syorksdeano
- Joined
- 7 Jan 2011
- Messages
- 780
Who says there was an announcement? The OP only says they saw it on RTT.Did any intending passengers show a reaction to the announcement you heard?
It is now showing as 'problem with the train (M8)'Who says there was an announcement? The OP only says they saw it on RTT.
The most likely explanation is someone selected the wrong reason code. If it was subsequently corrected I'm unsure if RTT would reflect it?
IIRC, the system that RTT gets data from doesn't communicate updates to reason codes.The most likely explanation is someone selected the wrong reason code. If it was subsequently corrected I'm unsure if RTT would reflect it?
FWIW, my fellow passengers on a badly delayed train yesterday seemed to appreciate being told that the issue was a broken-down freight train.Did any intending passengers show a reaction to the announcement you heard? It's an insight into the value attached to cause-of-delay announcements by passengers that, however bizarre the announcement, they usually show no reaction whatever. By that observation, one might question whether these are of practical use outside the enthusiast passenger.
Ep.1 "Eleven minutes late, staff difficulties, Hampton Wick."I keep thinking of Reginald Perrin![]()
Hi Merle.I had assumed / jumped to the conclusion that the O.P. had heard a station announcement and looked to RTT for 'hard copy' evidence.
It does seem that the reason code is used as a source of displays on stations and on trains. The announcements on trains seem to be in sync with the rolling display, so I would suggest that the reason on RTT was also given in announcements.
To be clear, I'm not challenging the usefulness of the announcements but remarking on the indifference to announcements displayed by passengers. Displayed by continuing to talk loudly/play music over the conductor/T.M.'s first announcement of the reason the train's been stationary for a while, for instance. Or not realising the significance of 'Due to reason X this service termites at this station, All change please'.
There always seems to be a delight in blaming another rail operator or N.R., too; losing sight of the railway being the customers' supplier.
Should it be interpreted as "Train cancelled from Sheffield because it was turned back at Derby owing to late arrival there from St P International?
A bit familiar, is it not? Although I feel 'problem with the train (Sir)' might be going too far.It is now showing as 'problem with the train (M8)'
