What are these elaborate 'access panels' for?
Hughby
16 Nov 2014
Milton Keynes
First post after lurking for a while.
As well as being a Rail enthusiast I cycle/walk in the MK area which means I cross the WCML regularly. I often come across bridges with what appear to be access panels that make little sense (to me!).
Any ideas? They don't seem to pass through to the 'railway' side of the structure (see photos).
Hughby
HugePilchard
18 Apr 2011
Tyne & Wear
Looking at the pattern of them, they seem to be symmetrical around the circular plate on the sixth panel in from the right.
Unless someone knows better, I'd say that they're just there because someone thought it would look good.
I agree, looks to me as if this is a girder that has been plated over and there is a void behind each panel where corrosion might not be detectable otherwise.
However I don't understand why some of them need much bigger hatches. I would have thought that if one of them needs a hole big enough for someone to access (which seems essential if corrosion is found and remedial action necessary) then they all do.
How about this, although just a guess. Maybe they all started out with the small circular inspection holes, and as and when corrosion has been found in individual sections, then a much larger hole has then been cut to do that work?
Could be, although their symmetrical nature pointed out by a previous poster perhaps suggests something about the structure behind those panels that needs more attention.
mcmad
11 Mar 2015
Are the photos both of the same side of the bridge? Could there be services running in the void perhaps?
John Webb
5 Jun 2010
St Albans
I would expect from the rivet locations that there are vertical 'H' section steelworks linking the two sets of panels together, so there won't be a continuous void - hence no services but the need for every section to have its inspection hatch. Probably of Victorian design, they had a knack, often lacking today, of making the necessary look attractive, hence the different shapes and symmetry of the hatches.
Hughby
16 Nov 2014
Milton Keynes
Technically no, but both sides of the bridge were the same with elaborate panels on the inside and none on the outside.
Thanks for your thoughts guys. Part of me is glad there is no obvious answer that I missed - the other part is still curious!
Hughby
