What is that Handle on a Bus For?
whhistle
30 Dec 2010
Hi all.
I'm talking about this handle:
(large and white)
(grey)
Usually on the right hand side of the top deck.
Any ideas?
Thanks
WatcherZero
25 Feb 2010
Yes, obstacle deflector as its only on the one side, have seen some buses add a rollcage there as well, often just inside.
newbie babs
16 Jul 2011
Sheffield
I would say the double deckers in Sheffield need these, they are forever hitting the trees that stand out too far. Although Sheffield does not have anywhere near as nice as the buses as you seem to have whhistle
mbonwick
26 Oct 2006
Kendal
I would hardly call the LT class of vehicles nice! Horrid, horrid things.
Does First not have Wright Eclipse Geminis in Sheffield?
newbie babs
16 Jul 2011
Sheffield
They are probably on the more popular routes, we have when we have double deckers the old version that don`t have the metal bit at the window to stop the branches hitting the window.
jon0844
1 Feb 2009
By having those two photos above/below, it makes me wonder why the hell we needed some crazy design and not just the 'normal' look like seen below. You could still have had a different internal layout but not the odd look, with crazy lights and all the ingredients for something that looks 'out there' today and totally stupid tomorrow.
jon0844
1 Feb 2009
Do they go down narrower streets where there might be stray branches from both sides?
Or maybe we don't have them on both sides in London due to the cuts!
mbonwick
26 Oct 2006
Kendal
Nothing to do with the routes, it's just the design of the ADL E400 that has cantail protectors on both sides.
WatcherZero
25 Feb 2010
To be honest looks better symmetrical, cant be that expensive to fit on both sides, what 20-30 quid?
jon0844
1 Feb 2009
If buses are anything like trains, you probably need to multiply that by a hundred!!
whhistle
30 Dec 2010
Thanks for the responses.
I do find it strange that they only have it on one side though. Do designers presume as the driver sits on the other, then they will be able to swerve to avoid low hanging trees?
jon0844
1 Feb 2009
I am pretty sure that in London, most branches sticking out (bearing in mind trees are cut back to prevent things hitting buses, lorries etc) would only reach the bus on the left hand side. It would be one seriously long branch to hit from the right!
ChrisCooper
7 Sep 2005
Loughborough
I think the main reason for them being fitted is that modern double deckers have larger front windows, often reaching right to the sides and top, even with some wrap around. That makes them very vulnerable. On older buses the main points that would get hit were fibreglass which was pretty strong or metal which could be knocked out if dented. IIRC the first buses to commonly have them were the Alexander Royale and the Northern Counties Paletine 2, both of which had very similar wrap around top deck front windows. The old ECW coaches didn't tend to have them much though, despite having very big front windows. Perhaps the sort of work they did meant they were less likely to hit trees. They were also designed in the days when councils still did bother to keep trees cut back.
Schnellzug
22 Aug 2011
Evercreech Junction
back in the old days when companies were allowed and could be bothered to do things for themselves, bus companies had their own tree Loppers, converted double deckers that went round bus routes and chopped off overhanging branches. Now they wouldn't be allowed to do that because of health & Safety and Conservation.
driver9000
13 Jan 2008
Tree guards are fitted on the nearside as that is the side most likely to come into contact with a tree in an urban setting. The offside would naturally be next to the centre of the road and oncoming traffic so less likely to strike trees. That is certainly the case in my experience of driving double deck buses in towns and cities and even in rural areas it was always the nearside that would occasionally strike trees, not always possible to avoid them.
DaveNewcastle
21 Dec 2007
Newcastle (unless I'm out)
In addition to these deflectors, there are signs warning drivers (of high vehicles) about low trees on some roads - one good example is Kingsway in Central London, which is essentially a dual carriageway with 2 lanes in each direction, but where the outer lanes are busses, taxis and bikes. The profile of London plane trees leads to their branches reaching out from the nearside kerb only, at upper deck height. Double-decked busses regularly scrape past them.
I've seen these branches being trimmed of their new growth, but the large major branches are generally left in place.
[For anyone who knows what I'm referring to, does anyone else think that in December, the Lonon Plane's nut shells look like Christmas tree baubles?]
newbie babs
16 Jul 2011
Sheffield
The new ones (Eco friendly) that travel on 120 route in Shefield dont have the rail for stopping trees hitting them.
newbie babs
16 Jul 2011
Sheffield
That`s the one, I dislike that route as its one every 5 minutes.
They are much longer than the others I wonder if the one I saw was an earlier one as it did not have any, I stood in the middle of the road to view it
BestWestern
6 Feb 2011
If you mean Stagecoach's E400Hs, then they do actually have the protectors
http://www.flickr.com/photos/dwbphotos/6212161586/
As part of the E400 family, they have the protectors both sides swooping up to roof level.
They're nicely incorporated into the overall design of the bus on these, they look an awful lot better than some of the other efforts which are very plainly just a steel bar bolted on! There are some pretty nasty looking ones out there!
Bungle73
19 Aug 2011
Kent
Why do we need these now?
I travelled on London buses in the '80s and '90s and they were for ever bashing into the ends of branches, and didn't have any of those gubbins. There didn't seem to be any problem then.
The first picture is the new Routemaster btw.
Nym
2 Mar 2007
Somewhere, not in London
Because bus companies aren't allowed to trim trees any more and councils can't be bothered, never used to be large branches to **** into the windscreen before...
mbonwick
26 Oct 2006
Kendal
Plus, as Nym has said, the lack of tree lopping.
ChrisCooper
7 Sep 2005
Loughborough
Tree lopping was never as common as is made out. Municipals tended to do it, as they were owned by the council who also were (and still are) responsible for maintaining roadside vegetation. Out of the cities and towns though there were as many low trees as today. Then and now any tree that poses a danger to traffic will be delt with. Generally trees will be kept naturally away from the roofs of vehicles as the new growth is hit and broken off before it can become a problem. Most tree damage comes from branches that have been damaged and started to hang low, branches pulled down under the weight of rain or snow, or when vehicles leave the normal driving line at speed (one time when I had a big bang on a decker was because I was passing parked cars on the opposite side and a car decided to come around causing me to swerve left towards the kerb and into some branches).
