What actually constitutes checking a route on the NRE website?
YorkC
26 May 2013
I've found a few interesting routes today where the NRE website and various booking engines will give a route but not offer any fares for sale. I'm happy to take these slightly more creative routes and have always been fine in the past.
As an example, here's York to Mexborough via Manchester Piccadilly (feel free to move if this is worth keeping on the DL...). It shows as a valid route using the new Yellow Pages. The NRE website, and other booking engines, offer routes for this but nowhere will sell a ticket for this route explicitly. Unsure if this link will work, but have a look at...
http://ojp.nationalrail.co.uk/servi...illy&saved=false&responseId=4&fareDisplayId=1
So my question is: does this process constitute checking and finding a route to be valid?
bb21
Emeritus Moderator
4 Feb 2010
It does in my opinion if you can find a website willing to sell this ticket for an itinerary via Manchester.
It indeed appears valid by the Routeing Guide but I struggle to get any booking engine to sell me this fare via Manchester, and NRE shows that you need more than one ticket to make this journey.
YorkC
26 May 2013
Ah yes. Good spot. The confusing thing is that it says more than one ticket is needed, then just lists the Anytime Day Return as the ticket required.
(http://pbrd.co/1jk4LjA is what NRE shows, btw)
Booking engines will allow me to get this far, too, but won't sell me any tickets for the route:
http://pbrd.co/1ey4p6J
It's absolutely baffling because this (i.e. changing at Manchester) is the only way (as with a lot of routes listed in the Yellow Pages) to use the map combination specified (in this case, MN+DW). Why is that combination even specified in the routeing guide if it's literally impossible to buy a ticket on any route that uses those maps?
Solent&Wessex
9 Jul 2009
As I see it: Mexborough is associated with Swinton or Doncaster. Both stations pass the fares check.
York to Swinton is only valid on Map DS. This does not show Manchester.
York to Doncaster is valid on map DO & MN + DW. The latter combination does allow going via Manchester, however I suspect this is an error as this journey has never traditionally been valid via this circuitous route.
There is however an easement thus : "Customers travelling from Doncaster to Newcastle, Chester Le Street, Durham, Darlington, Middlesbrough, Thornaby, Yarm, Northallerton, Thirsk, York, Malton, Seamer or Scarborough in possession of tickets routed "Any Permitted" may not travel via Manchester Stations. This easement applies in both directions. "
Which will probably by declaring this journey void.
bb21
Emeritus Moderator
4 Feb 2010
The way I see it is that he is not travelling from Doncaster, so the literal interpretation does not prevent him travelling this route.
kieron
22 Mar 2012
Connah's Quay
I see. I was wondering if you'd come across something more like the "We are sorry, we are not able to find any fares that match your journey details" message (and they should be sorry, as a Rail Ranger would meet this particular need perfectly well).
It's listed as a route between York and Doncaster. It is very easy to get an itinerary between those stations using those maps (although I haven't tried to find one which involves a train which stops at Mexborough).
There are 3 map combinations to consider with your journey, DS to Swinton, and DO and MN+DW to Doncaster. Both DS and MN+DW require you to pass through Mexborough en route to the final routeing point. NRE doesn't generally consider that to be valid on a ticket to Mexborough.
Starmill
18 May 2012
Bolton
So what you're saying is, it is valid, but you don't like it so it shouldn't be used?
YorkC
26 May 2013
Can't do it myself. Does it avoid Manchester and use Guide Bridge/Chinley?
button_boxer
12 Nov 2009
If you're trying to use Doncaster as the routeing point instead of Swinton, isn't it an issue that you have to pass through Swinton in order to do York to Doncaster via Manchester?
bb21
Emeritus Moderator
4 Feb 2010
I don't think that in itself is an issue.
As for that easement, it does not apply to this journey. I'd also buy the ticket from Poppleton, so it doubly doesn't apply! :p
However anyone wanting to do this journey must buy the tickets soon because the Routeing Guide will obviously be amended shortly now that the TOCs (in particular TPE) are aware of it :lol:
kieron
22 Mar 2012
Connah's Quay
Sorry, I think I may have made a mistake or two in my last post. If I ask it to go via Manchester and avoid Crossgates, it gives a route which follows the maps carefully (such as the second on the list), but doesn't list a fare for it, even as a combination of tickets.
One obvious criticism of the route in your screenshot is that it uses maps for York-Doncaster but never reaches Doncaster, but that's clearly not the problem.
YorkC
26 May 2013
It's also not giving valid routes as far as I can see, anyway: York->Doncaster is the first leg of the route.
But, in any case, isn't it invalid anyway under the new rules given that NRE won't give a route for the journey on one ticket?
Under whose rules? where is this documented? Did DfT approve the introduction of such a rule? Were Passenger Focus consulted?
YorkC
26 May 2013
So is it a general consensus that these updated "rules" are an unenforceable nonsense?
Solent&Wessex
9 Jul 2009
But he is using a Doncaster as a Routeing point which may be why NRE is declaring it void.
No. What I am saying is that it has never been valid this way, even under old versions of the guide, is not even vaguely sensible, there is a negative easement which, depending on your interpretation renders it invalid, NRE says it is not valid and is fairly obviously an error.
That is somewhat irrelevant. The routeing guide says a journey should be validated by NRE. The fact that it may not have gone through the correct approval process is a different matter altogether and does not by default render what the guide says invalid. If you take that argument then I could argue that the changes which have allowed this route are invalid and a previous version of the guide should be used, which didn't allow it.
No.
YorkC
26 May 2013
If anyone's interested, I did manage to find a ticket in this fares cluster (£23.70 anytime return) for which booking engines will give me a reservation between York and Manchester...
