What happens to sentinel & PTS after leaving NR?
Doorbit
11 Oct 2020
Paddington
I’m facing a disciplinary hearing in the coming weeks & wondered what happened to my sentinel & pts if I am sacked? (It’s not for drugs and alcohol )
henke7
13 Sep 2018
Network Rail is your sponsor, so I’d assume that you would lose your competencies and if you were to say go contracting then they would sponsor you.
Doorbit
11 Oct 2020
Paddington
Can they ban your sentinel for a time period? My pts has been suspended currently pending investigation,
henke7
13 Sep 2018
Network Rail own and run Sentinel so I assume they could ban it yes, however its useless without your PTS being in use as that will supersede every ticket on your card. If you were to move to a contractor, they would have to apply for a sentinel card to Network Rail then put you through a PTS again. The best people to ask about this would be a union rep who will be able to give you more accurate information.
transportphoto
Jobs & Careers
Quizmaster
21 Jan 2010
It’s worth a mention that this forum is not as anonymous as you’d expect. An employer can very easily work out who you are based on what you have typed.
This post could be seen as an attempt to potentially bring the employer into disrepute.
Whilst you/we cannot delete anything that has already been published, please bear this in mind for further posts.
Class15
30 Dec 2021
North London or Mildmay line
While deleting what has been published is not possible, it should be possible to edit the posts to remove revealing information. Of course the employer may have already seen the posts in which case it’s obviously too late but otherwise it would be possible.
Northampton
There are also callback/archiving services. It is good practice to consider posting online the same as handing a physical copy of the information to a stranger. You can ask them to delete it, but you don't know they haven't made other copies in the meantime. Almost anything posted online can be retrieved with sufficient effort, even after deleting or editing.
OP has done what they can now.
