What is a "Planning Error"?
blakey1152
5 Sep 2011
I saw an unusual tweet the other day from Southeastern. On the 2nd February at 1.12am they tweeted that due to a planning error the 00:53 Charing Cross-Gravesend service will terminate at Dartford. Passengers for stations to Gravesend from Dartford please speak to staff for onward travel. Sorry for an inconvenience caused by this.
There were a few responses, worryingly the driver failed to announce that the train was going to terminate at Dartford according to one passenger one the train and there were also concerns about there actually being any staff there when the train actually arrived.
Can anyone enlighten me as to what is a planning error as its the first time I've seen any TOC use this as a reason and why couldn't the train continue on to Gravesend as planned?
24 Nov 2019
One likely scenario - especially at that time of night - is that an engineering possession came into effect which prevented the train from continuing beyond Dartford.
23 Jan 2013
East Anglia
Can be all sorts of things. Here are a few examples.
Engineering possession planned incorrectly.
Possession limits incorrect
Electrical isolation incorrect
Booked train not amended to take account of possession
Additional train booked through a possession
Two trains timed to clash with each other
Platform occupation not planned correctly
No unit diagrammed for service
Booked unit diagram not amended to account for timetable alteration.
No train crew diagrammed
Booked traincrew diagram not amended to account for timetable alteration.
No traincrew rostered
Traincrew rostered but without required route or traction knowledge
And so on. ‘Planning error’ in the Control log is the worst thing a planner can see, and usually results in a stewards enquiry of some sort, if only to ensure it wasn’t your fault and that it isn’t repeated.
SlimJim1694
8 Jan 2020
Medway
The drivers diagram probably said Dartford while the public were told Gravesend so he's not necessarily going to know there is an issue and announce it. I've had it plenty of times where my schedule doesn't match what the passengers are being told.
Also Dartford is staffed 24/7 so no issues about it being unstaffed.
43066
24 Nov 2019
Or the driver would have been unaware until he stopped at Dartford on a red and was told the train was terminating.
The driver is often the last to know in these situations!
TUC
11 Nov 2010
Would station staff routinely be alerted so that they know they will need to support and advise passengers?
Aictos
28 Apr 2009
Usually last minute, I've used TL before when this has happened for example a Bedford bound service was due at St Pancras and the screens advertised it as running slightly late due to a passenger being taken ill. The screens only changed to show it running fast from Parkway when the train in question was coming into St Pancras which is poor.
Is that always the way?
TheEdge
29 Nov 2012
Norwich
Except in emergencies, some local instructions and a few other situations that can be dealt with by berth triggered broadcasts the only way messages get to drivers is either via a conductor (if available) or when they get called by a signaller once we get stopped at a red.
Oxfordblues
22 Dec 2013
I committed a planning error once. Whilst working at the Railfreight Distribution Train Planning Unit I failed to divert the Maritime - Ripple Lane Freightliner via Reading to avoid a possession on the Southern. The train was severely delayed and I was severely reprimanded. I never did it again!
Romsey
30 Nov 2019
Near bridge 200
The trouble is that once something has appeared on a control log, there is no right of reply even if you did everything correctly!
That is the only gracing feature of delay attribution as a train or access planner it was possible to dispute what happened if you had clear evidence that your plan was correct. Then there was the problem of all sorts of other unconnected delays which were dumped at random into your TIN. (OK, so why should I accept 10' consequential delay at Ramsgate which happened before mis-interpretation of the possession limits at Southampton? )
43066
24 Nov 2019
They should be, unfortunately communication isn’t always the best on the railway, whether it’s with passengers or staff.
Not always, but certainly more often than not.
Ashley Hill
8 Dec 2019
The West Country
Spartacus
25 Aug 2009
Seems at the moment like this one was a short notice possession at Dartford that failed to notice that it would affect services due to a combination of platforms under possession and units berthed in other platforms.
