose?
Thx
