Weird electrification at St Pancras?!?
jscz
9 Oct 2024
I'm sure someone has already asked this, so feel free to direct me towards there if possible :)
I was at St Pancras Low Level yesterday for the first time in a while, and noticed that rather than having overhead wires, the pantograph was getting its current from some kind of bar suspended from the ceiling. I'm not sure how new this is, but I can say it was changed from usual methods some time between 2007 and 2017.
Here are some images:
Figure 1: St Pancras Low Level in 2007. We can see here that the OHLE is the same as the rest of the 25kV network - copper wires suspended from the celling of the station box.
Figure 2: The platforms in 2013. It's quite difficult to make out what is going on from this photo as the angle makes it hard to discern from the equipment from each of the tracks.
Figure 3: This was taken in 2017 but is identical to how it was yesterday, so interpret it as the modern design. Now there is the bar and almost no other wiring.
I was wondering why the (copper?) wires were replaced with a (steel?) bar? I can't think why it's worth it, although I was wondering if the more stable climate underground means the wires don't have to be kept taught by the catenaries, so that could be a factor. It also reminded me of some metro systems where they have a DC 3rd rail suspended in the air rather than as a third rail, which looks quite similar to this but could be a co-incidence.
Anyone that knows why it's like this or could direct me to an already-existent answer would be a star!
SynthD
4 Apr 2020
It is an overhead conductor rail, for tight spaces where regular OHLE isn’t preferable. You can also see it on the Elizabeth Line.
jscz
9 Oct 2024
I wonder why they added it later rather than including it originally though. And why isn't it present at Farringdon and City Thameslink?
Edvid
7 Feb 2008
Here's a past explanation (by Bald Rick), from a previous thread on the topic:
Installed over Easter [2013]. Known as conductor beam. The contact wire is fixed to the underside. Much more robust than regular OLE, and practically zero maintenance.
It has replaced a tricky tension length of OLE between approx half way along St Pancras LL platforms* and the middle of the old KX Thameslink platforms. The curvature, cant and gradient change through this section made the OLE pretty difficult to keep in the right place and had high wear rates.
[* Extended through the Canal Tunnels and to just north of StP LL along the Moorgate lines since then]
Dr Hoo
10 Nov 2015
Hope Valley
The construction of the Thameslink 'box' at St Pancras was quite complicated. It was built 'round' he pre-existing brick arch tunnel and only needed simple catenary when it re-opened. The Canal Tunnels and junction with the link to the line out of KIng's Cross came later and the whole set-up had to be beefed up for very intensive operation and 12-car trains.
Magdalia
1 Jan 2022
The Fens
Possibly because that's where trains change from A/C to D/C and vice versa?
Raising a pantograph onto a conductor beam involves different forces to raising a pantograph onto a flexible wire.
norbitonflyer
24 Mar 2020
SW London
I believe one of the first applications was at Trowse swing bridge, where having a continuous tensioned wire would obviously be difficult.
Trowse was the first application I’m aware of in this country, and for precisely the reason you hint at, ie the opening of the bridge. You only get to understsnd the detsil when seeingit from the cab, and you can see it as three seperate conductor beams - one on the bridge and one each side, with a decent gap (side to side) to prevent arcing, but allowing the pantographs always to be in contact.
Back to the OP. The St Pancras Station page on Wikipedia states that the low level station opened in December 2007. I don’t think that is right. Not least because self and Mrs BR had a trip on the eurostar just before Christmas 2007, and we definitely changed via KX Thameslink.
My memory is that the Low Level opened in December 2009, on the Monday of the timetable change, a day after the Southeastern Javelin domestic services started. I well remember running for a train on the first Monday evening, having had, ahem, a pre-Christmas sharpener with some colleagues, and nearly taking a tumble as the brand new floor sufrace (laid that weekend!) hadn’t yet had the micro-etching done to give them some grip for people wearing shoes with a lower than optimal friction coefficient. Obviously the Christmas drinks had nothing to do with it.
Perhaps someone can confirm the opening date.
plugwash
29 May 2015
I did a google search for st pancras thameslink opening with a date range restriction of 2007 to 2010 and found a number of contemporary sources that seem to match the date on wikipedia. I did not see anyting that suggests 2009
bnc2018
14 May 2021
Banbury, Oxfordshire
I appreciate it's nearly 20 years ago but the the Thameslink station construction costs in that press release seem amazingly low compared to the costs of things now. According the Bank of England's inflation calculator, £70m in 2007 is £115m now - I'd be pretty amazed if something so ambitious cost anything near that nowadays
Warrior2852
27 Oct 2018
Network Rail's own history page on St Pancras says December 2007 for Thameslink, a month after upstairs.
The new St Pancras International station was officially opened on in November 2007 with Eurostar and East Midland services, and with Thameslink services joining that December.
Magdalia
1 Jan 2022
The Fens
My records say that too.
My last arrival at Kings Cross Thameslink was on 7 December 2007 and my first departure from St Pancras International Low Level was on 10 December 2007.
themiller
4 Dec 2011
Cumbria, UK
Garry Keenor’s book, Overhead Line Electrification for Railways describes this arrangement in 12.16.2 on page 165 as ‘a grooved bar designed to accept a conventional contact wire’ so it’s not a rigid contact bar but a contact wire which is supported along its length.
themiller
4 Dec 2011
Cumbria, UK
I think that the Severn tunnel was also fitted with conventional contact wire supported along its length.
JordR
31 Aug 2014
Is it considerably more expensive than standard OHLE? Is it only capable of accommodating lower speeds?
Well that just shows how memory fails. Thanks both (and others).
Yes, considerably more expensive.
For the avoidance of doubt, the conductor rail is not in contact with the pantograph. Contact wire is bonded to the rail for the pantograph to, er, contact.
Also I believe it needs supporting at much shorter intervals than standard OLE. That's not so important in tunnels where it's just bolted to the roof (and wire would also need a similar number of supports unless there was enough height to permit a catenary and droppers). But if it was used in the open air it would need many more supports.
Beebman
17 Feb 2011
Twyford
It's used in the open air at the Patchway Tunnels near Bristol as the gap between the two is only 160m which is too short for a length of tensioned cable:
https://x.com/NoelDolphin/status/1084861500248997888
Presumably a conductor bar is used to eliminate sagging and damage to the OHLE?
A contact wire is prevented from sagging because it's under tension, and also because there is a curved "catenary" wire above it which holds it up via vertical "droppers". The conductor bar is rigid but also much heavier and not under tension, so if the spacing between supports was as long as it is for a normal wire, then it would probably sag much more.
BRX
20 Oct 2008
Is it more expensive than 3rd rail? If so why not just extend 3rd rail to St Pancras and have the changeover there?
jfollows
26 Feb 2011
Wilmslow
“extend 3rd rail”
not going to happen!
plugwash
29 May 2015
Even if you extended the third rail the changeover at St pancras you would still need an area of overlap that was sufficient to provide for contingencies such as failed power changeovers. So you would probablly still end up needing OHLE out of both ends of St pancras.
Warrior2852
27 Oct 2018
They don't do third rail extensions anymore, even small ones - Merseyrail had to buy battery trains just for a one station extension because they couldn't do more third rail.
