What does this sign mean?
22 Oct 2013
Lincolnshire
I have searched about for the meaning of this sign but cannot find a clear answer. The image shows this sign near to the entrance of Whitby station. I've noticed this sign before, near level crossings. To me it looks like something to do with signalling, but to be honest I don't have a clue! Can someone tell me what it is and what is the name for it?
Thank you :)
transmanche
27 Feb 2011
Thank you :)
I believe that's a 'semaphore-style' distant signal fixed in the caution position. It means that the driver must expect the next signal will be at danger (i.e. a red signal).
Cherry_Picker
18 Apr 2011
It's s fixed distant. There is one visible from the platform at Stourbridge Junction on the Town branch.
Mugby
25 Nov 2012
Derby
I suppose you could say it's a cheap and convenient way of exhibiting a fixed distant signal rather than maintaining an old signal post with an arm on it. Being reflective, it doesn't require a lamp during the hours of darkness which an old style signal would.
contrex
19 May 2009
St Werburghs, Bristol
Fixed distants are to caution drivers that they are approaching a signal they can expect to encounter at danger, and that they need to get their speed under control accordingly. Essentially to help a driver to recognise where he or she is, in a consistent standardised way. The GWR was fond of them. I read about an ER driver who had transferred to the WR and thought there were far too many fixed distants. "You have to dither about like a old biddy here, that's why I call it GREAT WOMEN'S RAILWAY!"
driver9000
13 Jan 2008
Just to be pedantic the Fixed distant applies to signals and any other location a driver must stop such as the end of a branch line for instance.
Andyjs247
1 Jan 2011
North Oxfordshire
Those fixed distant boards are also quite common on lines such as Far North, Kyle, Cambrian etc approaching passing loops where the driver would be required to stop and obtain the "token"/authority to proceed. They were introduced when RETB signalling was introduced and traditional signalling abolished. BTW do they still exist on the Cambrian? I haven't been that way since ERTMS.
Sir_Clagalot
9 Aug 2007
There are several on the East Suffolk still, most seem to have gained signal numbers as well during the resignalling
aal7
16 Oct 2013
There's on on the disused Varsity line, between the Steeple Claydon level crossing and the junction to Aylesbury. I saw it on Saturday!
TDK
19 Apr 2008
Crewe
There is one each way on the branch from Wrexham General to Wrexham Central, also one on the approach to Llandudno
D1009
22 Feb 2012
Stoke Gifford
One has been temporarily fixed to the non functioning signal on the up in the middle of the recently flooded section between Cogload Junction and Bridgwater, to indicate approach to the end of the temporary block section.
TOCDriver
24 Jan 2013
There are a couple of beuties on the approach to the Heysham branch line approaching Morecambe station from Bare Lane
Lockwood
4 Apr 2013
I saw one while I was at Ribena, waiting (and waiting) from a train to Cardiff last year.
Railway guy on the platform who was advising everyone not to bother waiting, and to get a bus, said it was because the line ended not much further up.
It had an AWS ramp as well, with an ignore AWS board the other direction.
It was nice to see those signs - don't seem to get stuff like that down this way.
andypops
31 Mar 2011
Rhiwbina?
It's on the Coryton sine - see here - and is two stops from the terminal station at Coryton. So it's understandable to have a fixed distant there.
As an aside, presumably, I would imagine at this location and at Whitchurch (next station), the driver should be using his DRA?
Erm, I tend to disagree.... The WR had lots of odd little nuances, several of which have remained. And as an earlier poster has said, these signs are reasonably common on the WR.
Lockwood
4 Apr 2013
Yeah, that's the one.
Sounded like "Ribena"
It was nice to see those signs - don't seem to get stuff like that down round where I am.
