sheff'd victoria
Take The Woodhead Line when it closed
Rails , Signals , Equipment.
Are they re-used on the network or just sold for scrap ?
I know that the track from the woodhead route was used at birmingham on the snow hill linesDepends on lots of things to be honest, and the nature of signalling equipment.
Primarily a lot depends upon how much money there is in the Project pot.
Take a mechanical line. The signal arms will always be recovered, the lamp cases, and balance weights/arms as well to go as strategic spares.
The signal post and ladder would be cut down at ground level.
Signalboxes would have their operational equipment recovered, and depending upon the age and nature of the box it will either be recovered for re-use,or prerservation, or it will be demolished because of the risk of misuse.
On a colour light line the signal heads and ladders would come down, as would the post if it is bolted. It not bolted it may be left in situ or cut at ground level.
Location cases are gutted but not always recovered as the costs against that are too high.
Track is almost always recovered now and used for sidings or low class line or disassembled and the various items placed into the stategic stock or sold on for scrap.
Recovering old cable routes used to be too expensive against any scrap value so there was a sort of unwritten code that the pikies would wait a reasonable time and then do the recovery.
OHL equipment is always recovered for re-use, and the wire has to be recovered as it is classified as hazardous waste and has to be disposed of appropriately.
That perhaps gives you a more broader idea. Of course with the current economic climate, a more considered view will be taken on the value of all scrap materials against the cost of their recovery.
Hope this helps.
