What are the widest and narrowest station platforms?
TheRightTrack
Verified Rep - TheRightTrack
1 Oct 2024
Cambridgeshire
I believe that everyone agrees that Colchester has the longest (broken) platform and Beauly has the shortest but what are the widest and narrowest? Does anyone have an idea? Thanks!
Dr Hoo
10 Nov 2015
Hope Valley
Measuring across the ‘middle’ of Edinburgh Waverley’s central island between the tracks on either side must be in with a chance for the widest. (Please don’t expect me to get the bizarre numbering right.)
Several Underground stations have ends of ‘platforms’ in a tunnel mouth under ‘Do not alight here’ conditions.
Tetchytyke
12 Sep 2013
Isle of Man
All the way along the platform, or just the narrowest at the most narrow bit? If the latter I’d say Gargrave, where the platform goes under the toad bridge, is up there as one of the narrowest.
CarltonA
22 Apr 2012
Thames Valley
Wraysbury platforms are very narrow under the bridge. Staying behind the yellow line would be a challenge for most.
Cach17
13 Jul 2023
Kent
Wapping on the LO East London/Windrush Line must surely be a contender for narrowest in London. Without a derogation from HMRI (His Majesty's Railway Inspectorate) it wouldn't even be open today.
MichaelTrains
9 Jun 2022
Bradford
Carlisle wins this easily.
This is how narrow the platform is between platforms four and seven.
Euston P1 at the country end is extremely narrow. A few feet I think.
I think the Blackfriars bay platforms before the rebuild were much worse than that. IIRC at the south end the yellow lines crossed over…
Probably not quite the narrowest but Beltring's platforms are narrow enough that a train arriving has the automated announcement "Would customers please take care when alighting as this station has a narrow platform."
I've never been to Blackfriars but would they have express trains like 10/11 Pendolinos coming in at speed?
Er no, and definitely not in bay platforms. The risk was mostly to people getting off trains, if they took a second pace away from the slam door they were exiting they’d be at the opposite edge.…
trainmania100
8 Nov 2015
Newhaven
Lewes between platform 2 and platform 3. Originally there was a single track in between many years ago, this has been filled up and leaves a generous gap and cafe between the two platform s
Nev20
11 Oct 2015
probably won't win any awards, but I have always thought the london bound platform at Bicester North is bizarrely deep.
lewisf
21 Feb 2009
Kingston/Surbiton
The portion of the down platform at Balcombe underneath the road bridge. It’s less than the distance to the yellow line so you’re only allowed to alight there.
21 May 2014
Narrowest it might not be, but for the number of people you can get on it, the very top of Birmingham New Street Platform 4C / 4B seems perilously narrow sometimes. There is a very, very small area between the yellow lines for each platform and often hundreds of people.
That was built out in one of the early Evergreen line speed and doubling improvements to meet the existing position of the then up fast line. I think it’s fairly clear looking from the gap at the London end how it’s been done, the station originally had a much more complex track layout, with both platforms on loops off the through pair. You can see the road bridge just past the station was built for 4 tracks.
CarltonA
22 Apr 2012
Thames Valley
This has only been the case for a few years. Previously the platform was a fairly normal width with through lines. The present set-up allows faster through trains on the up side. Edit: Pipped to it by the above.
Nottingham59
10 Dec 2019
As for the widest, in my part of the world Netherfield is 15m wide and Burton-on-Trent is 18, both measured off Google maps. The island between P1 and P3 at Nottingham is around 24m, but obscured by the canopy.
Zomboid
2 Apr 2025
Oxford
I think Beaconsfield is the same.
Kensington Olympia has something similar going on, but they didn't make the new platform very wide.
CarltonA
22 Apr 2012
Thames Valley
The platforms at Beaconsfield are in their original place but the through roads have been removed. Same goes for Denham but a new island was installed as the old down platform was subsiding down the embankment.
Zomboid
2 Apr 2025
Oxford
Gerrard's Cross is what I was thinking of. Those stations merge into one in my mind!
geoffk
4 Aug 2010
Exeter
Polsloe Bridge must rate as one of the narrowest and there's no overbridge restricting the width. The yellow line is nearer the back fence than the edge of the platform. I must take a tape measure next time I'm there.
sad1e
26 Aug 2024
Sudbury and Harrow road has some very narrow platforms, definitely the narrowest I've been on on the NR network. The part over the yellow line is actually larger then the part behind it.
Quite terrifying when you have a class 68 hurtling towards you down it. (Attached photo of 68015 passing the station)1750088303614.jpeg
