West Midlands Trains "Destination Manchester" - will it happen?
Xenophon PCDGS
17 Apr 2011
I do not work in the railway industry so I have no inside information on this or anything else. I sent an email enquiry to stakeholders@wmtrains.co.uk to ask about the current status of this proposed new passenger train service which is the subject of the currently showing "Destination Manchester" page on the London Northwestern Railway website. I received the following quoted reply.
Thanks for the submitted information. To me, the word "apiration" in the LNR reply tells of the actual current state of matters.
llewjones
19 Dec 2025
Huddersfield
Both Stafford and Stoke already have direct services to/from Birmingham International (the CrossCountry service). Direct Manchester Airport services would be welcome though.
I should have made it clear, I was referring to a link from Stoke/Stafford to Manchester Airport
Thanks for posting that. It is accurate.
SeanM1997
2 Feb 2016
I know it won't happen but it would enhance connectivity from Walsall/Cannock if the service became a Manchester Airport - Crewe - Stoke - Stafford - Rugeley - Walsall - Birmingham NS - Birmingham International, connecting the 2 airports and avoiding the vast amount of movements in Wolverhampton. Yes slower, but CrossCountr already connect Stoke to Birmingham and this would be an alternative route
I believe there was once ambition to connect Stoke and Walsal which this could do
VT 390
7 Dec 2018
If possible this would provide useful connections from Walsall/Cannock to the north but I would have thought this would cause more conflicts as via Wolverhampton would mostly use existing services/reinstating removed services where as going via Rugeley would have to cross Colwich Junction and cross the entire WCML (southbound) north of Rugeley Trent Valley. There would also be the single track/platform section through Rugeley Trent Valley station which could cause congestion on the WCML. At least going via Wolverhampton the WCML fast lines can be entirely avoided to minimise conflicting movements.
Topological
20 Feb 2023
Swansea
I can see the logic, but the crossing of the WCML would be problematic.
You could use the line from Stafford to Wolverhampton via Penkridge and then go to Walsall to reverse. That would be easier to path if not serving Wolverhampton as it could cross at the same time as a train was crossing to/from the Shrewsbury line immediately north of Wolverhampton station.
People might then say just serve Wolverhampton as well. Then you have more potential conflicts as anything on the Telford/Shrewsbury line comes into consideration. Wolverhampton does have 4 through platforms to mitigate slightly. That would need modelling.
I would start back from Piccadilly using the path of something from the main shed to the airport. The service could then also take price sensitive customers between Manchester and Birmingham. It may only be the Northern stopper to Crewe that has an airport path from the main shed though. I cannot remember.
Would anyone then choose to use this service instead of one of the existing connections is a good question, but it might be worth trying.
The price sensitive customers will happily change at Crewe or the Airport, and don't need to specifically be catered for by a through train.
Topological
20 Feb 2023
Swansea
I know. In the case of London it is on and off the TfW (though less now because I believe the connections changed)
I do not know which train between Manchester and Crewe caters for price sensitive Manchester to Birmingham connections.
The Northern trains between Manchester and Crewe generally have relatively cheap advance fares available. Split at Crewe and buy an LNR advance fare to Birmingham.
Farigiraf
23 Jul 2023
Bridge on the River Cam
I know any current and potential usage for Styal station is largely irrelevant with its 28k annual usage compared to the 'big fish' (Stoke - Airport, Stoke - Birmingham) but it does seem like it hasn't been thought of much, as if its hourly stop is moved to an Airport terminator service it'll lose its direct service to Manchester Piccadilly, the main destination for passengers using the station. That'll probably deter at least half the existing passengers from using the station, which is a small but not negligible ~10,000 people per year. Plus the Airport-Piccadilly local stations, such as East Didsbury, will lose their hourly Crewe connection which can be rather useful.
Bringing up Styal station for the 2nd time this thread now, my apologies for this, it's just quite the curiosity, going from a sporadic service, to 1tph to Manchester, to no trains to Manchester but an hourly service to Birmingham.
SCDR_WMR
17 Dec 2017
Crewe
I guess it means they head to Wilmslow on the LNR and onwards to Manchester. Certainly a poorer service on the face of it. Whether evening/Sunday services make up for that I don't know.
jfollows
26 Feb 2011
Wilmslow
The sporadic service was because the 2018 timetable was too tight at Crewe (time between arrival and departure) to allow Styal calls. Thank goodness that’s now gone.
Via Wilmslow became a permitted route on mileage because the official mileage from Styal to Manchester is now via Manchester Airport.
Farigiraf
23 Jul 2023
With a decent connection at Wilmslow it takes roughly the same time to get to Piccadilly as the direct service, but the additional change will be a deterrent for many potential users of the station.
Yes, changing trains should be normalised more in UK rail passengers' mindsets, but that won't happen until reliability improves and Styal certainly won't be the birthplace of this change of thinking.
Xenophon PCDGS
17 Apr 2011
Let us not forget that Styal railway station is very useful for prison visitors at Styal prison and for Styal line travellers wishing to visit the National Trust property of Quarry Bank Mill.
Would there be greater travel costs involved in the current direct Styal line to Manchester and the referred to Styal - Wilmslow plus Wilmslow-Manchester Piccadilly
Farigiraf
23 Jul 2023
Via Wilmslow is a permitted route from Styal to Manchester Stations - you can buy a non-split ticket via Wilmslow on the forum ticketing site, which proves that it's valid.
jfollows
26 Feb 2011
Wilmslow
I alluded to it earlier
but to amplify, a “permitted route” is always the shortest route or one not more than three miles longer than the shortest route.
With the advent of the Manchester Airport branch, the defined “direct” route from Styal via Heald Green to Manchester has been via Manchester Airport, with an increase in the defined distance as a result. The route via Wilmslow is now not more than three miles longer than this, so has become a “permitted route” also.
I think that the official mileage Styal-Heald Green is now via Manchester Airport, so Styal to Manchester is valid via Wilmslow as one example, and there may be follow-on implications, all based on the National Rail timetable mileage and therefore not directly controlled by the operating companies.
NRT mileage from December 2024:
Piccadilly 0.00
Heald Green 8.25
Manchester Airport 9.75
Styal 12.00 (9m 69ch direct?)
Wilmslow 13.75 (but 12.00 via Stockport)
This is obviously ridiculous in face of the “real” mileage but it’s the mileage on which the comparisons are done.
Styal-Wilmslow-Stockport-Manchester is therefore officially 13.75 miles versus 12.00 miles “direct” so within 3 miles.
I don’t believe that the Sectional Appendix, or hence the actual mileage, is involved here. I’m happy to be proved wrong!
Topological
20 Feb 2023
Swansea
If the Manchester to Wilmslow route is truncated at Manchester Airport, a new line name will be needed to replace the current "Styal line" nomenclature.
Assuming the line is still open (which it would be) then why?
Although the trains that route via the Styal line for diversion route knowledge are not calling at Styal, they do pass through Styal.
cle
17 Nov 2010
Could an Airport terminator be extended - even in peak hours (could be like 2 journey E/W) to and from Crewe, or Wilmslow even - to enable a limited Styal-Manchester service?
jfollows
26 Feb 2011
Wilmslow
Wilmslow has a reversing siding which is booked to be used by terminating trains from the north, mainly on Sundays. Trains can also reverse in the platforms.
tfw756rider
30 Nov 2024
Wales (sometimes in England), thanks for replying!
tfw756rider
30 Nov 2024
Both West Midlands Railway branded & London Northwestern branded trains appear on RTT as 'West Midlands Trains'.
I know - that's because West Midlands Trains is the Train Operating Company (TOC) of both of those brands (although that's not consistent with Realtime Trains splitting Govia Thameslink Railway into its 4 brands).
And timing load is meaningless
Well, there must be some meaning behind the Class 323 timing load (rather than 350, or even just electric multiple unit?)
24 Jun 2024
Lichfield
That is not relevant to this thread.
AndrewE
9 Nov 2015
It isn't far from the topic at all. My guess is that the 323s could have a slightly slower timing than a 350, so there is a template there to be used with minimal work - and if it is a slightly slower timing then that is all to the good as you would expect drivers on route-learning to accelerating and braking more cautiously and going a bit slower overall than the units are actually capable of.
