What if colour-light signalling never happened?
fwsmVor
27 Aug 2021
London/Berlin
Suppose that in one of the earliest colour-light schemes, a horrific accident was caused by faulty wiring, so that parliament passed a knee-jerk law saying that all signals must be semaphore forever. Would we have seen the more widespread adoption of 3-position semaphores? Would they be made bigger, to enable 125 mph running? Would the drawbacks of motor working mean the survival of little mid-main-line boxes with no points to control, to get more block sections on e.g. the ECML, or is there some "could have been" technology that makes long pulls obsolete but came too late to be implemented?
I imagine we might have seen more experimental systems in place. Perhaps main signals in the form of an old-style electromechanical banner, or even companies/BR/NwR skirting the line by making the board smaller and the light brighter.
Railsigns
15 Feb 2010
The big problem with the hypothetical scenario described is that three-position semaphores and electro-mechanical banner signals are just as dependent on electrical wiring as colour light signals are.
stuu
2 Sep 2011
What would have happened is that parliament would have repealed the law once they realised how costly/idiotic it was in the first place
Northampton
Banning colour light signalling would presumably have also banned the use of Semaphores at night.
TSG
10 Aug 2020
Somewhere in the South of England
If we work on the assumption that this law is in place by about 1930, in the medium term I suspect you might have seen more compressed air driven equipment. This could extend the reach of mechanically locked signalling without necessarily having to tame those pesky electrons. In the longer term (say 1960s onward) , the case for rolling out a standard cab signalling system sooner would have been much stronger. Inevitably this would have involved electrical, electronic or perhaps even early processor equipment. To convince a wary legislature to allow this perhaps system safety engineering techniques may have had a bit more impetus in the rail industry sooner.
The interesting question here is, if they didn't trust colour light signalling, would they have allowed reliance on track circuits for train detection? Even absolute block really needs electrical circuits though.
EDIT: There's a thought. Did anyone ever drive compressed air valves from depression bars?
Still a colour aspect displayed by night. Also plenty of conversions to electric lighting at various times.
An electric lamp circuit though, not a safety critical control circuit.
dggar
16 Apr 2011
If the electric lamp circuit fails the driver will not see what aspect the signal is displaying.(at least until the train is almost at the signal)
mike57
13 Mar 2015
East coast of Yorkshire
I think the thing to remember is that any 'human driven' system can still go wrong when the human gets it wrong, and this will be a more frequent occurance than the wrong side failure of a well designed electrically interlocked system. So after a few more major accidents involving human error I suspect the original laws would be quickly repealed.
As for installation errors, they could happen on any system mechanical or electrical.
Anything which moves from the purely human powered mechanics is going to need motive power, be it air, electicity, or maybe hydraulics, and the potential to 'get it wrong' still exists.
ac6000cw
10 May 2014
Cambridge, UK
To be practical, the absolute block system has always required electric telegraph connections between signalboxes (in some form or other). Before the electric telegraph was developed, time interval working was the norm - which is effectively a form of permissive drive-on-sight working as there is no way to know if the previous train has actually reached the next station, unless a message to that effect is carried back by a train in the opposite direction.
Of course very basic 'token' working used on single lines where there is literally only one token in existence per section is 'absolute block', but that is very inflexible.
So really, almost any form of 'modern' railway working needs fast remote communications between 'train control' locations, and I think electrical communications are by far the easiest method of providing that.
If bright enough light sources had been readily available when fixed signals first came into use, would semaphore signals ever have been used (as they need lights for night time use anyway) - would they have just gone for mechanically operated colour lights instead?
MarkyT
20 May 2012
Torbay
Complex pneumatic systems might have a similar risk of incorrect connection as wiring, if that was the nature of the initial problem prompting the ban or restriction.
Onboard systems for cab signalling are unlikely to be electric wire-free, where similar 'faulty wiring' problems might apply. I suppose a mitigation might be that most of the complex wiring would be in standard sealed factory-tested modules.
If the issue is complexity rather than the use of electricity per se, track circuits are relatively simple systems. Similar with block bells and instruments. Would telephones be allowed?
No idea! Probably wouldn't be practical or cost-effective for train presence/absence detection over longer distance
A main aspect lamp circuit is safety-critical in that the filament is proved to be drawing power, and hence assumed illuminated, using a failsafe current sensing relay in series with the load. The relay contacts are used to switch panel status indications in the signal box and are checked in the circuits for the signal in rear which can only show proceed if the signal ahead is proven alight. An earlier oil lamp equivalent used a bi-metalic strip to detect the heat of the flame and switch an electrical status indication circuit.
London Underground took some time to adapt to the wholly electrical interlockings used increasingly on the main line network from the 1950s. They stuck resolutely with mechanical interlockings even into the 1970s using remote-controlled, pneumatically actuated interlocking machines that processed the bulk of the more complex control logic. There was limited relay circuitry clearly to take the outputs from these contraptions and drive colour light signals and point drive circuits (the points themselves were typically pneumatically actuated), as well as electric solenoid locks proving track circuits clear etc, but the most complex wiring was avoided. A common design of this type of machines was the Westinghouse style V frame that used rotating shafts driven by pneumatic actuators. In event of failure of the local punch tape sequence machines, an early form of automatic route setting, and remote control telemetry, the shafts could also be operated manually under instruction from the control room by local operating or technical staff. LU also didn't trust those new-fangled 'miniature' relays adopted by BR, preferring much larger traditional shelf types of a design colloquially known as 'fish tanks'. LU interlocking machine room wiring is also typically much better insulated and protected from mechanical and other damage than the types used by BR.
Description
This machine replaced the lever frames used by signalmen. Its function is to ensure that there is no conflict between the routes set by the points and the signals. This is done both mechanically and electrically. The levers on the front move sideways instead of fore and aft and are normally moved by compressed air, being controlled by the signalman operating a push-button panel. If the air supply were to fail, the signalman can go into the Interlocking Machine Room (IMR) and operate the levers manually. The moving parts of the machine are physically connected so that it is impossible to set up conflicting routes and signals. If a fault occurs in the control system, the mechanical interlocking provides the final line of defence.
eldomtom2
6 Oct 2018
It's worth remembering that semaphore vs. colour light signals and absolute block vs. automatic block are two separate things that aren't necessarily linked. You can have colour light signals in an absolute block system and semaphore signals in an automatic block system.
