Fastclip
www.pandrol.com/product/fastclip/Rail clips? They used them in my area for recent relaying work. There's a great little machine which can be wheeled along the railhead to push them in from both sides at once.
Pandrol Fastclip is an established, highly-regarded resilient, threadless rail fastening. Over the years, the Fastclip family has grown to include the FC, FD, FE Fastclip products, each of which has been designed to meet the technical and commercial demands of a specific area.
Fastclips lend themselves to much easier automation as the clips are pre installed when sleepers are manufactured
Long time since I was involved with perway, but a pre installed fastclip looks to be clear of the railseat, allowing rails to be dropped in without a problem. Other designs, like Pandrol, are driven into position parallel to the rail and will always be foul if pre installed.Fastclips lend themselves to much easier automation as the clips are pre installed when sleepers are manufactured
You can see a picture of them pre-rail here: https://railgallery.wongm.com/track-rail-sleepers/D938_3878.jpg.htmlLong time since I was involved with perway, but a pre installed fastclip looks to be clear of the railseat, allowing rails to be dropped in without a problem. Other designs, like Pandrol, are driven into position parallel to the rail and will always be foul if pre installed.
This is the best one from the EWR thread I think, there’s a quick shot of the clips being fastened at about the 57 second mark. There’s basically a group of four, ie two pairs, of large flat plates which push on the clips either side of the rail together:Somewhere on this site, probably on the E-W Rail thread, I've seen a video of a machine going along clipping the Fastclips.
Yes - Fastclips have a much higher toe load.
I'm new to this, but what exactly is the difference?Yes - Fastclips have a much higher toe load.
The e-clip in your picture has been superseded by the RE series clips that have a higher toe load but the insulation on both the pads and clip is different.
Different sleepers will have different fastenings set ups usually made up of pads, nylons / Insulators and fastenings /clips. All together they seat the rail correctly, maintain gauge (on concrete sleepers) and apply to toe load - hold the rail in place so it resists movement due to stresses from traffic and weather. Bit more to it but that is a very basic explanation.I'm new to this, but what exactly is the difference?
Yes. Although some types can be removed by using a sledge hammer, other types need specific tools. Fastclip type are not the only type that are very hard to remove without the correct tool.Is there any advantages or either type in theft resistance. I know the original 'bent wire' pandrol clip was easily stolen by someone with a sledge hammer.
Fastclips are easier to get out than put in with the right tool.Yes. Although some types can be removed by using a sledge hammer, other types need specific tools. Fastclip type are not the only type that are very hard to remove without the correct tool.
Yes, and also with similar tools, it’s possible to get a SHC clip out. The point being that it takes longer and is harder than using the specific tool.Fastclips are easier to get out than put in with the right tool.
welders manage with a wedge and small hammer..
I have been on many stressing jobs where we using hammers and nothing else. Not ideal but we cracked on. For fastclips the benefit is you can extract the clip far enough to free the rail without fully removing the clip.Yes, and also with similar tools, it’s possible to get a SHC clip out. The point being that it takes longer and is harder than using the specific tool.
