What’s this metal post for!!!
Southern Beau
29 Oct 2007
South Coast
Forgive me if I’m asking a silly question, but does anyone know what this recently installed post will be used for?
Horizon22
Jobs & Careers
8 Sep 2019
Where is it? Seems like it’s new so could be used for CCTV or a whole myriad of other things.
LBMPSB
20 Apr 2019
Looks like the bottom part of a hinged post. Either for station lighting, DOO Monitors/CSI Screens or an LED Signal. A lot of things that are high up on post are now installed on hinged posts, so that the upper half can be lowed without the need to use ladders/scaffold and the resultant Line Blockages needed for safety. The upper half of the post (not fitted in the photo) can be lowered to ground level, clear of running lines and at a level for staff to work on e.g. change lamps, monitors, fix signal heads etc.
I’d say more likely to be CCTV or similar.
Lighting columns are almost always a round section, although they’re also hinged for maintenance.
LYRobert
18 Apr 2022
Banbury
There is a label visible on the object which reads "Alton Comms Equip. Ltd". I looked them up - it is the base for a "Tilt-down" CCTV column. One picture in their catalogue shows the retaining bolt (to keep the mast upright) is located behind the panel towards the base. I noted there were lugs towards the base designed to attach something.
Where is it please?
Where is it please?
It's Altron, not Alton
Although why it 2024 they put a sticker on with a fax number, not an email address for contact seems bit obscure
coppercapped
13 Sep 2015
Reading
Where is it please?
Oh dear, now you've spoilt it! I was betting on it being a hitching post for the station dray horse... :lol:
