What does this Mean ?
petethetim
16 Feb 2006
Belfast N.Ireland
I am in the Middle of creating another activity for Bristol to Cardiff route & just about 3 Miles from BTM I get a message failed to create sms object any idea what this is is it something to do with the route or a piece of stock used as AI or lose con?
Any advice help or suggestions as always greatly received.
me123
9 Jul 2007
i'm guessing you need to download an object pack of some sort, as i needed to do with this route. have a look on the UKTS forums, becuase someone somewhere'll have popped a lotst of the required packs on. Or even on the route download page or readme.
If you have all the object pack things, then I don't know what else could be wrong.
petethetim
16 Feb 2006
Belfast N.Ireland
Thanks for the reply
Its a Strange one ? Cause it did not occur on previous 3 testings of the Act & Route Riter shows no errors & no additional stock has been added :? , I will run it again after the run through route ritter to see if the problem has cured it's self
laseandre
27 Oct 2007
sms? They're normally sound files. I'd check all the sounds for the train you're using.
