What are those train shakers at London Euston for?
JulienD
21 Dec 2025
Slough
I arrived into Euston a few days ago on a 730, I was in the front carriage and as we were coming to a stop the train started shaking. Looking at the tracks there were rumble strips on the tracks. What are these for? I haven't noticed them at any other London terminus!
Darandio
24 Feb 2007
Many would say it's to aid traction under braking to stop trains hitting the buffers.
It's not, it's to help train detection with track circuits. For instance, if trains didn't approach close to the stops for a while and the railhead got dirty or contaminated, a train near the stops in the future might not be detected.
The exile
31 Mar 2010
Somerset
Aren't they usually a way of ensuring that track circuits get activated where there is otherwise a danger that rail contamination means they wouldn't. Often at buffer stops so that the loco which had brought a train in but had been uncoupled from it would continue to be detected when its train had gone. Of all the London termini, Euston would have been one of the last to have that happen on a regular basis, so it probably just means that that track has been there for a long time.
Yes, a special alloy that doesn’t rust to assure that the track circuits operate.
I helped put them in.
AndrewE
9 Nov 2015
Eutectic Strips
Eutectic being what the railway calls them, whereas I think that they are just a special stainless steel chosen for its relatively low melting point, presumably easier to get to bond to the underlying rail steel. Having said that, I have seen places where it has come off...
(Wikipedia https://en.wikipedia.org/wiki/Eutectic_system shows that the rest of the world is unaware of this application!)
Taunton
1 Aug 2013
London Underground used to have more prominent ones in sidings, with a zig-zag-pattern across the rail head, but later seem to have given these up, they looked more like metal strips rather than a pattern applied with a welding rod. The sidings east of Farringdon, among others, were fitted with them.
Beebman
17 Feb 2011
Twyford
At Ealing Broadway there used to be a track connection between the District and Central Lines which had these prominent zig-zags. On 02/09/79 I was on a 1967 Tube Stock Railtour which traversed it and as might be expected it was a very rough and noisy experience!
Krokodil
23 Jan 2023
Wales
Manchester Airport has them, not a place which sees light locomotives on anything other than an exceptional basis.
DynamicSpirit
12 Apr 2012
SE London
Interesting. I don't ever recall noticing a train shaking as I arrived into Euston, and I would have thought that if trains did generally shake on arriving, that would be something that the general public would notice (To be fair, I'm pretty much never in the front carriage, which on Avanti would be the first class). Reading the replies, I'm also puzzled why a system to help train detection would make a train shake. Anyone care to elaborate on what's going on here?
DelW
15 Jan 2015
There's a zig-zag pattern of rust resistant weld metal (ref post #4) which means the leading wheels are running on a rougher than usual surface.
You would generally need to be in the front vehicle and quite possibly near the front bogies depending on the length of track so treated to notice anything. Even then I would suggest it's more of a rumble and vibration than shaking exactly.
There's a decent example of this on Reddit:
(Link to a Reddit thread which has a good image of the zig zag pattern that's been described)
Or standing on an adjacent platform as a train departs. The noise it makes is quite distinctive. (It’s more noticeable for departures, as the train is at higher speed)
Yes that's a good point, very noticeable when a train comes in or departs on track like that.
JulienD
21 Dec 2025
Slough
I was in on P11!
Sun Chariot
16 Mar 2009
My grey cells are happily transported back to seeing, feeling and hearing Euston's strips!
A sound etched in my memory as strongly as the class 310 EMU's "hiss-sigh" when its brakes were released.
I have a vague recollection of seeing the strips on Preston's south-facing bay - but I might be wrong on that.
CarltonA
22 Apr 2012
Thames Valley
I recall these strips on the turnback siding at Wembley Stadium, unfortunately the buffer stop got demolished by an errant train a while back.
Deepgreen
12 Jun 2013
Gomshall, Surrey
Waterloo used to have them at the stops on the low-numbered platforms, but I think they went with track renewal years ago. They used to cause a rumble, but no 'shaking'.
Lucan
21 Feb 2018
Wales
When I was there, London Underground had them towards the ends of less used but track-circuited sidings which were inclined to get rust on the railhead. They were just a zig-zag of weld bead for about a car length out from the buffers. It was to ensure the train wheels completed the track circuit. I don't think they were of stainless steel or anything else exotic because just the increased pressure (as in psi) of the train weight on the narrow beads was enough to ensure electrical contact got through. No "shaking" even in the end cab, just a rumble.
devon_belle
21 Jul 2022
Is this what Preston has on the bay platforms? I was there for the first time recently and the vibration / noise was very noticable on the train as well as from an adjacent platform.
Steddenm
2 Mar 2017
Clane, Co. Kildare
Carlisle has them on the Tyne Valley/Settle bay platforms and I think Manchester Piccadilly has them as well.
Don't all terminating platforms (ie non-through lines) have them or have had them in the past?
