Coming from the west, where would be the best place to double back to Heathrow by the EL? Ealing?I believe from the previous thread, all active work was “paused indefinitely” by NR in Jan 21.
I suspect it’s kicked so far into the long grass it’ll never be seen again..
If on the EL it will be Hayes and Harlington, in the Offpeak there are also some GW stopper calls there as well.Coming from the west, where would be the best place to double back to Heathrow by the EL? Ealing?
Agreed, it would be better to put any western link onto the Staines/Windsor lines, but that requires a solution to the level crossing problems to be found (among other problems).When the West London mega-hub at Old Oak Common opens it will be the obvious interchange from Wales and The West to Heathrow, diluting the usefulness of any Western Link.
Yep I agree. Hayes for locals and OOC for long distance (GWML and HS2 north) will be plenty.Agreed, it would be better to put any western link onto the Staines/Windsor lines, but that requires a solution to the level crossing problems to be found (among other problems).
Crossrail 2 achieves more or less the same for the South West London catchment, via interchange with EL at Tottenham Court Road.Whereas a Southern link - crucially if it could hit Clapham Junction - would open up a huge new rail catchment for Heathrow and save a lot of car/cab journeys. As to whether it goes just to Waterloo (and avoid the Egham thing) - maybe 4tph is possible, 2 via Richmond and 2 Hounslow - or there also is an onward service to either Reading, or Woking-Guildford/Basingstoke via Addlestone as various plans have had - totally depends on the level crossing stuff which I suspect will never change materially.
I travelled from Bristol Temple Meads to Heathrow T5 and back this week, and the journey that was both quickest and cheapest was changing at Reading and then Hayes & Harlington. The changes were short and reliable in both directions.Coming from the west, where would be the best place to double back to Heathrow by the EL? Ealing?
Despite that, even from nearby Reading or Slough it's still quicker than driving, and all EL stations have lifts. OOC will make the transfer from further west even easier.One issue that has not been addressed is the minimum interchange time at Hayes & Harlington, which is still 3 minutes. Hence National Rail Enquiries shows "valid" itineraries where Heathrow passengers loaded with luggage would have to be heroically fit to cross the station in time to catch the connecting service.
I reckon 6 minutes would be a more appropriate minimum interchange time for airport passengers.
Heathrow to Clapham Junction (and on to Gatwick) could be theoretically served via Acton Bank, West London Junction and Mitre Bridge Junction. I don't believe the journey time would be too shabby either, but suspect that demand might be lacking. Plus of course there is a small gap in electrification.Whereas a Southern link - crucially if it could hit Clapham Junction - would open up a huge new rail catchment for Heathrow and save a lot of car/cab journeys. As to whether it goes just to Waterloo (and avoid the Egham thing) - maybe 4tph is possible, 2 via Richmond and 2 Hounslow - or there also is an onward service to either Reading, or Woking-Guildford/Basingstoke via Addlestone as various plans have had - totally depends on the level crossing stuff which I suspect will never change materially.
Would it not allow an increase in services to Heathrow with services running through rather than terminating and reversing causing congestion.Despite that, even from nearby Reading or Slough it's still quicker than driving, and all EL stations have lifts. OOC will make the transfer from further west even easier.
Given this, it's difficult to see how a Heathrow western link could have a business case anymore, unless perhaps it was used to enhance through capacity on GWML, via Heathrow.
Unfortunately there's nothing simple about getting the shuttle into Staines. The route is very constricted and Staines only has 2 platforms.A simple shuttle link to Staines
would pick up a lot of car users from the southern side of Heathrow. Getting car traffic down around that part of the M25 must be some sort of priority, even if policy now requires no expansion at Heathrow. It is, after all, the local airport for a lot of people in Southern England and tweaking the SWR services to give better access to Staines from points beyond just Surrey and Berkshire would improve access for a lot of us.
As I write I'm planning a journey to Heathrow from Basingstoke for Monday, and the best option includes a trip around the M25 ( in a bus, to be sure, but that's just another vehicle clogging Britain's busiest motorway, and I'd guess there'll be no more than a dozen people on board)
Maybe, but that is also in the long grass.Crossrail 2 achieves more or less the same for the South West London catchment, via interchange with EL at Tottenham Court Road.
Staines is not always the easiest place to get to. There is a bus link to Heathrow at Feltham. Probably as good as it is going to get for a long time.A simple shuttle link to Staines
I assume that extra terminals and runways at Heathrow are also now completely off the agenda as well.
A way of increasing Crossrail capacity by flowing services through Heathrow and onto Reading?Given this, it's difficult to see how a Heathrow western link could have a business case anymore, unless perhaps it was used to enhance through capacity on GWML, via Heathrow.
It would allow XC to extend its Reading terminators, once they have bi-mode trains, unless the plan is to extend them back to Bournemouth. But I guess there would need to be more than a train every two hours! The coach takes a lot of Heathrow traffic from the west and is probably the way I would get there from Exeter.Despite that, even from nearby Reading or Slough it's still quicker than driving, and all EL stations have lifts. OOC will make the transfer from further west even easier.
But by far the easiest and quickest means of getting from Bristol to Heathrow is the hourly direct coach from Bristol Bus Station ....I travelled from Bristol Temple Meads to Heathrow T5 and back this week, and the journey that was both quickest and cheapest was changing at Reading and then Hayes & Harlington. The changes were short and reliable in both directions.
If travelling by train from Temple Meads to Reading, changing to the railair coach at Reading will save you far more timeI travelled from Bristol Temple Meads to Heathrow T5 and back this week, and the journey that was both quickest and cheapest was changing at Reading and then Hayes & Harlington. The changes were short and reliable in both directions.
If you were attempting to make an hourly train from Liverpool Street missing a change at Hayes could easily turn a comfortable connection into quite a tight one. I will concede that there are very few journeys for which this is likely to be a serious problem.Are people 'booked' on a specific Elizabeth Line Service? With 6(?) trains an hour missing an onwards EL connection is hardly a problem.
Wondering where the current MPs for Hayes & Harlington (John McDonnell) and Uxbridge & South Ruislip (Boris Johnson), or their successors are standing re Heathrow Expansion?Temporarily off the agenda. They’ll be back before long.
Looking at a typical evening itinerary, next week around 4pm, Bristol Temple Meads to Heathrow T5:If travelling by train from Temple Meads to Reading, changing to the railair coach at Reading will save you far more time![]()
I do go that way sometimes, particularly on person travel rather than business, but it is a bit slower (2h25 vs 2h10 now via Reading & Hayes) and I live much closer to Temple Meads than the bus station.But by far the easiest and quickest means of getting from Bristol to Heathrow is the hourly direct coach from Bristol Bus Station ....
4 trains per hour at the moAre people 'booked' on a specific Elizabeth Line Service? With 6(?) trains an hour missing an onwards EL connection is hardly a problem.
